 U-Can-Do 3d 46? >
U-Can-Do 3d 46?
U-Can-Do 3d 46?
Old 08-09-2003 | 01:55 AM
  #376
Default RE: U-Can-Do 3d 46?
Originally posted by STLPilot
I mind. This thread is for the discussion about the UCANDO 46 and how many sets of twin sisiters with photos that you have had in your life. Lets keep it that way!
STL
You can't count your twin cousins dude
Rick
Old 08-09-2003 | 01:57 AM
  #377
My Feedback: (21)
Why not! Cousins are better then strangers! Give it a try ... then get back to me.
Old 08-09-2003 | 02:02 AM
  #378
Ok .... give me your cousins' number and I'll set something up
You can tell its Friday night and we are really bored!
Rick
Old 08-09-2003 | 02:08 AM
  #379
My Feedback: (21)
NONONO! I said try YOUR COUSINS and get back to me. I'm telling you, cousins are AWESOME. They really know how to please you!
If you really are really bored lets see how many times we can say ***** on this thread until a moderator gives me SHYIT for it.
OK it's 10:08 CDST. Ready ... GO! Bring on the MODS! I am not scared of them!
Old 08-09-2003 | 02:11 AM
  #380
Thanx for the pix of your cousins.... ummmmmmmmmm ....... I think I'll pass
Old 08-10-2003 | 01:40 PM
  #381
My Feedback: (13)
Question for broken wing owners: About where on the wing is the break point? Center,, servo locations, etc. Was the wing totally severed or just cracked?
Old 08-10-2003 | 04:21 PM
  #382
by left servo and completly severed for me
Old 08-10-2003 | 06:13 PM
  #383
The leading edge of the wing cracked between the left servo and fuselage. I had 9202 servos on the ailerons and the flutter was so bad it stripped the gears on both the left and right ailerons. I believe if I had a servo with lower tork the wing would have seperated in the air.
I shipped the wing back to GP and they are going to replace it.
Regards
Scooterpilot
Old 08-10-2003 | 08:21 PM
  #384
NeoGenesis's Avatar
My Feedback: (27)
Just curious......how fast were you flying and did you seal your hinge gaps?
Neo
Old 08-10-2003 | 10:04 PM
  #385
No, I didn't seal the hinge gaps.
I was doing a nose down vertical power off decent. I wasn't over-speeding the model at all. Just letting it fall.
Regards,
Scooterpilot
Old 08-10-2003 | 10:39 PM
  #386
NeoGenesis's Avatar
My Feedback: (27)
What engine prop combo? Just doing comparisons to what I'm running.
Neo
Old 08-11-2003 | 02:32 AM
  #387
My Feedback: (45)
well i had bad luck with the wing today but it was not GP foult it was mine i went to a fun fly and at first i was pract. and came for a landing to start the event and i hit the limbo pole and and made a big gash on the right side of the wing but with some duck tape and some ca it flew again and i finish 3rd not bad after smashing that wing all it took to get it flying strait again was 3 clicks of trim
this is a great plane i will try to get the big brother again since it went to pices on june LOL
Old 08-12-2003 | 12:04 AM
  #388
rcflyguy_26's Avatar
My Feedback: (8)
I got my replacement today!!! Covering is nice and tight!
Scott
Old 08-12-2003 | 02:38 AM
  #389
Did GP replace the wing or the whole model?
Regards,
Scooterpilot
Old 08-12-2003 | 10:12 AM
  #390
My Feedback: (8)
They replaced the whole thing!
Scott
Old 08-13-2003 | 08:13 PM
  #391
NeoGenesis's Avatar
My Feedback: (27)
How much of it if any did you have to ship back?
Neo
Old 08-14-2003 | 01:42 AM
  #392
My Feedback: (8)
I sent back all of the pieces that were left.
Old 08-21-2003 | 11:27 PM
  #393
Bad Tooth's Avatar
My Feedback: (10)
Well, I just got my UCD .46 and I'm very impressed so far! My last plane was the GP Venus and I really liked that plane; this plane builds similar to what the venus did, but I think that gp made some improvements in some areas. I can't wait to fly this thing! I am just waiting on my YS .63!
Old 08-21-2003 | 11:37 PM
  #394
You will be VERY pleased with the YS .63, i hav flownafreinds and he had the ys on it. I hovered it down touched the rudder and with 2/3 power i zoomed straight up! ( we also used cool power 30% heli gas it runs cooler, gives more RPMs and thats all i use on my glow planes) Best of luck
-James Lyons 14 years old Florida
Old 08-22-2003 | 02:39 PM
  #395
Bad Tooth's Avatar
My Feedback: (10)
poptartcrust- did your friend's ucd balance ok with the ys? did he have to add any weight to the nose? what prop was he using? good to hear that combo works!
Old 08-23-2003 | 03:21 PM
  #396
Bad Tooth's Avatar
My Feedback: (10)
Has anyone done a pull-pull on this plane? If so, where did you mount the rudder servo?
Old 08-23-2003 | 06:55 PM
  #397
i know someone did pull pull rudder on the 60 size ucd, he just mounted the servo on the bottom of the fuse in front of the tailwheel.
Old 08-24-2003 | 12:02 AM
  #398
No it balanced perfectly with out using any extra weights or anything, he is using a 14-4 prop on it. I need one but all i have now is my os .46. It has enough but it lacks in certain areas though. I wonder if i put a osciliating pump on it if it would work better? It would be a pain putting it in but i wonder if it would work? Any comments appreciated!
Old 08-25-2003 | 03:19 PM
  #399
Ducted Fan Dan's Avatar
strupp 22,
I mounted a pull-pull on mine with the rudder servo in the tray meant for the throttle servo. I then mounted the throttle servo on it's side ahead of the rudder servo and tray, just behind the fuel tank. I also put a 6v JR 1400 battery pack on top of the fuel tank. It works great, it balanced perfectly with no extra weight.
Old 08-25-2003 | 10:08 PM
  #400
dyondan- what engine is on yours?
