- carbon fiber re-enforcing
- Carbon tuned pipes...how?
- Drilling and Painting Carbon Fiber Landing Gear
- leaks?
- Wanted: large diameter carbon tube
- what is best, polyester or epoxy molds for epoxy molding?
- Measureing ?
- Need some help and Got some ?'s
- Polyurathane and CF and glass
- Carbon Fiber Hazard
- carbon fiber box
- Need advice... Fiberglass or Silkspan?
- Fiberglass cowl repairs. How to fill in holes?
- Carbon Rod vs. Tube
- epoxy dispensing help
- Epoxy - safety gloves
- Need help on West System 206,209
- Joining wing halves
- fuel proof epoxy?
- Alternative for Peel Ply?
- c.f. sheet for removable "tank tray"
- Model Magic
- Epoxy question
- glass wings w/o ribs
- Poly fuse, bonding formers in place with epoxy?
- Mold Flange for Vacuum bagging
- What Wight Cloth And How Many Layers?
- Vac Form Materials
- fixing crashed Edge 540T
- Will this work?
- Space saver bag & ShopVac ??
- Seal Balsa before applying epoxy ?
- Help needed, making a carbon spinner
- Any good books on fiberglassing a plane?
- Fiberglass and cyno
- What sized rods for pushrods?
- Gel Coat vs. Fiberglass layups
- FiberGlass layup (female mold)
- Epoxy Resin Types
- laminated kevlar/cf
- Fuselage repair
- Wood Plug - Need help
- Fiberglassing question
- Carbon fibre rod, where to buy
- Epoxy cartridge with mix nozzle
- fuel proof paints
- carbon fiber propellers
- Glue for foam floats?
- vacuum bag with skins & shucks in bag?
- vacuum ports
- removing foam within fiberglass
- Vacuum Guage
- carbon shear web
- hinges
- Wing Ribs.
- Carbon Fiber Spinners, Will this work?
- How long in the vacuum bag ?
- Alternative to MGS epoxy...
- question about fuselage layups
- How can I apply thin layer of gelcoat?
- Is a fiberglass cowl lighter than ABS?
- I need a good price on EPP foam?
- Tooling gelcoat or Epoxy with graphite?
- Removing monokote from balsa, help!
- How to join a two piece fiberglass cowl
- Nylon vs. plastic bolts
- My question
- Pro Bond And Fiberglass
- Why CA on CF Spar Caps?
- How to build a vacuum bagger?
- vacuum bagging equipments
- Thinning down epoxy
- fiberglass cowl for Ultimate Bipe
- Bubbles in tooling layer of Mold
- vacuum box plans?
- Carbon fiber supply
- fiberslass fusealage
- how do I make a bow to cut foam ?
- CA Glue
- Anyone good with carbon fiber (broken boom on Skywave - pic)
- Prepeg
- epoxy running
- vacuum bagging questions
- Debonding Epoxy
- CF gear for CG Ultimate
- A Source For Kevlar
- Kevlar Has It's Place
- sealing balsa skins with hairspray before applying epoxy
- Bonding, adhesives etc
- Need Landing gear for Goldberg Extra 300
- How to repair carbon fiber landing gear?
- Racers Skin....
- Lost foam mothod
- Carbon / Kevlar Fuselage - Need Advice
- carbon fiber fuse
- Building spar for sailplane
- Spar strength
- wax solution
- balsa/carbon composite
- wingtip help
- polyester goo...why....how to stop
- V-Tail Parting Plane
- 205 epoxy cure time
- composite landing gear
- Wing Tip Molds
- Looking For A Good Fiberglass Cyano?
- How do I remove cured fiberglass?
- Boat molds
- Will epoxy be weaker if worked too long?
- Epoxy Resin has pin holes
- What does "tooling" mean in the world of composites ?
- Fiberglass Car Bodies
- laminating balsa help?
- Yet another Foam Wing Sheeting question...
- location of vacuum bag connector
- .5" OD CF tube
- Fuselage Wanted
- Anyone know anything about building composit landing gear?
- Breather Cloth
- Kadet Senior Cowl
- Composites book?
- 1.9 oz kevlar strong enough!
- What would you pay??
