 U Can Do 3D >
U Can Do 3D
U Can Do 3D
Old 11-26-2002 | 03:12 AM
  #551
DKjens's Avatar
My Feedback: (50)
Default apc16x4W
salmon,
just sent you a pm reg. prop.
DKjens
Old 11-26-2002 | 04:29 PM
  #552
My Feedback: (45)
Default U Can Do 3D
For APC props of any size go to Landing Products at www.apcprop.com and get what you want direct.
Old 11-26-2002 | 04:30 PM
  #553
My Feedback: (45)
Default apc props
You can get any apc prop from Landing Products the manufacturer. Go to www.apcprop.com.
Old 11-26-2002 | 04:47 PM
  #554
Default apc props
apcprop.com sells the 16X4W for $12.95 for the prop that Central Hobbies sells the same for $9.72.
Dale
Old 11-26-2002 | 04:52 PM
  #555
My Feedback: (45)
Default price vs getting what you need
You're right as to price but for availability sometimes you don't have the choice. In this case you do. Thanks to this forum and active modelers we can keep each other informed. Thanks Lou
Old 11-27-2002 | 02:47 AM
  #556
Default U Can Do 3D
not to start a flame war but check with your LHS they can probably get them from ACE....I just order 4 from my LHS got them for 10.95. Don't even have my UCD yet, back ordered ....getting impatient....want to play....
John
Old 11-27-2002 | 03:18 AM
  #557
My Feedback: (45)
Default wing washout
I am putting my UCD together and noticed the wing trailing edge had a noticeable anhedral. When pulling a line across the bottom trailing edge there was a 3/8 inch space at the center. Anyone else notice or have this? I haven't checked with gp to see if this is suppose to be there. Just wondering. Already have the ailerons installed. Plan to go with it. Hope no adverse effects or affects!! Lou
Old 11-27-2002 | 04:39 AM
  #558
Default U Can Do 3D
Hey guys,
I got my UCD a few weeks back, my wing suffered the same fate as allot of yours, I had one crushed rib, I decided to just fix it myself rather than wait. My question is I used Du-Bro pinned hinges rather than the CA hinges as Ive read allot of peoples hinges are cracking on this plane, I didn't want to chance it. I have sealed the bottom of the ailerons, elevators & one side of the rudder. Should I do both sides of all surfaces? I don't plan on flying it fast at all, but those are some mighty large surfaces!! I also put a little more tri-stock on the landing gear block, & am going to try to get a little bit of 30 min. down there also. I peeled back the covering under the tail, added a piece of 1/8 lite ply for a Sullivan tail wheel assy. I didn't trust the one that came with the kit. Anyone have any other suggestions I missed? (took me about three days to read all the post's here!!)
Thanks, Billy
Old 11-27-2002 | 04:53 AM
  #559
cmassa's Avatar
Default U Can Do 3D
Make sure you change your pushrods to 4-40. Others have had the 2-56 rods bend. None of the UCD3D's in my club (4 of them) have the hinge gaps sealed. The gaps are pretty tight though.
One thing we've noticed is that the bottom edge of the wheel pants takes a beating and cracks quickly develop (we're on a paved runway) You may want to put some glass cloth or carbon fiber around the inside edge.
2 of us have switched the cowl mounting screws for 6-32 or 8-32 nylon bolts with tapped holes in the blocks. Haven't come out yet.
Chris
Old 11-27-2002 | 05:19 AM
  #560
DKjens's Avatar
My Feedback: (50)
Default UCD wheelpants
I have a hard time keepingg the wheelpants tight on my UCD. Maybe my YS120SC swinging an apc17x6 puts a few more vibrations through the plane than the 90-91 size engines many use. I do balance my prop, and I don't use a spinner. I have put CA in the screws that goes into the wheelpants/light ply einforcement, but to no avail. I am just removing my wheelpants and saving them for if somebody wants to buy my UCD. I am also doing something else that I have never done before he he, I am removing some of my tail ballast. I've been fling this plane so tail heavy (pitches up good when flying inverted) that the landings can be and often are a bit hard on the plane.
DKjens
Old 11-27-2002 | 06:12 AM
  #561
Default U Can Do 3D
Yeah, Had planed on 4-40 hardware. (forgot to post.) Thanks for the tip on the wheel pants, we are on a paved strip also. Thanks again.
Old 12-01-2002 | 12:43 AM
  #562
Default U Can Do 3D
Just received my U-Can-Do. There is some thin wood along both sides of the inside of the box. Do I need it for the plane or is it just packing protection?
Old 12-01-2002 | 12:53 AM
  #563
My Feedback: (287)
Default U Can Do 3D
Mine did not have that inside. I would bet it is packing protection.
Brian
  #564
Default U Can Do 3D
Did someone put a gasser on this plane!!!!!!!!!!!
Old 12-01-2002 | 01:17 AM
  #565
My Feedback: (181)
Default U Can Do 3D
Any one have any problem with with engine flooding mounted inverted on the u can do.. i have a saito 100 in mine ,floods every time when i start. looks like tank to high .. any input ..
please help..
thanks Bruce..
Old 12-01-2002 | 01:57 AM
  #566
DKjens's Avatar
My Feedback: (50)
Default Saito flooding!
oldmanbruce,
yep, you should have put a YS on it hehe.
