Fiberglass?
LA
RE: Fiberglass?
45 deepvee here is the drawings. Open this and download the maxcatv-1 print it out at 100% and start building.
http://cid-d15bb0f76da55eb3.skydrive...MaxCatV1-L.zip
FL
RE: Fiberglass?
All that I had is bad, hate to spend the $$$ to fix such a small area, that is why I asked about the epoxy paint, do you know if it will bond to the area?
Thanks;
Thanks;
RE: Fiberglass?
Epoxy will bond to almost anything so you will be fine,but if it were me and to save painting id use a small amount of poly resin with some colour additive or gelcoat mixed into a paste with talc if the damage is deep? if not just use gelcoat as Hemi says.gelcoat is cheap and you dont need a lot just get a 500 ml tin and some catalist mix with some talc (usually very cheap from the gelcoat suppliers )to a paste if needed .
Mart
Mart
FL
RE: Fiberglass?
Thanks Mart; I will go with the poly and color, already have the catalist. And I have some good resin, not sure if it is bonding or finishing.
Again thanks
Randy
Again thanks
Randy
RE: Fiberglass?
Good tip for you to get cheap resin or gelcoat is look up any fibreglass moulding companys they will usually sell you some pretty cheap.I used a company that makes glass fibre roofs among other things and the gelcoat and resin was half what i usually pay and it was the exact same stuff too.
Mart
Mart
#31
RE: Fiberglass?
ORIGINAL: painman
Thanks;
Thanks;
#32
NE
RE: Fiberglass?
I up loaded an image of the damage I am trying to repair, can anybody give tips on how to repair this, my LHS recommended this finished two epoxy resin kit. Do I mix that with talc like im reading in multiple forums for repairing this. He also stated to repaint it with simple testors modeling paint.