- Vaseline
- Smart Composites
- foam or ? profile carbon fuse ?
- Cheap DIY vacuum bagging system
- Heat Curing Parts
- Composites/questions and answers
- Making cut outs for Wheel wells in Foam wings neatly
- Min-wax Paste Wax
- Carbon Wing spars ??
- MGS 285 mixing
- Looking for a source of Nickel chrome wire
- Lost foam wing construction technique?
- Foam for wings Any good links?
- Covering with GFK
- Special CFK/Kevlar
- Fine Weave Carbon Fiber
- Z poxy will not dray
- Canopy attachment/glazing putty
- Fiberglass repair?
- New to fibreglassing
- Fiberglass cowl layup
- Tinting canopy dark
- Vacuum Bag Joining
- Pull-Pull Question
- The Lancair project
- Parting Board Material
- Polish for Canopies
- ARF repair
- Glassing The Fuse?
- check this out
- I want to make a...
- Tinting the canopy?
- Epoxy Volatility
- Fiberglass Engine Cover Req'd
- Carbon Fiber
- vaccum bagging
- Needed 1/2" OD tube
- 2 more layers of FG on Cured Polyester
- What materials are needed to build a mold and vacuum bag it?
- Why epoxy over polyester resins?
- PVA color
- Syntex
- Canopies
- Needed CNC alunimum producer
- Where do you buy your CF rod from??
- Hatch Fitting Problem
- F3J hinge wing
- Glass tooling plates
- Where to buy CF pieces?
- I need urgent help !!!
- Tekoa Roto-Cut
- how to cut foam core Leading edge
- HELP Plug from Plastalina?
- Need some inspiration?
- Which Brand of Resin Should I use?
- carbon fiber strip adhesion question
- Fibrelease
- Alumilite as mold material?
- A Good Book/guide For Working With Composite/fg For Begginers
- What is Z-poxy and where can you fget it ????
- shelf life of epoxy
- Anyone remember HobbyPoxy Formula 3 Thixotropic Epoxy??
- A little different glass landing gear?
- Source for Carbon/End Grain Balsa Sandwich
- Monocote over a Plug
- How to make a composite wing
- Question on how to repair (Pics)
- Trimming fiberglass cowlings
- Hollow compsite wing - aileron hinges
- Aluminum Mold for Carbon Gear
- plug & mold help ?
- Purchasing Kevlar cord
- Covering a crummy foam plug
- Wing Mold
- color pigment for epoxy gelcoat
- sources for foam
- CF Spinner
- How do you cut endgrain laminate?
- homemade prepreg
- Need some tips for building a foam/glass wing for club pylon racer. r
- Fiberglass Cowls
- IL-2 STURMOVIK -Composite molding
- Plug construction time
- West epoxy cure time
- Carbon Fiber Matting
- What weight of CF for pull-pull servo tray?
- How can I get a mirror-like finish on my mold?
- Glassing Advise
- Carbon Fiber Bulkheads and Radio Interference
- Cutting F/G cowl
- Composite F4U hollow wing
- Vacuum bagging a cavity mold
- 2 part urethane foam
- Can't do vacuum bagging right - need advices
- If wax or PVA alone is fine, why both ?
- Composite shell wing construction question.
- Pva
- Gelcoat ?
- Good prices on Carbon, Kevlar, etc.
- Waxing the plug
- applying PVA over waxed mold surface ? It doesn't work
- Some Plugs
- Peel Ply
- Curing oven for sale
- Molding needs
- Air Bags
- Carnauba Wax & Partall #2
- carbon fiber
- 1/4 graphite composite firewall for gas engine?
- Laminating lite-ply w/carbon fiber cloth
- Pannel Lines
- Fiberglass Cowls
- "Post curing" What is it? How is it done?
- Source for composite honeycomb material
- vac baggers please respond
- Repairing a fiberglass cowl?
- Composite 109F/G Spinner
- What material is trampolene matt made from?
- Cowling
- close this post
- Removal Of Excess Epoxy
- Excess Epoxy
- How do you use PVA?
- Has anybody used Release All Safelease-#20L
- Glass is STUCK to the CFK
- Making Carbon Fiber Props
