 Showtime >
Showtime
Showtime
Old 10-13-2005 | 03:59 AM
  #1076
My Feedback: (17)
Default RE: Showtime
Yeah, I added one washer's worth of RH thrust to mine after I had flown it several times. Mine really needed it. But that was enough. I like if fine now. Helped in hover, uplines, etc.
Barry
Old 10-13-2005 | 07:03 AM
  #1077
exeter_acres's Avatar
Well...I'm going to fly it this morning so I can test some more... it was calm last night when I was flying and I think it could use just a scosh... I'll add one washer...
Thanks for the input....
Old 10-13-2005 | 08:23 AM
  #1078
Good morning Barry. Can I assume that to add right thrust you put the washers under the left side of the engine mount? Thanks. Jim Tucker. Ordering my first ST today.
Old 10-13-2005 | 08:34 AM
  #1079
My Feedback: (17)
Yes...One washer under each screw on the Left Side of the motor mount as if you were seated in the canopy.
The washers I use are just average washer I get at the hardware store.
Barry
Old 10-13-2005 | 12:11 PM
  #1080
WHAT?? You didn't use the Sullivan Du-Great-Bro-Planes Ultra Hi strength thrust adjustment washers?? For shame!
Couple more flights this morning...yep needs a tad of right..
Thanks!
Old 10-13-2005 | 12:14 PM
  #1081
Raimondi:
I hate to hear your 1.08 does not perform well on the Showtime. My ShowTime with a 1.08 inverted and using a stock muffler, 16 x 5 Zinger and 15% Omega is literally a rocket. It will jerk it out of a hover rather nicely with plenty of power. I'm not sure if all 1.08's are the FSR version, mine is an older one, about a 1992 model with many gallons run thru it. One thing about the 1.08 series, at least mine, is that shipped from the factory there is a brass insert in the carb venturi that restricts the opening to allow the motor to be used without muffler pressure and the owners manual plainly states: "Orinary suction feed is sufficient for this carburettor. If, however, higher output is required for pattern flying, it is advisable to remove the carburettor insert. In this case, a muffler pressurised fuel system should be used."
You also stated your 1.08 is a new engine. Being a ringed engine, break in could take longer to develop max power. Maybe that and the fact you could have the insert still in the carb could be adding to your lack of power.
Kurtzz
ORIGINAL: raimondi
Hello friend, I builded mine with an OS 1.08 and it fited perfectly sideways with the pitts muffler, the problem with this engine is not that it fits or not, the problem is that the OS 1.08 doesnt have the power neded to 3D this plane it all. I flew mine with a brend new OS 1.08 and 15 % nitro coolpower fuel and different props, I used an APC 17x6, 16x4 and 16x8 and it didnt hold on a hover not even over have power and the pull out was really poor. I wouldnt waste time and fuel with these engine and the showtime,
ORIGINAL: rcflip
Hi,
Can somebody please tell me if the OS 1.08 will fit under the cowling of the showtime with the
Bisson inverted pitts muffler.
I would like to see some under cowl pics with this engine if possible?
Cheers,
Sam.
I would go direct for a YS 1.10 or even better a ys 1.40. I was really thinking that the OS 1.08 was going to do well on the showtime but I was really desapointed on the performance to the point that I am not fliyng the plane againg until I put a new engine in it.
Old 10-13-2005 | 01:44 PM
  #1082
Welp....
Flew this morning and found a major problem with my Showtime....
The landing gear is on the wrong side!
Did a beautiful waterfall.. (man this plane flips sooooo smoothly!) into an inverted Harrier... and it was perfect.... gorgeous harrier, inverted, relatively low... stable as anything.....
powered up and out nicely....
Flew so nicely inverted that I am sure the gear are on the wrong side......
or maybe it needs gear on both sides.......?!?![sm=spinnyeyes.gif]
or maybe...Hey, nevermind....its 5:00 somewhere!
Old 10-13-2005 | 06:26 PM
  #1083
drvcrash's Avatar
Anybody have a pilot In thier showtime. Im trying to figure out what size one to stick in there.
Old 10-13-2005 | 07:01 PM
  #1084
Hey IT Gimp!
I have a 102mm and it's too big! Whatever the next size down is (somewhere between 80-90mm) will fit just right!
Magoo
Old 10-14-2005 | 02:53 PM
  #1085
MIXMASTER's Avatar
My Feedback: (15)
Are you using an inverted muffler? I'm going to need one for an old 108FSR(I think) What engine & muffler are you using???
Old 10-15-2005 | 09:11 AM
  #1086
more trim flights this morning before the wind picked up....
adding a washer for right thrust was the ticket..
now... for level flight, I need about 2 clicks of aileron... which seems to maybe be hurting me in some manuevers (or am I imagining it)
is there a way to change the incidence of the wing slightly, so the ailerons do not need any trim?
