Reload this Page >
Comp ARF BAE Hawk build thread
Old 02-05-2017, 06:23 AM
  #2176
Dave Wilshere
I started this project a long time ago, well its finally finished. In the end I farmed some of the work to our ace Hawk builder Roger M, who did the cockpit for me and installed the air valves, plus Rx stuff so I could finish other models I had on at the time. The need for this EDF Hawk came from our local grass club where turbines can't be flown Mon-Fri. The owner has a turbine version with a P-140Rxi in it that matches (Also we are just finishing a SG Hawk for the same customer) all three are 2010 scheme. This one has a Schubeler DS94HST running 14s 10,000 Mah Thunderpower 70c cells. There are four 7s 5000 packs running parallel/series. One of the delays has been battery mounting, i expected the cells to sit in the rear of the cockpit, but it came out really nose heavy, so they have to sit on top of the wing. I eventually came up with a sliding tray. I'll do more detailed pictures when I have more time. Test flights soon!
ID:	2199728   Click image for larger version
ID:	2199729   Click image for larger version
ID:	2199730   Click image for larger version
ID:	2199731   Click image for larger version
ID:	2199732   Click image for larger version
Old 02-05-2017, 07:17 AM
  #2177
afterburner
My Feedback: (18)
afterburner's Avatar
Cool project Dave. Looking forward to flight video. What's the AUW?
Old 02-05-2017, 07:48 AM
  #2178
Dave Wilshere
Need to weight it, but the packs weigh 3932g (8.65lb!) So a little more than a tank of kero...but this does not get lighter as the flight continues. I think even with the scale gear we used on this one, the OA weight will be less than a fueled turbine version.
ID:	2199746   Click image for larger version
Old 02-05-2017, 08:41 AM
  #2179
DUCMOZ
Nice project Dave. please post a Video once it is flying.
Thnaks, Behzad
Old 02-05-2017, 08:57 AM
  #2180
Dave Wilshere
Will do.
Less flight packs its 24.6lb.
Old 02-05-2017, 09:04 AM
  #2181
Dave Wilshere
Ran the whole set up wing on and 10,000mAh today for the first time, thrust feels OK (should be around 24lb) did a 2 minute take-off, cruise, landing run on the power and ground temps are much lower than I expected.
ID:	2199752   Click image for larger version
Old 02-06-2017, 12:24 AM
  #2182
jjantti
Very interresting! Owning two airframes and having long history with EDF's... Flight video is a must see item
/Jyri
Old 02-08-2017, 08:21 AM
  #2183
Dave Wilshere
Looking back through a camera card I found these from 2016
ID:	2200250   Click image for larger version
ID:	2200251   Click image for larger version
ID:	2200252   Click image for larger version
ID:	2200253   Click image for larger version
Old 02-08-2017, 11:03 AM
  #2184
karl hibbs
karl hibbs's Avatar
Default one of one
I took some liberty with this paint scheme, a little more color.
Old 02-08-2017, 01:46 PM
  #2185
Dave Wilshere
Looks like a good paint job. Quite like the scheme
Old 02-09-2017, 06:46 AM
  #2186
izzy
that's a great color scheme
hope CARF adopt it for future
Old 02-09-2017, 12:26 PM
  #2187
karl hibbs
karl hibbs's Avatar
Default fly by
thanks
Old 02-10-2017, 08:15 AM
  #2188
Dave Wilshere
Did the very last job on the EDF Hawk today, had the stop the batteries sliding forward on the tray and wanted no tools. So a spare 5.5mm bullet plugs in through a hole in the plate. The black pull cord is a section of 8swg wire with a red 'visual' cap on the end.
Sadly winter is well and truly back in the UK this weekend so no test flight :-(
ID:	2200448   Click image for larger version
Old 02-10-2017, 02:55 PM
  #2189
erh7771
My Feedback: (30)
Hey Dave,
REALLY nice EDF setup !!
