Great planes ultimate 160
#4977
My Feedback: (7)
IN
RE: Great planes ultimate 160
ORIGINAL: sdstick06
a1pcfixer..............
Do you really like the Ulty better then your 260?
I see you have a DP Ulty..... I had one of those and really loved it. does the GP fly better?
SDS
SDS
Remember the early days of real bibes. Big, slow, and ultra-manuverable.
The GP Ultimate has a style & grace all it's own. Add a 50cc gas engine, and smoke, and look out!
#4978
My Feedback: (7)
IN
ORIGINAL: sdstick06
Should I power it with a Brillelli 46GT or a DL50?????
SDS
SDS
If you want gobs of power to hover and pull out, get a DL50 or a DA-50r.
#4980
My Feedback: (17)
ORIGINAL: sdstick06
Just did a weight analysis
46GT with muffler and ignition = 56.6 oz
DL50 with same = 55.3 oz
I am surprised... I thought the 46GT was lighter then the DL50
#4984
TN
The only thing I don't like about runnng a 50cc is that it protrudes further out of the cowl then a 46GT. I love the lines of the radically raked back cowl and anything sticking out of it to far ruins that line.
I think the 46GT will have enough power for me.... and I have one.... I am going to stick with the 46GT.
I like good verticle but I am not a 3D flyer at all.... IMAC, artistic aerobatics, and freestyle are my faves.... should have plenty of power for that type of flying.
Thanks all,
SDS
Thanks all,
SDS
#4986
My Feedback: (14)
ORIGINAL: sdstick06
Thanks all,
SDS
Thanks all,
SDS
#4987
SC
ORIGINAL: mcmike
Once it breaks ground for the first time with the 50 on the front, you won't really care that the cylinder is hangin' out in the breeze. the 50 is without a doubt the correct engine for this thing!
ORIGINAL: sdstick06
Thanks all,
SDS
Thanks all,
SDS
Mine has a Brison 3.2 and I smile every time I fly it.
#4991
My Feedback: (14)
I've been using a TBM 22x8 for my typical messing around flying. One thing I did notice on the TBM props was a bit less rpm from others i'd tried, but it sure pulls a lot harder!
#4993
Well, in spite of the tornados attacking my part of the state today, UPS came through on time and my Ultimate has shown up. Initial impression is great. I am very glad I decided on this one and not the others on the market. Now I just need to save my quarters to get all of those servos!
#4994
My Feedback: (17)
Well, I pushed the button this morning for the order for my second Ultimate this morning. I will now have two of them, one in Florida for the winter time and one here in Minnesota for the summer time. This build should go faster than the first one.
#4997
FL
question for anyone who will respond. When you built your GP Ultimate 160, how did it go when you glued the top wing together, then mount and bolt it in place before the epoxy hardens? What glue did you use? The weather here in Fl is getting warm. No A/C in my shop. 30 minute epoxy does not last to long before it starts to set.
Bruce
Bruce
#4998
My Feedback: (14)
ORIGINAL: aa2dd
Bruce
Bruce
#4999
I used West System epoxy and 105 hardener. Takes about 4 hours to set up and has maybe 45 minutes of working time. I mask to the edges with tape, globbed the epoxy on, aligned the wings and then covered the seams with a 6" wide strip of waxed paper and smoothed out with the edge of a piece of sheet balsa over the paper. Makes a smooth, shiny seam that blends in well and fills all the gaps without needing to be sanded. WHen hard peeling off the waxed paper and the tape is all there is to it.
I also peeled the covering on the bottom wing and glassed the seam top and bottom to within 1/2 " of the bellypan edges.
#5000
My Feedback: (17)
aa2dd,
We have a place in Fort Myers where we are spending six months a year, and just became Florida residents in February. I fly at the Cape Coral R/Sea Hawks.
http://www.rseahawks.org/
Regarding attaching the upper wing halves, I'd look for a longer working time epoxy as Charlie P suggested. It actually doesn't take very long to attach the top wing if you practice it once or twice before applying the epoxy. For balancing purposes, I placed a loop of monofilament fishing line at the cg before gluing the upper wing together. It is sandwiched on each side of the aluminum rib. To balance the plane, just hang it from the loop and move your battery around. I didn't do the fiberglassing of either wing, I just made a wing joiner out of a quality 1x2 piece of wood.
Chuck
Chuck
