 Showtime >
Showtime
Showtime
Old 05-11-2006 | 10:03 PM
  #1551
rcfury's Avatar
Default RE: Showtime
I may re-enforce those threads with a little CA to get some extra strength in the prop. So what is it now a 9x4?
Old 05-12-2006 | 09:37 AM
  #1552
AHPowelson's Avatar
My Feedback: (37)
Saito 125 - my rudder servo is in the tail. It balanced perfectly with the battery and regulator under the wingtube and the RX next to the throttle servo.
Old 05-12-2006 | 09:52 AM
  #1553
rclement's Avatar
ORIGINAL: Barry Cazier
I mounted mine with the pull/pull. Was easy to balance. I think I have my battery in the rear of the hatch. I'm using the mighty 110. This plane seems to have a very wide CG envelope though. But after my Funtana experience I wasn't taking any chances. Seems either area works just matters where you put the battery. I love the fact that the plane comes with two choices. Very nice.
Barry
I can't believe you are giving away the secrets of prop sewing. [X(] I thought that was highly coveted technology. Oh well, now everyone knows. [&o]
Old 05-12-2006 | 11:46 AM
  #1554
rcfury's Avatar
ORIGINAL: AHPowelson
Yeah thats one thing i did notice you can either mount the servo as pull-pull or stuff it in the tail and still works very well. just need to place the battery up closer near the wingtube. Its great having a very lightweight engine like the 125.
Old 05-12-2006 | 05:44 PM
  #1555
My Feedback: (13)
Quick question: How are you guys keeping your four canopy bolts in during flight? They tend to work loose/out. Thanks
Old 05-12-2006 | 06:04 PM
  #1556
My Feedback: (32)
First put a piece of copper tubing in the hole so the washer does not crush the wood. Then use blue thread locker
Old 05-12-2006 | 08:15 PM
  #1557
raideron's Avatar
Hi all,
Now that I finally have my C.G, right, I got 6 flts on the S.T. She does fly nice and lands easy!!
No problems arose this AM... Well I had a bit of tweaking on the YS and she did her thing, Guess
she liked it so well she spit out my muffler tip:-((.... I still have a bit of setup etc.... But she's a
great flyer, tracks good and true... And she lands really easy.... Inverted flt. now takes a bump
every now and then... So I may move the battery back a little... But overall..... I like it!!!!
Landing is a breeze.. And she did not show any problems as yet... She's charging again for the AM
Old 05-12-2006 | 10:05 PM
  #1558
AirWizard's Avatar
Ron,
Congratulations........This is my favorite glow plane. have you tried it with the SFG's?
Old 05-12-2006 | 10:29 PM
  #1559
My Feedback: (32)
Flew mine again today and love every minute of it. I did find that dead spot though, took off to slow and dipped the right wing. It is not a problem if you let her roll a bit and get some ground speed
Old 05-13-2006 | 12:19 PM
  #1560
raideron's Avatar
Hey David... No SFG's yet..... Got another two flt's this AM, Had to cut it short it's
the "Bosses" B-day......... Man I love the way she flies.... Still have not had any of
the "bad" habits show up..... Hope it stays that way)))) Ohh did I say she lands
nice and easy)))))))))
Guess you ordered your APC 16.5x5W from APC??? I started to order one but the
shipping said $15 for 1 prop???????? So I stopped the order, If you ordered from
APC was your shipping that high???
Also with the 17X4W, It sounds like my YS is turning some R's??? Have not tach'd
it yet... So, I'm not sure abut the 16.5????????
Old 05-13-2006 | 03:49 PM
  #1561
My Feedback: (17)
Ron...
By my trusty, highly accurate fish scale test the APC 16x6 is the prop that makes the most thrust by over a pound on the 17x4W and 1/4 lb on the 16.5x5. The 17x4W is easy to overspeed.
Congrats on the Showtime. I think you're in love.
Barry
Old 05-13-2006 | 08:00 PM
  #1562
AirWizard's Avatar
Ron,
I got mine from Horizon. The price is 12.?? and shipping is 4.99 by USPS
Old 05-13-2006 | 11:06 PM
  #1563
raideron's Avatar
Thanks Barry and David... I have the 16X6. just have not use it yet... Just thought I also
give the 16.5X5W a try... I do like the plane.. It makes me try to be more precise on the
sticks and I think she looks good in the air:-))
She's on the charger, I may try both the above in the AM.... I was going to put the SFG's
on today, But the other member that likes the low H.A. K.E.'s was flying his F-90... And if
the SFG's does what's said, I may try a 1' pass.... My V2 Kat is still laying in the garage
floor after the last time I tried that:-(
Old 05-13-2006 | 11:14 PM
  #1564
AirWizard's Avatar
Ron,
You have to try the SFG's.......Knife Edge is fantastic......and when you pull up to hover it locks in.
Love it....Love it......Love it
Old 05-14-2006 | 01:51 AM
  #1565
My Feedback: (17)
I have to agree...mine is more fun with the SFGs. But them make me very nervous for landings as I fly off of a grass field. Usually quite long grass. I've broken one a couple of times. They are fragile. Oddly enough I found my hard to fly slow enough to do KE with the SFGs. Then I learned to trust the YS better and I can just creep along in high alpha KE and it's pretty cool. I also flet it flatspins better with the SFGs. They really work. But I fly it most without them. Just think they are gimick looking. This is one of the finest KE airplanes with or without the SFGs.
