101" C-130 arf
#101
My Feedback: (30)
GA
RE: 101" C-130 arf
you are right, it is a lot of money. the real kicker it is not worth it, sorry kit ,poor instructions. and a pain in the butt to build. i would not do it again!! hey if you really want one i will sell you mine rtf less recv. 1200.00 3 flights with a lot of repairs due to product failures. randy m
#103
My Feedback: (30)
GA
RE: 101" C-130 arf
good choice,i still am not comfortable with mine. every time i try to fly it something different seems to break or malfuntion. i had to re-weld the main landing gear on retracts,welds broke on takeoff last week,see video at trentonrcflyers.com. that was a shock to do a 360 spin on takeoff!!!! randym
#107
My Feedback: (30)
GA
RE: 101" C-130 arf
hey guys, I have been in contact with Mike Greenshields at hobby people the last few days and he and his co-workers have been great on advice and suggestions on the c-130 as per set-up and flying.If any of you have or had problems with this bird or have had one crash ,call or e-mail him he truly does care and will help solve any problems. [email protected] Randy m
#111
My Feedback: (30)
GA
RE: 101" C-130 arf
well i got my replacment plane today from hobby people ,started on it tonite so we will see if 3 is a charm.the guys at hobby people have been great on advice as to flying instructions on this bird.i have talked to some of them that are flying the plane on a regular basis. randy m
#114
TX
RE: 101" C-130 arf
I was just wondering how much headaches you guys have had on running the engines inverted? I will mount my engines soon and I'm not sure which way to go, inverted or side mounted.
#115
My Feedback: (30)
GA
RE: 101" C-130 arf
hey gremlin, i am running gms 32 and the only thing i am doing is using os #5 glow plugs and keeping the idle trim up just a bit, you may have to really lean your low end setting down. but they are very reliable in the air.hope you enjoy the retracts they worked great for me. randy m
#116
My Feedback: (40)
FL
RE: 101" C-130 arf
I mounted my GMS 32's sideways. (See picture) The engines were running perfectly, but when I rebuild mine, I am installing an on board glow starter, just as an added safety feature. I have it ----- so why not use it. I am starting to put mine back together again, probably a couple of weeks for a maiden. Jerry
#118
My Feedback: (30)
GA
RE: 101" C-130 arf
Hi guys, well today was maiden on #3 c-130!!! All went well 2 clicks down on elev. and 1 click on left ail. was all the trim needed to fly hands off. I kept the power on half to 75% the entire flight. My langing was smooth as glass but a tad hot due to keeping engines running on long final. I am not going to fly it again till I install on-board glow just to be safe. Randy M
#120
MD
RE: 101" C-130 arf
Kool Beans, Randy...
U Da Man!
Mr DJ
Anyone--the narcells are numbered 1-4 but my wings are not. 1/4 and 2/3 are matches, but which goes where on the wings--my wings have no matching numbers.
U Da Man!
Mr DJ
#122
My Feedback: (13)
IA
RE: 101" C-130 arf
Randy m:
on the on board glow system,which one are you going to use?......Congs. on your test flight.........One more thing..I have 3 Mag 30's FS sitting around doing nothing...All I need to do is buy one more...Do you think that these are powerful enough for the C-130??
#123
MD
RE: 101" C-130 arf
ORIGINAL: randy m
the order is outside left is 1 inside left is 2 inside right is 3 outside right 4. get er done!!! randy
Mr DJ
#124
My Feedback: (40)
FL
RE: 101" C-130 arf
Sitting in the cockpit------the Number 1 engine is always the outboard engine on your left wing, and Number 2 is the inboard engine on your left wing. Number 3 is the inboard engine on your right wing, and Number 4 is the outboard engine on your right wing. This is the same for full scale. Jerry
#125
My Feedback: (30)
GA
RE: 101" C-130 arf
Jimmy I think the 30 fs would be plenty to fly it. I am using 32 2strokes and half throttle is still to fast, but keep in mind you have to keep this plane flying fast or it will stall very easy.Randy ps jerry I do not know what on board glow to use. Any suggestions?
