Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
New Krill Spark Evo I- Build Thread.....
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 02-20-2011, 12:46 PM
  #126
lyka
lyka's Avatar
Default RE: New Krill Spark Evo I- Build Thread.....
In action.... ( Spanish Version)...coming soon in English version ( is in the oven )
[youtube]http://www.youtube.com/watch?v=-G3hmBa1ZsI[/youtube]
ENGLISH ( sub-titled ) ready !!!!
[youtube]http://www.youtube.com/watch?v=JouIZ9y92mM[/youtube]
Old 02-22-2011, 07:49 PM
  #127
flyboy91
Tonight my Spark Evo took to the sky!!!!
It was not a very good day to fly as the winds were high and the sky was very dark but I had to fly my spark to get it in the air.
My setup is as follows
Hacker C50-14XL
Castle Ice 80HV Lite
Thunder Power 10s5000 Pro Lites
Futaba BLS551 Aileron servos
Futaba BLS651 Elevator Servos
Futaba BLS352 Rudder Servo
Thunder Power 2s730 mah receiver pack
Castle BEC for switch, until I get my Digiswitch in.
Falcon 21x14 carbon prop
Final weight was 4.75 Kilos RTF.
The model flew extremely well with very little trim needed. The wing incidence is already set for you and I was worried about not enough positive in the wing and I was wrong. After trimming the model I was able to tell the model was flying with a nice fuse angle and not tail low that I was worried about.
I started to run the plane through the sequences and notice that I needed to increase my aileron throw to achieve the snaps I was looking for. After a bit of playing around with this I was pretty happy with the setup I have. I have to add a bit of down thrust to my model as it pulls ever so slightly to the canopy on a long upline. I will do that tonight and try and get out and fly tomorrow as well.
The elevator authority is great on the model, seems to be really happy even in the bumpy conditions we had tonight. Rudder authority is amazing!! It feels great for stall turns and all other rudder demanding maneuvers( Figure M in P sequence). I have cut the expo down from -60 on the Spark Dynamic to -45 on the Evo.
More news to follow.
I must thank Darin Pierce a ton for finishing off the airplane for me. I was sent to Yuma to do some testing for the Army and could not finish the airplane off and Darin offered to put the plane together for me. I returned home Sunday night and went to his house Monday night and finished it off. Thanks Darin!!!
Andrew
ID:	1568503   Click image for larger version
Old 02-23-2011, 07:44 AM
  #128
dlpeirce
My Feedback: (10)
Andrew,
You are very welcome, I was glad to help. Congratulations on the new plane! It looks awesome!
Darin
Old 02-24-2011, 11:30 AM
  #129
kochj
Andrew, Any chance getting a gas version in your color scheme?
Old 02-24-2011, 06:33 PM
  #130
flyboy91
kochj,
I will check with Krill about the progess of the Glow Spark Version. Once I hear from you I'll let you know. As far as my color scheme I will check with him as well. I know he did this for someone else.
Andrew
Old 02-25-2011, 10:29 AM
  #131
kochj
Thankyou.... It appears that Chief aircraft has the glow version instock??
Old 02-25-2011, 01:06 PM
  #132
woodie
woodie's Avatar
Looking good so far!!! Has anyone actually measured the incidence and thrust setup on the plane as it comes from the factory? If so, would you mind sharing with us?
Woodie
Team Acme LG
Old 02-26-2011, 12:52 PM
  #133
joenella
ORIGINAL: kochj
I do not think anybody have the EVO for glow instock As Ivo told me yesterday, he will soon be ready with this version.
Old 03-01-2011, 02:27 PM
  #134
flyboy91
Last night I was able to get 3 more flights on the Spark Evo after work and I must say its a pretty awesome airplane. I have found the CG I like which is 215mm back from the leading edge of the wing, or about 8.5" back. This seems to be a perfect spot to for zero coupling and good authority of the airplane. I have messed with the throws for good snaps and found them to be 24 degrees of ailerons, 12 degrees of elevator, and 24 degrees of rudder. I am getting more and more comfortable with this airplane that the other spark dynamic has been left at the house!!
Here are a few pictures of the airplane.