Enlarge the rear pin hole a bit so the wing could then rotate slightly and then redo the hole in the new position?
anyone done this or noticed this
I think I would need to move one wing about 1/8"
does my rambling make sense?
Exeter
Old 10-15-2005 | 09:15 AM
  #1087
My Feedback: (17)
exter_acres...You might be able to move the aileron that much by just using a sealing iron and a friend to hold it while you iron the covering.
It seems mine will warp that much when I leave them in the cold or hot. I sometimes have to trim a bit now and then for no apparent reason. That's always what I thought caused it.
Barry
Old 10-15-2005 | 09:51 AM
  #1088
Hmmm... but if I just change the aileron... I'll be back in the same boat of needing some trim for level flight... thats why I was thinking the a wing incidence change may be needed...
so the plane flies level with the ailerons completely even with the wing
or am I barking up the wrong tree?
Old 10-15-2005 | 11:59 AM
  #1089
BoneDoc's Avatar
That would be too much work for me . Sometimes wings get warped because of the covering becoming loose and such. You should make sure that's not the case first before you do the other modifications.
Old 10-16-2005 | 05:47 AM
  #1090
Hi all,
I just got my Showtime, second hand, and I have it almost ready to fly.
In the front is a Saito 150 swinging an APC 17-6[X(]
I have Hitec 6965's on all of the control surfaces.
The only problem I have is the stab has a little movement, it rocks a little. I thought about rotating the tube and re-drilling and tapping the retaining screws, hopefully making the halves tighter to the fuse. The movement is minimal, but is there.
Has anybody else seen this? This is my first plane with removable stabs, hence the lack of knowledge.
Thanks in advance,
Ken
Old 10-16-2005 | 06:35 AM
  #1091
Ron Kinsey's Avatar
Hey Ken,
You're going to LOVE that plane. Unless you are planing to remove the stab for transport or some other reason, I'd suggest...EPOXY.
Good Luck & Many Happy Flights!!
Old 10-16-2005 | 06:37 AM
  #1092
My Feedback: (17)
kennyandannie...My Showtime does the same thing. I can rotate/move very slightly the stabalizer. It dosen't seem to be a problem, but it is a little bothersome. When I get time I think I'm just gonna glue mine. I don't plan on removing the stab anyway. My other planes don't have removeable stabs and I don't think my Showtime will in the near future.
Barry
Old 10-16-2005 | 06:48 AM
  #1093
I was thinking of that, I don't have any problem transporting my other planes with the stabs on. It might be the answer, thanks.
Ken
Old 10-16-2005 | 08:01 AM
  #1094
Just use some foam tape along the edge, it helps seat the stabilizer and stops the rocking.
R/C Foolish
Old 10-16-2005 | 08:16 AM
  #1095
Toto's Avatar
I made a 1/16 ply shim to take up the space in the stab. But after a couple of flights it came lose again so I epoxy it.
Problem fixed no more slop
Old 10-16-2005 | 08:34 AM
  #1096
drumbum's Avatar
Well I just recieved Showtime #2. I bought Joebobs from him. The last one i used my YS-110 but on this one i think im going to use My YS-140L . the only problem is im moving and doing work on new house so getting the time to put my gear in it will be hard
Old 10-16-2005 | 05:32 PM
  #1097
I think I'm going to fly it like it is, just not slap it around real hard. Before I put it through it's paces, to extreme, I'll probably epoxy the stab and make it permanant. I do want to fly it first, just in case I need to make a incidence change.
Thanks for the help guys, I'll get the maiden in this week!!
Ken
Old 10-16-2005 | 07:03 PM
  #1098
kregan's Avatar
Sounds like the anti rotation pins are loose in the holes in the fuse
side. Simple fix, just CA a little balsa in the holes for the pins, then
file out the hole a little at a time untill the pins fit snug in the holes.
Once everting fits nice harden the hole with CA.
No need to epoxy the stabs in place, what happens if you damage
on side and need to replace it?
ORIGINAL: kennyandannie
Hi all,
Thanks in advance,
Ken
Old 10-16-2005 | 08:54 PM
  #1099
You've got a good point Advent, I will look into that fix. I might need to change the stab incidence, so using your repair might allow me to kill two birds with one stone, so to speak.
Ken
Old 10-17-2005 | 10:18 PM
  #1100
BoneDoc's Avatar
She lives!!
I moved the CG back a tad, and hovering is now nearly effortless. I was just grinning ear to ear when I decided to pullout... a funny noise came, and soon I saw my prop flying off (didn't put double nut on the saito). $#@%$^# I thought to myself as my ST went down nose first in an effort to gain air speed. I started to make a pull, but then I pulled too hard on the elevator, causing an Aunt Jemima (aka Pancake). The gear flexed and delaminated... but is still intact. Everthing else is ok also except for the firewall coming off a bit, and one of the SFG has a little crack. I couldn't believe how much of this bird survived that Aunt Jemima from 20 feet.!!!
So now I know, it flies great, and also durable as heck!