Mine came in at 28lbs AUW with a RAMTEC 11 blade ran it on 12s 10,000 mah packs single packs (6.6lbs) and it still was a floater on landings even when nose heavy...had to play with CG to get better landings.
QUESTION: What's your peak amps with everything buttoned up?
Thx in advance for any input
Old 02-11-2017, 05:24 AM
  #2190
Dave Wilshere
Nice and light, this has all the scale bits, but I'm a firm believer in energy verses drag and I think this will work well at 33lb
I'm 180.5A and 50.1V (14s) after 30s static. The small inlets won't help either, but once its rolling it will be fine.
Dave
Old 02-18-2017, 12:25 PM
  #2191
Dave Wilshere
OK, had three flights with it today, this is the second flight, still working up on the packs, it looks like we are going to end up around 7 minutes, but its early days.
https://youtu.be/2hxKdwCMC2g
Landing at 33lb is not causing an issue, it was fairly calm, cool and a bit misty today, not ideal for EDF! Packs were not as warm as I'd like before we start...but summer is coming :-) I slowed it up a little more on the third flight and it was still showing no sign of a wing breaking away.
Old 02-18-2017, 12:46 PM
  #2192
afterburner
My Feedback: (18)
Nice Dave!
Old 02-18-2017, 05:28 PM
  #2193
DUCMOZ
Looks good Dave. It looked liked it took off easy enough.
Behzad
Old 02-19-2017, 05:57 AM
  #2194
Dave Wilshere
Yes, its now rotating at about 70m, I increased the flap after the first flight, it used all 90m of the main strip.
Once we get the cells bedded we can see what we really have.
Think back not that long and a Hawk with small unducted inlets would not have been possible.
I'll do a thread on some of the mods required
Dave
Old 04-03-2017, 11:54 PM
  #2195
Didier
Awesome take-off with the maingear still on the ground during rotate on the electric Dave!
I am about to fly the fly my new Hawk with the "sports gear" very soon.
I already read in this thread about the soft springs on mains but didn't read about the o-rings brakes.
It looks to me there is not much breaking power, even with 9 bar (130 PSI) of pressure. It is not hard to turn the wheels with brakes on.
Anyone has any suggestions or normal system behavior?
Thanks!
Old 04-04-2017, 12:02 AM
  #2196
Dave Wilshere
Something odd, mine uses 60psi to lock the wheel.
You greased the hubs or not?
No kinked lines?
Dave
Old 04-04-2017, 12:46 AM
  #2197
Didier
No kinked lines?
Dave
I bought the Hawk almost new (only 10 flights), so I don't know how the wheels where assembled.
I think it is not a kinked line, as brake reacts instantly.
So it is NOT normal system behavior, hmmm. What do you suggest? Clean the brakes including the o-ring?
I don't have any experience with o-ring brakes as I always used Jet-1A.
Thanks!
Old 04-04-2017, 01:42 AM
  #2198
Dave Wilshere
OK, what brake valve does it have? Pulsing or solid on off?
Yes, take the wheels apart and see if the surface is greased.
Dave
Old 04-04-2017, 07:05 AM
  #2199
jjantti
Not braking with 9bar sounds strange. Last summer I used 3bar with pulsating valve and still managed to get small flats on the tires. Is the o-ring hard as glass? Actually this wouldn't be bad at all if controllable and symmetrical
btw. My new Hawk is ready for maiden. AUW 11,7kg with just CAT fuelled. Full lights and smoke system on board. Didn't even try to make it light weight... This is to be trainer for the another one and it is heavier with scale gear and all the details. Some 70g of lead on the nose...
/Jyri
Old 04-04-2017, 07:14 AM
  #2200
Didier
Dave
It has a electronic Evojet valve. I have it on a switch. It go's from pulsating to 100% with a delay of 1,5 seconds.
I'm happy I asked, so it is not normal behavior. I will check the o-rings and clean them. I guess no lub is required. ;-)