DKjens
Old 12-01-2002 | 02:00 AM
  #567
My Feedback: (181)
Default U Can Do 3D
DKjens,
you could be right.. i like my saitos... any other ideas... or is is that saitos hate to run inverted.. what size ys do u have on yurs..
may have to try one..
thanks Bruce,
Old 12-01-2002 | 02:23 AM
  #568
DKjens's Avatar
My Feedback: (50)
Default U Can Do 3D
olmanbruce,
I run a YS120SC, swinging an apc17x6 at 9500, very fast vertical ha ha, Hovers at about 1/3 throttle, sounds like just above idle. When does your Saito flood? If it's just between fueling and starting, just pinch the line with some forceps, it it floods when taxying out to the runway, and idle is adjusted right, yep, then I guess you'll have to movve the tank. I am purely YS when it comes to 4-strokes, so you'll see me recommend those engines all the time ha ha.
DKjens
Old 12-01-2002 | 02:45 AM
  #569
Default gasser
Captinjohn,
I've got a RCS 1.40 mounted on mine and it fits great, unfortunately I'm not finished putting the plane together yet so i cant tell about how well or bad it will fly, I've been waiting for three weeks on some servos i ordered for this plane and am still waiting. when its together i will post some pictures
Old 12-01-2002 | 03:18 AM
  #570
Default U Can Do 3D
Supertiger: Thanks for the reply. I cannot wait to hear how it flys. Good luck and don,t get the airspeed to high. It sure should hover easy. If there is a lot of shake in tail-feathers you may want to use tail braces... non metalic. Best Regards C.J.
Old 12-01-2002 | 03:24 AM
  #571
Desertrat's Avatar
Default U Can Do 3D
Oldman: Dont go buy a YS, your Saito will power this model just fine. I havent gotten my UCD yet, but I just bench ran the Saito 100 - wow, what a great motor. yes, it does seem picky about where the fuel tank is, but if you have the tank center centered to carb, then you may just have the low end needle set too rich. I bench ran it inverted to see if it could be finicky, and it was some, but like I said, if the tank is placed properly, then its just a needle problem, adjust it like the owners manual says and the problem should go away - if not, a pump/regulator will solve the problem for sure, and save you big bucks. My Saito was spinning a 15x8 at 8500 RPM, still set way rich, I'll take that with the full pound of noseweight savings and the lack of tailweight, the ability to put after run oil in the motor, not having to send the thing in for a new diaphragm every other year, not spraying myself with fuel when I pull the wrong plug, not dealing with a really finicky needle vavle, not splitting fuel tanks, not hunting down annoying fuel system leaks that make the motor go WAY lean (read another trip to service department), hoping I wont have to send it back to the shop when i get it back from the shop because it still doesnt run right - again, any day and bet it flys way better than the YS 120. But hey its just me. Dont get me wrong, I'm a big YS fan, I've owned 5 of them, sold 4, still have 1 (and it needs a new diaphragm) , nothing beats the raw power of those motors, but for the UCD, I think I can deal with a half throttle hover instead of a 1/3rd throttle hover....
Old 12-01-2002 | 03:49 AM
  #572
DKjens's Avatar
My Feedback: (50)
Default Holy Cow Batman,
didn't like mean to start a bashing of any sorts, didn't even think I bashed anything (Saito). Funny how I read again and again all this maintenance crap that's needed for YS engines and yet, I've never had to do any of it. I don't use after run oil, yes, I make little changes on the high end needle when weather dictates it. A Saito 100 weighs 21 oz with muffler, my YS120SC weighs 32 oz, that's not 1 pound different. My tank is mounted on CG, no changes to flight characteristics during flight, no fuel draw problems. Yes, I thought about putting a YS91AC on the plane, but what can I say, I didn't believe it would satisfy my thrust to weight ratio craving.
Hey, I did not put down Saito, I just promoted YS, there's a difference you know. The Saitos are fine engines, they are just not a complete package like the YS, unless you have the freedom to mount them and the tank just the right way.
DKjens
Old 12-01-2002 | 03:59 AM
  #573
Default diaphragm?
I just buy em two or so at a time, and have four years worth...they take ten minutes to change out....
Or are we talking about different things? I'm talking about the pump silicone thingys....
$10....no shop charge
As an aside, anyone having trouble with an inverted engine might want to try an onboard glow driver....
Cheers!
Originally posted by Desertrat
Oldman: Dont go buy a YS, ......not having to send the thing in for a new diaphragm every other year
Old 12-01-2002 | 04:24 AM
  #574
m.gramling's Avatar
My Feedback: (8)
Default U Can Do 3D
I had my saito 91 running inverted w/ no problem. I pulled it off though. not enough vertical pull. I now have a ST90 2stroke mounted inverted. I haven't flown it yet. But I have ran a tank thru it, inverted and it doesn't seem like its going to have a problem.
I pulled the saito because vertical was lacking, it would pull out of a hover but very, very slow. I am problably like, DKJens, Iwant to be able to lauch out of a hover, not crawl.
I haven't had a chance to tach my ST90 w/ a 15x4W prop. But my saito 91 was only peaking it out at 9200-9300. and I had it set to fly at 8800. I am sure that the ST90 w/ stock muffler will atleast do 10,500. I am in the process of putting a moosecan on it. If the moosecan gives me the extra 1500-2000 RPM like it does on my other motors. That should put me in the 12,500 RPM range. That is 3700RPM increase in power. That is approx 30% increase in power over the saito91. That pretty good for a $50.00 motor that I picked up at a swap meet. Not bad.
Old 12-01-2002 | 04:33 AM
  #575
My Feedback: (33)
Default U Can Do 3D
i got a saito 120 on mine inverted with no problems at all. just need to get the adjustments right, my low end took a little while to get straight and then the high end but now runs like a charm and flys like a rocket
Chris