Andrew
ID:	1571851   Click image for larger version
Old 03-14-2011, 11:46 AM
  #135
joenella
Distance from bottom rudder to rudder horn? Like the dynamic 150 mm up?
Old 03-14-2011, 12:00 PM
  #136
flyboy91
When I get home I'll measure that for you and will let you know.
Andrew
Old 03-14-2011, 12:38 PM
  #137
Spark09
Spark09's Avatar
Noticed that the wooden block for the rudderhorns in the rudder are very small, becarefull and meassure exactly like Andrew says.
The rudder is very thin and if you are off the balsa block you are screwed..
I meassured between 150/160mm from the bottom of the rudder.
Old 03-14-2011, 11:18 PM
  #138
joenella
Look here
No wonder why it has been difficult
Old 03-15-2011, 03:11 AM
  #139
Spark09
Spark09's Avatar
Strange place for the rudderhorns..
Had not seen this picture before.
I looked at Jonathans and Andrews plane
Old 03-15-2011, 03:32 PM
  #140
lyka
lyka's Avatar
About these questions, our set-up...
cheers...
File Type: pdf
Old 03-27-2011, 08:00 PM
  #141
joenella
No right hand thrust build in?
Old 03-27-2011, 08:10 PM
  #142
flyboy91
There is about 1 degree of right thrust in there. I run about another 1 degree of right thrust in there.
Andrew
Old 03-30-2011, 04:08 AM
  #143
urs k.
andrew, could you report about the behavior of the bls651?( its said they are for cars)
thx
Old 03-30-2011, 05:50 AM
  #144
rcpattern
My Feedback: (45)
The car servos work great on electric planes. On glow they tend to wear a little faster, but on electric they work really well.
Arch
Old 03-30-2011, 07:52 AM
  #145
urs k.
hi arch, thx a lot.
thats really excellent news!
i run all my planes with bls, i do love them, bls 152, 153, 351, 451.....but the bls 153 was a very painful experiance. the gear breaks very quickly...not a single case, i have 20 pieces of them and they all failed. costed endless money, nerves and a few planes! they were used in planes in wich normaly a hitec 5085 is enough.
well, i am happy i can replace them with the 651 (metal gears).
another question, sorry, a little offtopic,is it possible to put the metal gear from the 651 into 153?
Old 04-10-2011, 08:13 PM
  #146
joenella
Yeeesss !! Maiden my EVO yesterday. As reported earlier it is very sensitiv on the rudder especially around center point.
Old 05-24-2011, 07:16 AM
  #147
Daveeast
Its very quite here, is there alot of trimming going on, whats the verdict?
Old 05-24-2011, 10:52 AM
  #148
Spark09
Spark09's Avatar
Hello Dave,
I have about 90 flights with my Evo and I must say that it is one of the best flying planes out there.
Cause of the smaller ailerons compared to the older Spark it snaps a little less then the older Spark but with full aileron and a 38mm horn it does the trick.
Flying is much smoother en precise, integrated figures like rolling loops are much easier.
Also the rudder feeling is much improved with the curve shaped rudder.
Current setup:
Hacker C50-14XL
Schulze 32.80KA
Mezlik 21x13E
Hyperion 25C 5000 10S packs
JR8811 on rudder
JR3328 on elevator
JR8231 on ailerons
Using around 40% expo on ailerons and elevator and about 80% on the rudder.
Differential is -24% for perfect rolls.
Flightbattery is just behind the landing gear as I like the c.g a little backwards, pretty much the same as the older Spark.
Last week I mounted a big Axiome like canalizer on the canopy and it seems that the plane flies better with strong winds, less shakey.
Currently setting up different flightmodes for snaprolls, spin and stallturn..
Cheers,
Roy
Old 05-24-2011, 01:32 PM
  #149
Daveeast
Roy
Nice, good to get some feed back.
Good Luck over the weekend will see you Saturday.
Cheers Dave
Old 05-24-2011, 01:43 PM
  #150
Spark09
Spark09's Avatar
We will be there with the 2 new biplanes..
We leave Thursday afternoon and arrive in the evening.
Looking forward to the contest, hope the weather will be nice
