Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Combatpigg's 1903 wright flyer
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 11-05-2015, 01:43 AM
  #176
Pond Skipper
Pond Skipper's Avatar
What about using a QB or if you can reconfig for a counter clockwise spinning engine such as a TD .049 or Norvel .061 for enough extra boost.
Could create a a figure 8 in the O rings to keep them from jumping out perhaps a nylon roller where they intersect.
Old 11-05-2015, 11:31 AM
  #177
combatpigg
combatpigg's Avatar
I would only use a larger engine to spin a direct drive prop, just to get the model airborne and to see if this design CAN be flown as slowly as what the twin prop power plant provides.
Running the belts with less tension and idler pulleys is a possibility.
I've seen a floating idler that both sides of the belt loop feed through. The idler is not hard mounted to anything, it just floats.
Old 11-05-2015, 04:08 PM
  #178
MJD
MJD's Avatar
I'm trying to read your post, and on the right side of the the screen is the Ali ad, with some chick putting adhesive flesh color cups over her boobs plus what else. I still have no idea what you said, you built a Sopwith Cameltoe or something..
Old 11-05-2015, 04:47 PM
  #179
Pond Skipper
haha Mike!!!
Old 11-12-2015, 09:15 AM
  #180
danilo-2
Gustave Whitehead.. Interesting Wiki on a subject your School system wilfully ignored
Worth a read at least
https://en.wikipedia.org/wiki/Gustave_Whitehead
Old 11-12-2015, 09:53 AM
  #181
MJD
MJD's Avatar
Not to mention Bell.
Old 11-13-2015, 05:18 PM
  #182
combatpigg
combatpigg's Avatar
I am surprised that nobody has duplicated Whitehead's machine to prove that it was capable of controlled flight before the Wright Brothers in 1903.
Old 11-13-2015, 06:45 PM
  #183
mgnostic
mgnostic's Avatar
At least according to the internet there have been replicas including at least one that has flown but not with an original type power plant. In terms of early flight there were individuals who had flyable gliders and it was the power plant that made the difference. Even the Wrights engine in the flyer was just barely light and powerful enough to get the job done. Without Charlie Taylor the Wrights might not have flown as early as they did.
Old 11-13-2015, 07:14 PM
  #184
Tom Nied
Tom Nied's Avatar
How about about an early motorcycle engine? Glen Curtiss?
Old 11-17-2015, 04:06 AM
  #185
g-rock
g-rock's Avatar
combatpigg,
Have you thought about using timing belts, helicopter models having been using them for years. I have even seen timing belts used on a Cox .049 TD successfully back in the seventy's.
Gene
Old 11-17-2015, 09:14 AM
  #186
combatpigg
combatpigg's Avatar
Gene, I did a few general searches for toy helicopter parts, sewing machine parts, turntables, but didn't come up with any useful help or info. In most cases the best I could find was a part in an exploded view with no dimensions and a fairly high price tag. So I gave up.
The O-ring system might work better if I go with less tension and idler pulleys to help stabilize the belts at higher rpm. I think it'll work "as is" if I find the correct props and get the airframe set up better for low speed control.
Old 11-17-2015, 12:36 PM
  #187
g-rock
g-rock's Avatar
Combatpig,
I believe that SDP, http://www.sdp-si.com/ has everything that you will need. Look at (timing belts) .080 (MXL) and .0816 (40 D.P.) they start at 1/8" wide. Even current helicopters that have a belt driven tail rotor, use this size timing belt. I was using this size belt on my machines back in 1970 and they were purchased from SDP. When used directly on the engine, a flywheel is required.
Gene Rock
Old 11-17-2015, 01:36 PM
  #188
MJD
MJD's Avatar
See post #73!
http://www.rcuniverse.com/forum/1-2-...l#post12109007
Old 11-17-2015, 02:46 PM
  #189
rcguy59
My Feedback: (8)
rcguy59's Avatar
Wasn't the Sopwith Cameltoe covered with Spandex instead of linen?
Old 11-17-2015, 03:04 PM
  #190
combatpigg
combatpigg's Avatar
Gene [and MJD], thanks for the link to that supplier and the recommendation for which belt system to use...!
If all else fails, I'll have to scrap the system I built and try this.
Besides cost, the first thing I wonder about is how bulky a twin / divided / siamesed cogged pulley with integral spinner cone will be at the engine. I need to draw a side view of that.
If what I built [so far] wasn't working at all with no promising results I would have scrapped it after the first attempt failed. I've got enough invested in this 2nd attempt [not a lot, but enough] to keep me from scrapping it just yet.
I've got to get the current airframe in the air and get the major kinks worked out. I might as well use a single engine that weighs about the same as the .049 powerplant and clear that hurdle first.
I just received a couple different props to try with the .049 powerplant and will see how much thrust they produce. I've got an assortment of spare O-rings and will experiment with less tension and a floating idler pulley for each belt.
The .049 that I fitted with a front bearing isn't doing so well. I had to undercut the front of the shaft to slide into the bearing. The cut takes the shaft O.D. even with the rut that Cox has near the end of the shaft, so I hoped it wouldn't weaken the shaft too much. I was wrong.
It hasn't broken but it has a wobble. Cox left that extra nub of load bearing steel at the end of the shaft for a good reason I suppose.
Old 03-16-2016, 08:02 PM
  #191
Pond Skipper
https://www.youtube.com/watch?v=eWBuO9RVwV4 Nice use of a dolly for launch although elect...
Old 03-16-2016, 08:05 PM
  #192
Pond Skipper
https://www.youtube.com/watch?v=ADhr-HyGZxk Awesome Sauce
https://www.youtube.com/watch?v=MyzIzG2Na1o More Sauce
Old 03-19-2016, 11:10 AM
  #193
combatpigg
combatpigg's Avatar
Yes..!
He sure didn't need that dolly, but it's useful to see a dolly in action.
There's another video out there of a twin electric WFer just jumping out of the pilot's hand. By all rights, if the first few moments after launch can be done cleanly without any overcontrol / stalls, these planes should be able to lumber skyward with 12 ozs of thrust.
Old 03-19-2016, 01:11 PM
  #194
Pond Skipper
The second vid the guy did some slight design changes to insure solid control and it worked great
the plane turns on a dime with a mix of wing warp and his added trick. Attention to all scale components
for the size of the plane was quite some doing.
The first one took months of trial and error or timid attempts finally in the end the big beast flew.
