EXI 450 build, component selection help
#51
FL
ORIGINAL: mksubaru
hello everyone, i´m also bilding a 450, mine is a clone HKH 450, my question is, i dont want it to be fast, so what motor should i get? can i use a e-max 25c i already have? i´m gona put some pictures about the servos i want to get, they are not the best, wish i could get the hitec, but let me know witch one you tink is the best, both have a 1,5kg torque. thanks to all.
#52
thanks noobflyer01, gues i´m gona get the htx900, i just got a Colco GY400 AVCS gyro, it´s not to bad to start is it? one more question, i cant aford to get a futaba or a spektrum rightnow, so, can i use this http://cgi.ebay.com/ws/eBayISAPI.dll...m=320363721729 , i have a walkera 60 and i could use the tx and rx from it, but, i would like to try something diferent then walkera, everyone says their electronic is really bad. thanks to all in advance
#53
FL
the transmitter in the link you provided is the esky 72mhz 6ch. this will not work for you. its not a programmable transmitter. your transmitter doesnt have to be futaba or spektrum but it needs to be programmable. if you have never set one up before then i highly recommend you getting a futaba or spektrum since most everyone have them and can help you in programming your heli. do a google search for finless bob helifreak tech room. all your setup answers are found there.