Ron, keep us posted to your progress. I'm interested to see if you find the "dead spot". I flew mine 20 ro 25 times before I noticed it and could pin point it. As I flew in more and more situation is when I discovered it. Many have the same problem as me and many do not. It's kinda split that way. Anyways, here's hoping you don't find it. It's kinda lowered my trust leven in the plane.
Barry
Old 05-14-2006 | 07:42 AM
  #1566
HoverLoW's Avatar
Hi! My Showtime finally flown the last weekend! It's a great plane!
I'm using the 1.60 FX without problems. I just re-drilled and reinforced the firewall with epoxi and mount all servos in the tail. I don't put yet, but the plane will need some weight in tail.
Anyway, the results are perfect. I can hover with less of 1/3 throttle, and the plane lands light anyway!
I liked that combo very much. No vibration problems too!!!
Here my configuration:
O.S. 160 FX
Perry Pump VP30
J'tec in cowl muffler
Futaba 8UAF sistem
5 Futaba S3305 Servo High-Torque Standard w/Metal Gears
Sanyo 6v 1500 mAh Battery
All alluminuim servo arms are 1.57"
Some pics:
ID:	461094   Click image for larger version
ID:	461095   Click image for larger version
ID:	461096   Click image for larger version
ID:	461097   Click image for larger version
ID:	461098   Click image for larger version
Old 05-14-2006 | 12:18 PM
  #1567
raideron's Avatar
Hey Barry.... Got another three flights this AM.... I did not try the 16X6 nor the SFG's
maybe next time...the "other pilot" was doing his thing, So thought I better leave them
in the wing bag until I get more use to the plane... He was trying to talk me into it too
No problems yet.... Will keep it updated... But I hope I'll be quiet :-)))))))))
David... I need to try the SFG's... But timing is everything)))))))
HoverLoW... Very nice!!
Question.... The firewall/engine will have a slight play, movement while moving the spinner
in checking that all is tight?? I hope I asked that correctly... I removed the cowl and all
is tight and looks good, but I can get 1/16/1/32 movement when putting pressure on the
spinner, I thought I read something about that in this thread.. But I could not find it...
Old 05-14-2006 | 07:41 PM
  #1568
HoverLoW's Avatar
Raideron, I figured the some thing in my model.
The firewall have a little movement behind the holes in horizontal pressure, but I don't saw nothing with vertical pressure!
Anyway, I think this condition in flight almost never happen and is not a problem.
Maybe theres a little - or none - of those vertical and horizontal movements in flight because the engine pulls the airplane vectorially and the force is distributed of the mount for firewall and it for fuselage.
It is only a consequence of light structure.
The problem is not the firewall crack, but it to unglue of model.
Theres a pic in that forum of a RCU member what had him firewall unglued!!
Old 05-18-2006 | 10:45 PM
  #1569
Well I maidened the ST today, and it flew great. I only got one flight, hoping to have more tomorrow. I only had one problem. I seem to have a fuel tank issue though. After I fill up, fuel starts to run out of the carb line. It doesn't matter what line I fill up with, or whether or not I fill up with the carb line connected or unconnected, it just keeps running out. I have never had a problem like this on any of my planes. I have the tank mounted in the stock position, and a Saito 125 mounted inverted. Would a Cline regulator fix this issue?
Old 05-18-2006 | 11:19 PM
  #1570
Describe your fuel system. 2 lines, 3lines, Dubro fill valve.
Sounds like your filling through the exhaust? Nah, your at SFA, your smarter than that.
Nevermind you said after you fill up. My guess is your tank is higher than your carb and it is siphoning.
Old 05-18-2006 | 11:36 PM
  #1571
Well after I made that post I started thinking, and went down and looked. You got it right Super D, carb is below the centerline of the tank. I can fill up through the carb or the fill up line ( I have three lines, carb, muffler, and fill-up), and if I disconnect the line from the carb and keep it above the engine, the fuel will not run out. If I lower it down to the level of the carb, fuel will start running out of the line. I don't know much about the Cline regulator, or what it does, but will it help this issue? Is there another way to fix this?
Old 05-19-2006 | 04:28 AM
  #1572
My Feedback: (32)
Yeah, start the engine immediately after fill up. Seriously, I had that problem once with a U-CanDo. Try making a large loop with the fuel line.
Old 05-19-2006 | 07:02 AM
  #1573
Not sure if th ecline would fix it, seems like I've heard it might or maybe something like a uniflow system. I doubt a loop would work on the line going to the carb, on vent lines yes it would.
Old 05-19-2006 | 09:33 AM
  #1574
My Feedback: (32)
Fluid seeks its own level. If you make the loop higher than the tank then to the carb it will work. Atleast it worked for me. I am flying a Saito 100, just looked at my setup the fuel line comes out of the tank and loops around then to the carb. I have no syphoning problems
s
Old 05-19-2006 | 01:59 PM
  #1575
Yes the loop worked. I ended up looping the line around the motor mount, which is right at the same level of the tank. When filling up, the fuel will want to come out, but will stop when it gets to the level of the tank. Thanks for the help guys.
