Anyone own a Ofna Ultra LX1??
#151
RE: Anyone own a Ofna Ultra LX1??
ORIGINAL: oldtown72
Does anyone thread lock those engine mount bolts? I took mine off once and it was a pain in the *****. i can't imagine having to go through that everytime I want to clean the engine. I just use a lot of Nitroclean and clean it on the chassis most of the time.
#152
Something tells me mine won't vibrate loose. They're soooo tight.
I've threadlocked the other bolts though, all the diff ones.
I'm using the Tamiya blue stuff too, although the tube keeps leaking.
Wish the weather would pick up over here, its just been so wet recently.
#153
TX
Stock Ofna (HONG NOR) engine mount screws are VERY TIGHT and have A LOT of thread lock applied. If you need to, cut a slot in them and remove em with a flatblade screwdriver. I always have a spare set on hand.
Once you have them out, regular threadlock applied normally will be perfect. I've never had the same problems removing the screws from my Jammin or my son's LX AFTER getting the screws removed the 1st time.
Never run with out without threadlock on these screws because they can shift under load and vibration.
#154
AZ
ORIGINAL: Dokioto
Haha.. Just snowed 10 inches today[:'(]
ORIGINAL: alaskaN8
i am at the same place as you dokioto, i know anchorage is way warmer but i still don't want o break mine in in the cold, i did it with my savage and it sucked. on a side note though the engine didn't overheat
#155
VA
Hey everyone. Well I just got me a OFNA LXComp and didn't even think I was gonna be walking home with 2 extra R/C Vehicles. Well I got this thing basically for 15 bucks and about 8 hours of work. Friend told me if I could fix his E-Maxx I can have the buggy. I said NP! Well got home and started playing with it. First off it sounded like the one way bearing was bad. Than when it was running it wouldn't last. I'm thinking that it was a air leak I found after I was done playing with it. Is there anything I should know about this buggy? Is it a race buggy? A bash buggy? Also what is the stock settings? Like for the HSN and the LSD? This is my first R/C other than a MT and mini's. I'm excited cause this thing is HUGE!!! Is there more than 1 lx? For example the topic says LX1. Is there a LX2? How do you identify it? Heres some pictures of it. Sorry its so dirty. I have been working on the E-Maxx since I got home. He wants it done by tomorrow...
#156
thay are pretty much the same the lx1 is an updated verson of your buggy. dif. shocks,engine,and c hub suspension but as far as chassis lay out thay are the same
#157
VA
ORIGINAL: rshooch
#158
ORIGINAL: jtnktz
So I have the low model? Bummer.
ORIGINAL: rshooch
#159
TX
ORIGINAL: jtnktz
And yes there are many Models of the LX. The LX1 oddly enough is the newest.
There is also a Ultra Worlds,Ultra MBX, Ultra MBX comp, Ultra LX, Ultra LX Comp, and a Ultra LX Comp 2. The basic design goes back about 10 years.
It appears that you have a Ultra LX Comp 2 which was the model immediatly before the LX1 (yes 2 was before 1, go figure).
How do you identify?? Ultra Lx comp 2 has the laydown steering servo which is the biggest givaway. That it's a 2 instead of an earlier model.
#160
VA
ORIGINAL: Paradoxmaker
Pretty sure you Have a Force 26 on that buggy so here are the baselines for you.
ORIGINAL: jtnktz
#161
TX
ORIGINAL: jtnktz
This is exactly what I was looking for. Just a question do I lean the HSN or richen it from flush? The HSN doesn't lean 2 turns from flush
You lean the HSN (screw it in) from flush.
If the HSN is FLUSH with the top of it's housing it will screw in (lean) about 5-6 turns, so if you can't lean it 2 turns from flush you either have it set wrong or someting is wrong with the carb.
Also on the Force 26 I know that the baseline for the LSN is set flush to the housing, but in my experiance that makes the engine very rich on the low end. I run mine 1/4 to 1 turn in from flush.
#162
VA
Not exactly sure how to answer that one...
ORIGINAL: jtnktz
#163
TX
ORIGINAL: jtnktz
Great....It basically stops at flush... AHHH
ORIGINAL: jtnktz
No no no no no, look back at the pic i posted.
Look at the housing that the screws are in. The needle is considered FLUSH when the head of the needle screw is flat even with the top edge of the housing.
