Reload this Page >
Hangar 9 1/4 Scale Piper Cub ARF???
Old 04-25-2014, 04:32 PM
  #1551
sj3cub
My Feedback: (9)
Originally Posted by HELI-MECH
I have just comleted the bungee mod, instead of the orings. I threaded small screws through the small welded nuts and then tied one end of small bungee cable (bought at walmart) and then did about 12-14 some what tensioned wraps on each side. So close to 24-28 wraps per leg total. I also fabricated shock covers like the PA 18 as this plane is being converted to the PA18 from the J3. The springs that were on it seemed super tight, i would rather have a more forgiving landing gear.
Hey Heli, Do you remember what section of Wal-Mart you purchased the small bungee'sin?
Thanks a lot!
Old 04-25-2014, 04:33 PM
  #1552
HELI-MECH
Thanks a lot!
Hey there, it was in the craft section with the beads and what not and sewing stuff cheers.
Old 04-29-2014, 03:53 AM
  #1553
HELI-MECH
What is the axle diameter of the axles on this plane? I am away from home and can't measure.
Old 04-29-2014, 11:46 AM
  #1554
bikerbc
I have 3/16 " that I made from cap screws in mine . They fit and work great . The originals were not long enough for my big wheels .
Old 04-29-2014, 12:27 PM
  #1555
HELI-MECH
Thanks for the info, I could potentially go this route but I have the stock axles and bought new wheels. I need the stock axle diameter as I want to buy brass tube and make bushings. Do you know the stock diameter? 5/32 ?
Old 04-29-2014, 01:19 PM
  #1556
bikerbc
Okay I have the original wheels and axels hear on my desk along with a micrometer and the measurement is 0.197 in or 5 mm
Old 04-29-2014, 01:27 PM
  #1557
bikerbc
Old 04-29-2014, 03:12 PM
  #1558
HELI-MECH
Awesome, thanks a lot, i bought some 7/32" outside diameter brass bushing tube with inside diameter of 0.191" I may have to run a reamer or drill bit through it but should still leave enough material as a bushing. cheers.
Old 05-01-2014, 08:45 PM
  #1559
astrohog
astrohog's Avatar
Maidened mine today. What a sweet flying plane! I bought mine used, previous owner stripped the Ultracote when it was new and re-covered it in Solartex. I added the VVRC 40 twin. AWESOME little motor, and a PERFECT match to this plane!
Regards,
Astro
Old 05-27-2014, 05:17 PM
  #1560
HELI-MECH
Does anyone have a right wing they want to part with? Lightly damaged is even ok...
Old 05-29-2014, 03:51 AM
  #1561
HELI-MECH
Originally Posted by Jb Stearman
HELI-MECH
Sorry I have not gotten back to you. My pc crashed and I had to buy a new system. I'm still trying to learn the new Windows 8!! A whole different world to me!!
Watched your video of the flap operation.You did a super job with the install. Very scale looking with the hidden push rod linkage and servo. I didn't think doing the bottom hinge method. I'm looking forward to seeing the finished Super Cub.
Jim
still working on this one, kinda messing with the wings, they are scratch built and not perfectly aligned like stock. Need to bring up the trailing edge of the wing a bit relative to the fuselage to lessen then angle of incidence to a more stock set up. Vvrc 40 cc twin installed with functioning cowl doors.
ID:	1999620   Click image for larger version
Old 05-29-2014, 03:59 AM
  #1562
HELI-MECH
Couple more, just an idea of what I'm dealing with for the wings. Flaps are all cut into them now as well. Just need to raise the trailing edge of wing, easiest way I'm thinking is to relocate the rear holes in fuselage for the most aft small wing tube.
ID:	1999624   Click image for larger version
Old 06-01-2014, 08:04 AM
  #1563
jmcowart
jmcowart's Avatar
Hey, Heli-Mech - Is the Hanger 9 1/4 scale cub J3 landing gear fully interchangeable with the PA18 landing gear? Meaning you can take the whole assembly off of a 1/4 scale PA18 and directly install it on the 1/4 scale J3? - (I'm aware of the paint difference, of course) Thanks much.
