 Capiche 140 EX and IC version >
Old 01-24-2005 | 02:03 PM
  #2576
Default RE: Capiche 140
I think that is more about propellor/rpm/torque than air flow..
Old 01-25-2005 | 01:13 PM
  #2577
Berk's Avatar
Oooh.. I built a whole aileron last night... i'm on the last one tonight. LE chamfers done already, so just need to stick em on!!
Light at end of Tunnell!!
Regards,
Steve
Old 01-26-2005 | 07:37 PM
  #2578
Berk's Avatar
All building done!
Will attack the wings with the compressor before covering....
Regards,
Steve
Old 01-27-2005 | 06:22 AM
  #2579
Sprink's Avatar
ORIGINAL: Berk
All building done!
Regards,
Steve
Why, whats wrong with the airofoil?
Old 01-29-2005 | 03:32 PM
  #2580
Berk's Avatar
Well, I thought i'd asked all the questions!!
I now have the hinges to do... any knack of being able to control where the cyano goes using the hinges? I don't want to spoil the covering job!!
I'm clumsy at the best of times, and a test with one of the cyano hinges, using that pacer hinge glue pulls wood out before anything fails, so I might just use that!!
Anyone want to sound alarm bells?
Regards,
Steve
Old 01-29-2005 | 05:21 PM
  #2581
mikey-3d's Avatar
if your using the i h hinges then just use thin cyano and let it soak in, only use little runs at a time and you can see the hinge soak it up.
Old 01-29-2005 | 05:24 PM
  #2582
Berk's Avatar
Mikey,
That I understand.. but is there any fool proof way so I don't get cyano everywhere??!!!
Regards,
Steve
Old 01-30-2005 | 04:58 AM
  #2583
Ian.W's Avatar
use one of those extenders for the top of the bottle. this will give a much more precise placing of were you want the cyno so it doent go everywere and make the covering horrible
Old 01-30-2005 | 09:36 AM
  #2584
Luke 3D returns's Avatar
Yep eddys bang on.
Ran the Ys 160 again today, the thing still wont stop even when the throttle is closed right to the stop. It will hold an idle of 1500 but wont stop![:-]
Having said that i have never seen an engine go so well with only 3/4 of a gallon through it.
Old 01-30-2005 | 11:43 AM
  #2585
The boys Back's Avatar
send it back there is obviously something wrong with it. i have never had a ys that wont stop instantly you hit the cut switch
Old 01-30-2005 | 03:59 PM
  #2586
C140 Brothers's Avatar
what was wrong wid the 140L anyway?
Adam
Old 01-31-2005 | 11:35 AM
  #2587
We just ordered my Hatori pipe shud be here wednesday
Adam
Old 01-31-2005 | 05:03 PM
  #2588
Berk's Avatar
Not long to go now,
Had the YS140 running today, all set up now, soooo easy to do...
Set high end needle midway between too rich and too lean
Set idle needle until fuel stops p1ssing out the carb at idle
Set Regulator to get moderate amounts of smoke during transition (slightly proud )
drops to 2k rpm in an instant. throttle reacts instantly! like an electric motor
richened it up a bit though to be kind to it for the first few flights!
Nearly ready to test fly!
Regards,
Steve
Old 02-03-2005 | 03:19 AM
  #2589
this is my new hatori pipe for my capiche 140, i am going to fit it on in the next couple of weeks.
what do you think?
Adam
Old 02-03-2005 | 04:29 AM
  #2590
Sprink's Avatar
looks like mine
Old 02-03-2005 | 06:05 AM
  #2591
nice kitchen units
Old 02-03-2005 | 01:47 PM
  #2592
The new kitch en is just being fitted
Old 02-06-2005 | 10:23 AM
  #2593
Good news is the Ys problem is solved it now stops fine. Gave me a bit of a shock when the engine visibly coughed(but kept running) once during an inverted elevator with zero airspeed but apart from that its going really well. Lots of punch out from the hover and good downline breaking with the 19x8. With 3/4trs of a gallon through it and the valve springs still to be re-adjusted its turning the 19X8W @ 7500. I think this engine is the perfect choice for this plane. Pattern is effortless and hovering is done at half power even with 40% expo on the throttle.
Old 02-06-2005 | 12:09 PM
  #2594
Rhilluk's Avatar
ORIGINAL: Luke 3D returns
So you do do Pattern then????????????????????????
Old 02-06-2005 | 12:28 PM
  #2595
Well , pattern manuvers.
Old 02-06-2005 | 01:01 PM
  #2596
mikey-3d's Avatar
what was wrong with the motor luke
Old 02-06-2005 | 01:26 PM
  #2597
Theres a screw that stops the throttle from closing completely. It just needed adjusting a little more to allow the carb to completely close.
Old 02-06-2005 | 03:35 PM
  #2598
JIMBO D's Avatar
What! You mean the idle screw that all motors have Luke?Not that anybody uses them nowadays.Glad to hear it is going well now.I was flying a G-trick with a YS 110(that I got off Pete the other day) today and the motor was awesome.I had run four ounces of juice through it on the bench and it fired straight up and gave no problems all day.The owner was well inpressed,Says he's not gonna get any other type of engine now!
Jim
Old 02-07-2005 | 02:24 AM
  #2599
I'm running the YS110 on the Capiche90 - a superb combination. The motor has loads of power, instant throttle response, and is completely reliable. I havent had to touch idle or regulator at all. It hauls the 8lb model effortlessly turning a 16 x 6 apc at 9300.
Old 02-07-2005 | 07:01 PM
  #2600
Berk's Avatar
Nearly there now.....
Just scheme to do on wings, and spray cowl and spats!
Need to get the paint first, but thanks to ColinM and Simon, I know what i'm after!!
Camera ran out of steam after this photo, poor focus sorry
Regards,
Steve
