 Wagstaff Extra 300 >
Wagstaff Extra 300
Wagstaff Extra 300
Old 02-28-2004 | 07:39 AM
  #5526
TOFAST4U2C's Avatar
Default RE: RE: I maidened my Patty with a DA-50!
How about when you use 2 6volt packs in parallel??
Old 02-28-2004 | 08:39 AM
  #5527
Forgues Research's Avatar
My Feedback: (7)
ORIGINAL: rcguy1
BasinBum is a regulator really necessary when you use a 6 volt battery pack? I'm using Hitec digital servos with Futaba radio equipment and no regulator on the 6 volt battery. Have had this setup over a year now with no problems. Also other fliers at our field have the same setup, 6 volt battery no regulator with 35% planes and no problems.
If I may, you don't need a regulator with any 5 cell packs of NiCds or NmHds
Some years ago, JR servos would not tolerate 6 volts, but as for Hitec and Multiplex, and most other brands will have no problems with 6 volts.
Right after a complete charge, you will see close to 7 volts, but normally when take everything out of the charger and drive to the field, the batteries have stabalized to a lower voltage.
Also if you have your transmitter very close to the airplane at the start of the day, you might see some jitters, because the RF is getting swamped , pull away a bit.
Hope this helps.
Roger
Old 02-28-2004 | 09:05 AM
  #5528
ORIGINAL: rcguy1
Asked and answered. They are not necassary but they are sure common. As Roger points out the voltage drops off quickly but if you tend to top off at the field it'll keep the servos from twitching. I have also read that the servos will perform more consistantly through the flight but I don't know if it's a noticable differance.
As for 2 fasts parallel question it wouldn't change the voltage so that set-up does not have to have one either.
Old 02-28-2004 | 09:08 AM
  #5529
My Feedback: (16)
There is not a problem with two 6 volt packs in parallel.
http://www.geistware.com/rcmodeling/..._batteries.htm
ORIGINAL: TOFAST4U2C
Old 02-28-2004 | 11:33 AM
  #5530
My Feedback: (21)
RCGUY:
These guys are correct. Especially with the HiTec servos which are supposed to be capable of taking up to 10 volts (I don't believe it as a constant 10v, although I maybe wrong). The only servos on the market that don't tolerate 6v too much is Futaba. They are marked as such although their digitals are more tolerant of 6v when it is regulated. As these guys pointed out with a regulator you get a more consistent voltage through out your flights. The regulators used today are better suited to battery packs of Li-Ion & Li-Po technology where the voltage out is any where from 7.2 to 8.4 volts and needs to be regulated. As pointed out a 5-cell 6 volt NiCad or NiMi doesn't need regulation with todays' servos.
Old 03-15-2004 | 05:51 PM
  #5531
DENNIS C's Avatar
My Feedback: (99)
Default RE: Wagstaff Extra 300
Hey guys anybody have a new spinner that comes with the patty they want to sell. if so send me a e-mail please.
Old 04-06-2004 | 10:39 AM
  #5532
PlaneKrazee's Avatar
My Feedback: (14)
Default Crazy Pilots?
Swift Bill,
Where did you get your pilot and do you have contact information?
Old 04-06-2004 | 10:48 AM
  #5533
P-51B's Avatar
Default RE: Crazy Pilots?
Regarding the 6 volt pack and regulator issue...aren't the electronics, such as the receiver, built on a 6 volt platform? Therefore, isn't there a potential damage to the electronics rather than the servos (since the packs will hold more than 6 volts for some time)?
Old 04-06-2004 | 01:10 PM
  #5534
My Feedback: (21)
Correct, most damage would show up in the receiver as it's not designed to take more voltage.
___________________________
Too Soon Old, Too Late Smart
[link=http://www.edge540t.com]Edge540T.com[/link]
There's a Fine Line Between Hobby and Insanity
Old 04-06-2004 | 01:20 PM
  #5535
My Feedback: (7)
By far the best way is to use a 5 volt battery for the receiver and a 6 volt battery for the servos. This way the receiver runs clean without any issue.
And here is one way of doing it
Roger
Old 04-11-2004 | 03:02 PM
  #5536
Default Patty With A Glow
for the guys here that are flying a Patty with a Glow engine!!!
do you have any problems with a glow pulling the Patty!!
Old 04-11-2004 | 03:14 PM
  #5537
John Murdoch's Avatar
Default RE: Patty With A Glow
My first Patty had the Moki 2.10 for well over 200 flights until I went gas. Works okay but nothing spectacular. She would do the basic and sportsman IMAC maneuvers but kinda had trouble with the advanced and beyond. Not enough vertical. But it was a great little engine to get the feel of the Wagstaff. Once I went with the BME and the DA, four vertical snaps, not a problem. If you're even considering the glow motors, remember the $$$$ you need for fuel. Even with the rise of gas prices, $2.00 a gallon is pretty cheap.
