Reload this Page >
Top Flite Staggerwing
Old 10-11-2006, 03:04 PM
  #126
jimt
Default RE: Top Flite Staggerwing
From JimT
I will try to post a few pitures. If this works I can post more if you like.
ID:	539262   Click image for larger version
ID:	539263   Click image for larger version
ID:	539264   Click image for larger version
ID:	539265   Click image for larger version
Old 10-11-2006, 03:06 PM
  #127
jimt
From JimT
It worked let me know if you want more and of what part of the plane.
Old 10-11-2006, 09:17 PM
  #128
CRAZYRYAN
ORIGINAL: Tall Texan
Still planning on the Saito 170 Radial or maybe a Zenoah 23. It looks like the radial will fit but will be pretty tight
well just make some nice cuts for the saito's heads so they can get air fllowing over them to cool the engine better.
Old 10-11-2006, 10:14 PM
  #129
jimmkeeh
I am looking at putting my Saito 180 in mine. I think that I will have to cut some of the cowl for the rocker arm covers. I might put it in inverted to avoid seeing the cutouts. I will do more measuring to be sure.
Hey Jimt, yours looks just like mine! I am thinking about some black and gold trim to the wings to "finish off" the look.
Anybody else have thoghts about adding something to the wings?
Jim K
Old 10-11-2006, 10:43 PM
  #130
N215PB
N215PB's Avatar
Mine arrived intact with no help from UPS, looks like they drug it behind the 727 and the truck. Major dings/tear in box, thankfully it just missed the wings.
Old 10-12-2006, 01:57 AM
  #131
fgpierce
fgpierce's Avatar
I'll always try to do 2nd day air. More expensive but cuts down on damage for me! I find replacement parts always have something wrong with them. Glad to hear you squeaked by.
The RCS 180se will fit fine in mine. Although I found the marks on the firewall to be around a 1/2" low. The original marks made the cowl "droop" down excessively. No other problems as yet.
One minor thing... The covering on the wings are scratched from the factory heat iron on all cap strips. It would have helped to use a sock.
This is one pretty awesome plane.
Old 10-12-2006, 04:59 AM
  #132
jimt
The only thing I will add is a NC number to the wings. I will need to search some pictures for what number to use. the N2100 may need to go.
Old 10-12-2006, 07:25 AM
  #133
pettit
My Feedback: (23)
pettit's Avatar
I believe my Staggerwing should be here tomorrow or Monday.
I'll be using an OS 160 four cycle twin (they want me to "keep it in the family")
They also said that the OS 325 5 cylinder would be "just too much" for this plane.
The Robart retract system will also be on the way.
Old 10-12-2006, 09:00 AM
  #134
CRAZYRYAN
ORIGINAL: I'll be using an OS 160 four cycle twin (they want me to "keep it in the family")
well why dont u use the 5 cylinder?
Old 10-12-2006, 10:40 AM
  #135
P-51B
P-51B's Avatar
ORIGINAL: pettit
Uh Oh. Don't tell me RC Report is becoming like the other magazines.....[]
Old 10-12-2006, 12:31 PM
  #136
fgpierce
fgpierce's Avatar
It seems that I did need to raise the engine 1/2". The pics show the cowl and dummy engine aligned to the side graphics and prop shaft. I also needed to shift the engine ,facing the firewall, to the right 1/4".
ID:	539889   Click image for larger version
Old 10-12-2006, 01:23 PM
  #137
pettit
My Feedback: (23)
pettit's Avatar
We like to comply with requests from the manufacturer, especially when they show a particular engine in the manual and I just happen to have one.
Plus, the 325 Radial is really too much (power and $$$) for this plane.
Old 10-12-2006, 01:29 PM
  #138
CRAZYRYAN
but would it work well?
Old 10-12-2006, 01:44 PM
  #139
pettit
My Feedback: (23)
pettit's Avatar
I really don't know if it would even fit in the cowl.
Old 10-12-2006, 01:48 PM
  #140
CRAZYRYAN
not if you make cuts for the cylinder heads
Old 10-12-2006, 01:58 PM
  #141
pettit
My Feedback: (23)
pettit's Avatar
In that case, ANY engine would fit....
Old 10-12-2006, 02:31 PM
  #142
CRAZYRYAN
well then i might as well get that plane and the engine instead of the 3 cyl. sometime. as tim taylor would say arrrrgh arrrrgh arrrrgh more power!!!!!
Old 10-12-2006, 02:36 PM
  #143
CRAZYRYAN
man with the engine and some of the accesorees the total outcome would be 2448.99!!! damn
Old 10-12-2006, 08:17 PM
  #144
jimmkeeh
FGPierce,
Yiour pictures seem to show that you mounted the 180se inverted. Is that correct?
According to the RCS website, the 180se is 5" from the prop centerline to the top of the plug. My Saito 180 is 4.4" so it should work inverted, also. Did you try to mount the 180se at 90 degrees? Do you know how much room there is for a 90 degree monted engine?
Soory to bother you with these questions, but you seem to be moving right along. I have only taken mine out of the box and looked at it so far. My job, seems to get in the way of my fun.
Jim K.
Old 10-13-2006, 12:12 PM
  #145
fgpierce
fgpierce's Avatar
jimmkeeh
Your right! The engine is inverted. I'm sure all the cowls are the same shape as mine and with that being said you'll notice that the cowl isn't round. The bottom drops down a bit giving a little more room for the inverted position. I don't think you'll find the same room horizontally. However your engine is shorter than mine so you may be able to sneak it in. Now there's the consideration of cooling. The cowl is too tight against the fuselage for that. You'll need to make a hole. I wanted mine on the bottom. After all a lot time spent in admiration of this beauty will be on the ground. The unsightly hole won't be as noticeable to the ants.
Old 10-13-2006, 01:56 PM
  #146
lear31A
My Feedback: (123)
Some different versions, notice the gear doors.................
Old 10-13-2006, 05:16 PM
  #147
GaGeeBees
My Feedback: (23)
GaGeeBees's Avatar
Got mine today!!
Old 10-13-2006, 05:33 PM
  #148
apalset
Got mine today as well. How many are we in this club now?
Old 10-13-2006, 05:59 PM
  #149
jimmkeeh
fgpierce,
Yeah, I saw the shape of the cowl was better for inverted. This is good for gas, but I amy have to lower the tank for inverted glow. Siphoning can be a real problem!
In either case. I plan on the exhaust going out the bottom, so I will have openings there for the muffler and cooling.
Jim K.
Old 10-13-2006, 06:08 PM
  #150
lear31A
My Feedback: (123)
Mine will be here next week. I noticed on the Top-Flite website video that on landing they had full flaps on the lower wing. I am trying to figure that programming out. How to mix all 4 ailerons for flying and only the lower ailerons for flaps? This is one exciting project for sure. I am waiting to decide what engine. I want a gasser for sure.