If the screw stops you are bottomed out in the housing and you WILL DAMAGE THE SCREW AND/OR THE SEAT if you try to force it further in.
if you look back at that pic it shows the LSN "B" flush and the HSN "A" is probably about 1.5 - 2 turns in from lean (judging that the screw is NOT flush with the top)
#164
TX
ORIGINAL: jtnktz
Great....It basically stops at flush... The carburetor HSN looks funky... It looks smaller than the one in the picture. Now that I look at it...it looks like he cut it off or broke it off...Can anyone tell me how many turns from all the way leaned out is flush for you guys? So I can use that as a template...
#165
VA
Well if it was cut off or broken that all bets are off as to what the settings will be...
ORIGINAL: jtnktz
#166
TX
ORIGINAL: jtnktzAnyone know where I can get a replacement? Not a full carb but just that part... (The metal part that encloses the HSN) Does it look short to you guys? Or is it just me?
You can get replacment parts from www.nitrohouse.com
http://www.nitrohouse.com/eng_parts_ofna_force_26.htm
52259 Main Needle Assembly 12.71
#168
TX
ORIGINAL: jaws1
paradoxmaker is really the expert on the ofna/hong nor ultras, glad to have you here and ofna forum
I don't know about being called an expert, but you do learn a lot by breaking em
#169
VA
ORIGINAL: jaws1
#170
TX
ORIGINAL: jtnktz
Till I get more cash can someone tell me how many turns you richen the HSN from the bottom?
#171
AZ
I think my .28 is 2.5 turnes out from bottom. I don't think our engines are the same though.
Has anyone built a ramp yet? I'm in the middle of building mine. I went to MisbehavenRc and got specs for one. I'll take some pics when I'm done for you guys.
#172
NY
Hi I just got my first lx 1 , I love this thing looks vary strong. I do have a few questions, to put diff oil in it do you have to take the hole buggy apart ? The other is if I use a bump
box and replace the pull start with a backer plate, is there a 1 peace motor mount I can BUY, hate haveing to re mess gears every time. This is my winter project and I can't wait for sping sick of looken at all this snow ! And the wife keeps telling me dont you start that thing in my house but she did let me display it on the liveing room !!! lmao
Cant wait to pipe this thing and change up the gearing a little bit , go or blow and the smell of nitro !!!
#173
TX
ORIGINAL: d800
box and replace the pull start with a backer plate, is there a 1 peace motor mount I can BUY, hate having to re mess gears every time. This is my winter project and I can't wait for spring sick of looken at all this snow ! And the wife keeps telling me don't you start that thing in my house but she did let me display it on the living room !!! lmao
For the front and the rears you can get away with removing just half of the tranny case. Remove the 4 rearmost screws (2 4mm ones and 2 3mm ones) tranny on the underside of the chassis, remove the shocks, remove the swaybar, remove the arm pin holder, and then remove the 4 screws at teh top of the tranny case that hold the half's together...... You can leave the arms and hinge pins in place and pull the tranny out of the case.
For the center, start with removing the throttle/brake servo horn from the servo and the carb (leave it attached to the brakes). Remove the 4 screws that hold the mount to the chassis and then pull the entire tranny off the chassis. Then remove the 4 screws that hold the upper plate on, after that you can remove the tranny from between the mounts. Make sure you pay attention to which driveshaft belongs to the front and the back.
The hardest parts about putting it back together is getting the driveshafts back in right and making sure you remember to put the brake disks back on when you re-assemble.
On to the rest
The Jammin 1 piece mount will fit the chassis but since some motors are shaped differently than others, it may not work. It will let an engine sit lower on the chassis and since there is no relief cut into the chassis under the motor, some may hit the chassis and not mount correctly. BTW even with a 1 piece mount you will have to reset the mesh everytime you remove the engine.
#174
NY
Thank you vary much for all the info sounds like a big job. But thats why I picked nitro as a new hobby I like to tinker and fix stuff. And if I mess it up to bad it didnt cost me 600 bucks to learn. Onec again thanks for the info and taken the time out of your day to help.
#175
sure now some posts on a easy way to change the diff oils lol good thing i started in the back and not the front and figuered it out but it is really easy.
i got a question though what does ofna use on the pinion screws cause what ever it is it on the yolk and i can't get it off. just pry really hard?