Old 04-11-2004 | 03:20 PM
  #5538
Default RE: I maidened my Patty with a DA-50!
I have a Fugi BT-64A in mine and I have been told that it was the wrong engine!! to heavy and not enough HorsePower!!! How much did you spend for your Gas Engine?
Old 04-11-2004 | 03:39 PM
  #5539
$500 for the BME and around $600 for the DA.
Old 04-11-2004 | 03:53 PM
  #5540
OK I was just wondering THANKS
Old 04-11-2004 | 06:37 PM
  #5541
Baker here are the links to engines made for the Patty. Good luck. If I left any other engine out -- it was not intended to offend anyone who may have another engine choice for the Patty. I have made many mistakes in my lifetime and will make many more in the future (I hope) but I have learned to make the best of a poor choice.
http://www.bmeengine.com/html/50.htm
http://www.desertaircraft.com/da50.html
http://www.brisonaircraft.com/revolution.htm
http://www.aircraftinternational.com/ A little heavy.
http://www.rcshowcase.com/html/engines/zdz50.html
Old 04-11-2004 | 10:31 PM
  #5542
Does any one have a Patty or a Giles 202,or a Edge 540 , or a Extra that they have CRASHED LAYING AROUND that they would part with?
If so EMAIL ME and put BAKER PLANE in the subject!!
Thank you all for reading
Old 04-14-2004 | 06:38 AM
  #5543
Just pick up new gp patty wagstaff 300 looking for set up w/da50 length for standoffs,rudder pull pull cable or servos in tail?muffler for smoke & pump to use. set up for gas tank & smoke tank in fuse. new in gas planes have 4 stroke & 2 stroke planes help! thanks jim
Old 04-14-2004 | 08:47 AM
  #5544
My Feedback: (9)
Jim,
Length on standoffs for DA-50R is 3 3/16ths" to get the exact 7" from the firewall.
You must do pull pull on rudder because the DA is so light. Even still you will have to put the batteries near or ahead of the wing tube to balance.
Skip the smoke in this one. You want to keep it light. My opinion though as the bird could loose some weight as opposed to adding it.
If you must, I would use the Slimline setup using the Pitts smoke muffler and sport pump. Otherwise Use the non smoke SLIMLINE PITTS.
I used a B&B industries 16 oz Rectangular tank over the tube.
[link=http://www.se2skunkworks.com/images/DA50MountDiagram.zip]Here[/link] is a link to the mounting diagram I made for the DA-50R.
[link=http://www.se2skunkworks.com/photo.htm]Here[/link] is a link to my picture gallery that can answer most of your questions.
Jason
Old 04-14-2004 | 09:05 AM
  #5545
My Feedback: (7)
ORIGINAL: SilverEagle2-RCU
Jim,
Jason
Jason,
I just looked at your picture galery, very nice engine standoffs
I have a question, about your fuel tank, what kind is it and does it come standard with the fill/overflow nipples on top as in the pictures. I like the idea, since I am developing a fuel fill system to fill faster for the larger tanks.
Roger
Old 04-14-2004 | 10:11 AM
  #5546
My Feedback: (21)
Hi Roger:
Those tanks are from B&B. Here's the site: [link]http://www.bennettbuilt.com/index.html[/link]
_________________________________
There's a Fine Line Between Hobby & Insanity
Old 04-14-2004 | 10:16 AM
  #5547
My Feedback: (9)
Default RE:Roger
Roger,
They are nice standoffs. It's a shame to have to cowl them and the engine. Need to make a clear cowl for the plane!
Did you see the fueler adapter that you made for me as well? Looks great on the fore turtledeck.
rcpilotjae is correct. You need to install the nipples yourself where ever you want them on the tank.
Jason
Old 04-14-2004 | 10:34 AM
  #5548
My Feedback: (7)
ORIGINAL: rcpilotjae-RCU
Hi Roger:
Great, thanks, that's what I was looking for. The stupid thing about it, they were practically next to my booth in Toledo,,bummer
Roger
Old 04-14-2004 | 11:31 AM
  #5549
thanks for the help jason will let you kown how the plane come out jim
Old 04-15-2004 | 01:04 PM
  #5550
dave_anderson's Avatar
My Feedback: (47)
I hate that I have to admit I didn't search all 5000+ posts on this plane. I'm still going.
Can anyone tell me if the spinner that comes with the ARF will fit the bigger props? I will probably be using a Pro Zinger 22X8 on my DA-50 (foir break-in).
I am asking because my kit is on it's way and I want to get a spinner order in should I need one. I can drill it for the DA-50 myself.
Also, what is the spinner's diameter?
Thanks!
Dave