Mike in Douglasville
Old 06-01-2014, 08:39 AM
  #1564
HELI-MECH
Mike,
wish I could answer that but I'm not sure. The floats are interchangeable so I'm assuming the mounts are the same. I looked at the pictures of both and they look the same other then the shock covers. I built my shock covers for my pa18 conversion myself.
Old 06-11-2014, 11:55 PM
  #1565
John_M_
John_M_'s Avatar
I think the H9 PA-18 has a wider fuselage than the H9 J3, so the spreader brace on the PA18 is probably the only part that would be different... I have the Robart j3 cub gear on my sig cub, and its suppose to be a replacement for the H9 gear; based on that assumption, the spreader brace is a bit narrower than the H9 PA18, something that could be corrected.
I just got my PA18... one thing I noticed right away, which is hard to believe; H9 got the gear scaled correctly over the Robart gear , center to center between the fore and aft pivot points on each arm scaled is 5.375" H9 nailed it, where as Robart's is 4 5/8" center to center... go figure.
John M,
Old 06-20-2014, 05:20 PM
  #1566
HELI-MECH
Default Maidened flight
Maiden flight on the converted j3 to pa18 tonight. Got the vvrc 40cc tuned in nicely and sounded great. A bit windy for my liking so another long time club member maidened it, little up trim and that was it. I'll take the sticks on Sunday and hopefully get some time on it.
ID:	2007222   Click image for larger version
Old 06-21-2014, 02:30 PM
  #1567
Jb Stearman
My Feedback: (8)
HELI-MECH,
Your Super Cub really looks outstanding! I have a dozen or so flights on mine now. The G26 and a 16/8 Master Airscrew prop seem to be a good choice. This airplane is awesome with flaps!! It will almost stop in mid air. Takeoffs and landings are sweet. Put the floats on mine for the float fly next Saturday.
Jim
Old 06-21-2014, 03:02 PM
  #1568
Jb Stearman
My Feedback: (8)
HELI-MECH
trying to figure out how to add pics.Jim
ID:	2007473   Click image for larger version
Old 06-21-2014, 04:17 PM
  #1569
SkyPilot101
Heli-Mech, any details and pics on the mod's to the fusalage & flaps, yea, I want to copy yours !
Old 06-21-2014, 06:55 PM
  #1570
HELI-MECH
HELI-MECH,
Jim
Thanks a ton, super pumped about this plane and can't wait to get mine on floats as well. Great pics you added, can't beat a cub!
Old 06-21-2014, 07:06 PM
  #1571
HELI-MECH
Hey there, thanks a lot, project turned out great. I have quite a few pics of the build, there was some pretty big mods to the tail, firewall and front portion of fuse, but overall easy to do. Highly recommend the vvrc 40cc engine, stuffs nicely in cowl and looks great with dual exhaust and also highly recommend the hinged engine cowl doors for tuning purposes. I have quite a few pics in this forum I think, check into it.
ID:	2007515   Click image for larger version
Old 06-22-2014, 04:47 PM
  #1572
Jb Stearman
My Feedback: (8)
HELI-MECH,
Did you get to fly your Super Cub today and get a chance to play with the flaps? Where did you get the tires? I like the tundra look they have. I'm using the 1/3 scale Dubro cub tires on mine for now but would like to go bigger.
Jim
Old 06-22-2014, 04:57 PM
  #1573
HELI-MECH
HELI-MECH,
Jim
Sure did! Plane flew great! Engine crapped out on climb out and piled her in. Gonna have sone beers in her memory tonight.
Old 06-22-2014, 06:08 PM
  #1574
iflyfloats
iflyfloats's Avatar
HELI-MECH, sorry to hear about your engine failure, that was a beautiful looking job you did. in the last pictures you posted it looked like you where on approach, what is on the horizontal stabilizer? looks like something was
caught on the flying wire brace.
Old 06-22-2014, 06:14 PM
  #1575
Jb Stearman
My Feedback: (8)
Heli-Mech,
I'm really sorry to see that! I know how much time and work you have put into the build. But don't let it beat you. REBUILD her.
Here is one of my projects to give you some incentive.
Jim
ID:	2007825   Click image for larger version
ID:	2007826   Click image for larger version
ID:	2007847   Click image for larger version
