Spinners
Old 09-04-2010 | 06:46 AM
Default Spinners
HELP!!! I need a couple of ELECTRIC Spinners, 3.25 to 3.50" for my 73" Mosquito that I converted to electric. Well, I mean ones under $20.00 bucks each. I did find some carbone ones at like $44.00 each. NTY! Thanks, Ken
Old 09-04-2010 | 07:09 AM
Default RE: Spinners
Why do they have to be electric spinners? Tower sells a lot of nice spinners in your price range for glow engines. Just enter "3" spinner" in the search window on Tower's(or any other hobby) website. I use these, http://www3.towerhobbies.com/cgi-bin...?&I=LXEBE5&P=7
Old 09-04-2010 | 08:23 AM
My Feedback: (13)
I recently put one of the above mentioned spinners on an OS 1.20 ax instead of spending $50 on a tru-turn. Ive gotta say, I like it. I have found my alternative to the higher priced spinners when I dont want to spend the $$$. Have one in white; and just ordered another in black. Should be in today hopefully.
Old 09-05-2010 | 03:55 AM
Look for the plastic ones with alluminium backplate. I think Tower sells them.
Regards
Old 09-05-2010 | 05:56 AM
ORIGINAL: TommyWatson
Regards
The aluminum backplate spinner is what the above link is. I first used the the plastic spinner with aluminum back plate some years ago to help a forward CG I had. I found that the aluminum back plate spinners didn't slip like the plastic back plate spinners. I now use them on all my planes and have had no issues. Good spinner for the money.
Old 09-05-2010 | 09:48 AM
This is the one.
http://www3.towerhobbies.com/cgi-bin...?&I=LXBMY8&P=7
many sizes, they also have a lighter spinner called E Spinner
http://www3.towerhobbies.com/cgi-bin...?&I=LXRBB4&P=7.
I use them on both electric and Glow models
Regards
Old 09-05-2010 | 02:21 PM
Hey guys, I thought that the plastic spinners were to heavy for electric motors, is that NOT correct? Are you saying that you DID use those heavier spinners on electric motors? If yes, you did, then GREAT, I'll order some today. Many, many thanks. Ken
Old 09-05-2010 | 04:38 PM
Too Heavy? No, they are ligher than all alluminium spinners. The alluminium backplate makes them much more stable and less liable to the distortion that can happen to the all plastic spinners. They are easy to fit. The cutout for the prop is thinner around the edges and easilly trimmed with a knife to fit the prop. I can't see any down side to these spinners.
Regards
Old 09-06-2010 | 09:44 AM
Banned
As I recall, the Mosquito had a shape that is NOT consistent with standard spinners.
Les
Old 09-06-2010 | 01:03 PM
How true how true! However, begars can't be chosers! You find me a 3.25" spinner that IS correct, and I'll buy 'em! Thanks, Ken
Old 09-07-2010 | 09:25 AM
Banned
Since this is for electric, rather than fuel, the spinners do not have to be as beefy (to stand up to the pulse). Should be able to fabricate some out of fiberglass. Blue foam forms glassed over, and emptied.
Les
Old 09-30-2010 | 07:35 AM
 I have a O.S. 46LA. 2 times the propeller has came loose and flew off. Once giving me 8 stitches. Any thoughts?
Old 09-30-2010 | 08:35 AM
My first thought is it's not the fault of the spinner.
Old 09-30-2010 | 09:02 AM
Charlie P.'s Avatar
ORIGINAL: [email protected]
Do you have a prop nut and a lock nut? Or you're just not tightening the nut enough. Ihave used single nuts or bolts on many engines and never had a prop fly off. Try some blue Loc-Tite, but it shouldn't be necessary.
Old 09-30-2010 | 02:35 PM
Are you using wood props, if so the wood is probably compressing under the prop washer causing the nut to become loose.
Old 10-01-2010 | 06:16 PM
My Feedback: (90)
ORIGINAL: Crash-RCU
What is meant here is that at each flying session before you fire your engine up check your prop. Wood props compress slightly when tightened. that sets it up to slip when the engine starts. Then it just works the nut off like really fast. Moral of the story. Tighten your prop nut each day you go out to fly.
dennis
Old 10-02-2010 | 09:28 AM
Banned
Seems that my four strokes came with a castelated lock nut.
Alternative could be to find the right size "NYLOCK" nut. This is a nut with a dome shape on one side, filled with nylon. Problem may be that it is too long (tall) to fit the shaft properly.
Les
Old 10-06-2010 | 06:26 PM
I too would like to replace my plastic spinner with the aluminum backed one, but it sounds like the shaft hole for the motor is round. My spinner plate is round with two flat sides for the plate to lock onto the motor. How will that work/
Andy
Old 10-06-2010 | 08:32 PM
Uh-hhhhh guys, this has got away from he direction it was intended. Please read the beginning post for direction, unless I'm wrong. Albert (Ken) McCormack
