Central NEW YORK boaters
#702
PA
RE: Central NEW YORK boaters
You will be fine with that setup. My Whiplashes run long pushrods, but they are pulling. Anyway you don't want to give the hydros too left or trouble at speed.
#703
NY
I have some spare pipes and props. let us know when your coming. My Miller is still in wood stage. no paint. I will get my Atlas Van Line ready for next year. The only place they still race them hulls is London Ont. And a few other states. Mine is a shelf Queen.
#705
Hello Neil hope all is good at your end.
just to let you know that we did race the 1/8 scale at our
Sept... race.
got to love them scale boats.
Sept... race.
#706
NY
ORIGINAL: Canadian LoCo
Sept... race.
Sept... race.
#708
That is a very good question and, because of many variables, has no single correct answer. The driver's style of driving has an affect, but there is more to look at than just that.
The boats have the following inherent to themselves as variables:
weight-affects how fast the boat can accellerate
hull type-is the boat a round nose, pickle or blow hole. Each has different aerodynamic and hydrodynamic profiles that must be addressed
set up-this includes balance, fuel, engine and pipe, prop type and depth as well as rudder and skid fin placement
The course has the following variables:
corner radius-it's harder for a scale to maintain top speeds with a smaller corner than a larger one
straight length-a longer straight gives more distance for the boat to accellerate than a short one will
I know this is a very simplified way of looking at all the variables as I know there are more that can be addressed. For answering this question, however, this is plenty. Now, getting to an answer, I've seen one boat run close to 70MPH. This boat, an 8255 hull, was built for record runs and was a whopping 8 POUNDS RTR. I've seen Thrifty Too's and a 60 powered Coral Reef that were literal rockets on the straights but couldnt' turn at speed due to the length to width ratio, they were so narrow they tended to barrel role in the corners. With the boats racing in the Northwest, we normally see speeds in the lower to mid 50s. This is partially due to the smaller courses we run on as many of our sites are fairly small and restrict either the course width or length. The average boat also weighs in at an average of 15 pounds so they are slower off the corners and at the start than the 8 pounder.
#709
Great info, and really interesting. Its also amazing how much it really takes to pull an extra few mph hour of a boat, as opposed to doing it on the pavement
#710
What is bad is I just barely touched on some of what's involved while some of the "experts" think it's all engine/pipe/prop and maybe a little in the balance. In their opinions, mod the engine and you will have a fast boat, while weight, balance and overall set up are all nonfactors, rather than being important as well.
#711
NY
Thursday night running...Guys, I will most likely not make it out to Stony Pond tonight (bummer!!). I am leaving for New Hampshire in the AM and need to get some errands done tonight.
FYI...I put the damaged VS-1 tunnel on the bench and really dug into the motor mount assy issue. I would say the I paid $125 for the hull new, and it was really worth about $50!! While the wood cut and design is very good, the gluing and assembly is typical Far East!! The gluing around the mount uprights, was for the most part, non-existent. This allowed water and fuel residue to enter the center cavity, rotting the wood in just one season. I think I may have just enough good wood left on the center section to epoxy it back together. After I get the structure re-set I will 'glass' the uprights and bottom support to the center section with 2oz cloth, as well run a bead of epoxy along the sponsons to help keep water out. I estimate about 8-10 hours of hobby time to piece it back together. Roger C.
#713
ORIGINAL: engineman351
#714
ORIGINAL: advanced builder
Is anyone running? or this weekend ? I have my EVee to test.
We have an Elmira race coming up on Oct. 1st. Who is going and what are you racing??? I'll be racing 20 mod tunnel and 20 hydro again.
#715
And people wonder why I refuse to buy any of the premade boats. Roger, your experience, along with that of others has me staying with wood hulls that I build myself. I just don't trust that any of the ARTRs or RTRs are worth the prices they are charging. After seeing the way some of the ARF planes were built, there is no way I would buy any of the hulls coming from China or Taiwan as the quality just isn't there. Oh well, off the the garage to work on engine mounts
#716
NY
Craig, I am not sure I can make Saturday at Elmira for the Oct race. If I do, I will only bring two gassers, Thunderboat and Mono. I will only be able to run two heats (and miss the banquet) as I have an evening committment in Penn Yan on Saturday night. I am also planning to show up Sunday AM for the donation and raffle. RAC
#718
ORIGINAL: Joe Petro
I can be there on Sunday. I have 4 boats to test...
Joe
Joe
#719
NY
I'm in as well I have 3 hulls to test. My EV , .67 cat &.21cat. I waiting on the inner coupler .187 I still use the old K&B coupler. the inner piece keeps going bad after a few seasons. My .21 rigger is badly damaged but savable. I think My .21 NR is also done. I'll take my CMB and swap. My new{old} Gas Aeromarine Vee is all most done. I used a Zippkit radio box to replace the damaged one. All batteries are charged.
#720
PA
Neil,
I am bringing my NIB Nova 35 Plus to the next race. It comes with collet, header and a really nice new Frank Orlic carb. Was going to run it in the JAE21 I have but I am out of nitro. It will scream in the JAE.
Bill
Bill
#723
NY
Bill I had a bearing go. It blew out a piece of the case. The case was JB Weld, but the piston is badly marred up. the sleeve is OK The rod is on the way out too. I do have a Picco & OPS to use. We will talk next weekend. I have already committed to Sue's Vee.67 hull. Let me see what I can come up with.
#724
PA
Don't worry about it bro. I will work with you. Do me a favor: run the engines on the rich side. ALL my nitro boats had 3rd channel needles to adjust mixture once the setting was close. If you run 55% or higher and happen to be too lean, the bearing are toast.
Bill
Bill
