 Showtime >
Showtime
Showtime
Old 10-11-2005 | 06:47 PM
  #1051
Default RE: Showtime
Exeter & Barry,
I have had good luck cutting little fuel tubing "washers" and placing them after the main washer. I've never lost a screw this way.
Old 10-11-2005 | 06:48 PM
  #1052
drumbum's Avatar
ORIGINAL: mightychuck
Exeter & Barry,
thats what i was going to say. but i have lost only one that way.
Old 10-11-2005 | 07:47 PM
  #1053
exeter_acres's Avatar
I'll try that....
not sure the all up...I don't have a good scale[:@]
but I normally run a 15 x 6 with my 1.00
tried the 16 x 4w but it just doesn't seem to spin up quite right
Old 10-11-2005 | 07:56 PM
  #1054
Hi,
Excuse me for my ignorance but what does this mean... What was your AUW with the Saito?
Cheers,
Sam.
Old 10-11-2005 | 08:11 PM
  #1055
auw = all up weight... total weight, ready to fly, but with no fuel
and you are excused
Old 10-11-2005 | 08:34 PM
  #1056
Hi,
Thanks because I was confused and being an Aussie AUW is our currency.
Cheers,
Sam.
Old 10-11-2005 | 09:14 PM
  #1057
BoneDoc's Avatar
lol, good one
Old 10-11-2005 | 10:19 PM
  #1058
What is everyone using for a CG? Is the book a good setting to start at?
Thanks in advance.
Scott
Old 10-11-2005 | 10:28 PM
  #1059
My Feedback: (17)
My CG is 7 3/8" just a bit in front of suggested 7 7/16" I like it there. Still easy to land. I may go back to suggested next time I fly this plane. It's not bad on the CG that's suggested.
Barry
Old 10-12-2005 | 03:00 AM
  #1060
Nickolas's Avatar
Hi,
Showtime users' manual states:
"On the top of the wing tips,measure back 7 7 /16 "from the leading edge against the fuselage and mark both places
with a felt-tipped pen.This is the recommended center of gravity (CG)range."
Well there's no illustration so it is not very clear to me how you obtain the range. OK we start from the wing tips we measure 7 7/16'' parallel to the cord line from the leading edge and then project that point to the wing root? Am I wrong here? Well this is not a range but a point how to do you obtain the range, can someone explain please?
Looking forward to replies,
Nick
Old 10-12-2005 | 03:39 AM
  #1061
BoneDoc's Avatar
Just measure it along the root, then extend it out 90 degrees so you can put your finger to balance it there.
Old 10-12-2005 | 06:15 AM
  #1062
range = somwhere close to that measurement
Old 10-12-2005 | 08:52 AM
  #1063
Hey Barry,
Do you mind sharing your Control surface settings on High and Low rates (in Degrees or Inches)?
Maybe if you feel real generous you can also share your mixes...
I have watched your video a bunch now and just cannot get over the skill you have to fly the Showtime....the inverted parachute is killer!!
Also that is is a darn nice grass field (even at sunset) that you fly from....I am way jealous[8D]
Thanks!
Magoo
Old 10-12-2005 | 09:52 AM
  #1064
Jetmech,
I really like it at the recommended 7 7/16". I had it a little forward of that when I had a prop hub on instead of spinner & it didn't seem to lock in to harriers as well, parachute/elevator as well, or flatspin as well. I may even go back a little more to see what its like.
Old 10-12-2005 | 11:22 AM
  #1065
Hello friend, I builded mine with an OS 1.08 and it fited perfectly sideways with the pitts muffler, the problem with this engine is not that it fits or not, the problem is that the OS 1.08 doesnt have the power neded to 3D this plane it all. I flew mine with a brend new OS 1.08 and 15 % nitro coolpower fuel and different props, I used an APC 17x6, 16x4 and 16x8 and it didnt hold on a hover not even over have power and the pull out was really poor. I wouldnt waste time and fuel with these engine and the showtime,
ORIGINAL: rcflip
Hi,
Can somebody please tell me if the OS 1.08 will fit under the cowling of the showtime with the
Bisson inverted pitts muffler.
I would like to see some under cowl pics with this engine if possible?
Cheers,
Sam.
I would go direct for a YS 1.10 or even better a ys 1.40. I was really thinking that the OS 1.08 was going to do well on the showtime but I was really desapointed on the performance to the point that I am not fliyng the plane againg until I put a new engine in it.
Old 10-12-2005 | 12:11 PM
  #1066
back to those silly hatch screws....
someone told me that one thing that can be done is to put locktite on the screw and do not insert it.... allow the locktite to dry on the screw and then once dry, screw it in.....
says it creates just enough resistance to stop them from backing out....
any thoughts?
Old 10-12-2005 | 12:56 PM
  #1067
OAK
The idea in it self is good, but loctite is anaerob-hardening which mean it won't harden as long as it is in open air (on the thread).
Old 10-12-2005 | 01:00 PM
  #1068
MIXMASTER's Avatar
My Feedback: (15)
I have had no problems backing out using the hard rubber grommets that come with the PSP cowl binders,I've also used old servo grommets,just cut them in half(round ones) and place a washer that is at least equal in size to the grommet,they dont squish out as much.Fuel tubing is better than nothing but its too soft,cant tighten as much.I finally had a full day flying the Showtime without dead sticking.Got a few steps of the trim procedure in,the added right thrust seems about right now.No other trim needed, it tracks straight in KE, still could go further aft on CG but will fly it more this way.Does slow HA KE quite well(no SFG),harriers are soooo easy. If using spoilerons, no ail. is needed at all,even does 'em w/o spoilerons but needed a lot of right ail. at times it was maxed to the corner. Seems to hover well, but I dont have the best prop on for that,loads down the eng. too much. I have trouble doing waterfalls, that rolling to right thing when a lot of elev. is pulled. Does same trying square loops,rolls right. I know I'll have to check elev. halves for uniform throw, after that-what??
Old 10-12-2005 | 04:30 PM
  #1069
drumbum's Avatar
ORIGINAL: exeter_acres
any thoughts?
fuel tubing works fine
Old 10-12-2005 | 05:56 PM
  #1070
Ron Kinsey's Avatar
Hey Guys...There is a write-up on the ST in this months Model Airplane News...
Old 10-12-2005 | 07:29 PM
  #1071
there is one in the new 3D flyer too...
and I flew this evening and the fuel tubing worked nicely... Thank You!
Hmm...balance seems good, lateral balance seems good... but doing some trim flights, it feels like it could use some right thrust.... anyone find this (and if I missed the posts, I'm sorry!)
Cheers
Exeter
Old 10-12-2005 | 07:47 PM
  #1072
BoneDoc's Avatar
Finally got my Saito back from Horizon and flew today... MAN I MISS IT! It just feels so natural. Did some pretty cool harriers also low and slow. I kinda scared a fellow club member with my KE stunts since I was going 3/4 throttle KE figure 8 15 feet away from me.
Old 10-12-2005 | 08:25 PM
  #1073
AirWizard's Avatar
Josh....you ole Hotdog!!!!!!
Old 10-12-2005 | 08:32 PM
  #1074
drumbum's Avatar
Cheers
Exeter
mine didnt need any right thrust but I have been on this thread since day 1 and I recall at least 2 people saying they had to add some,I think Barry was one of them
Old 10-12-2005 | 08:57 PM
  #1075
Cheers
Exeter
Yeah, I think you're right Drum. I believe it was Barry C. that mentioned it so I added one washer's worth before I maidened. Flies perfectly straight uplines, so you may want to try it.
