Spectrum receivers
#51
ORIGINAL: grimbeaver
Read the bottom of the product page, of course it's a knock off:
http://www.targethobby.com/in-stock-...p-4161958.html
ORIGINAL: goirish
Just a question, Are you all saying that the RX from Target hobby are knock offs. They sure look like the real McCoy.
***we are not able to tell this is a real spektrum rx, or not. But we are responsible for the quality, and guaranty each rx to be in good working situation, any defects can be return or refund***
#52
MN
ORIGINAL: goirish
I'm not sure exactly what that quote means. It could be a disclaimer because of selling spektrum so cheap. All I can say is I have 10 of them and probably 20+ in the club. No one has reported any brown outs or failure of any kind. All sorts of plane sizes are being flown on them.
ORIGINAL: goirish
#53
I don't think I will do that. As I said I have been flying with them for some time. I damage more planes through stupidity than by bad RX's. If someone else wants to buy one and do that and post the results that would be OK also.
#54
My Feedback: (193)
FL
I've used orange receivers since last year with my JR 2.4 transmitter. I have them in an Evader, a StrykerQ, Phase 3 F-16s, a Stinger, a GP F-20, a Mini Ultra Stik, a Hobby Lobby F-35, a Demon pylon racer, and a motor glider. I use satellites on all. The StrykerQ has been over 1,000 feet (with permission of the tower, using an Eagle tree altimeter); the Evader is a rocket and I use two HXT900 servos in it ($2.49 each); my buddy flies a GP Edge 540 50". Collectively we estimate we have over 1,000 flights on our planes. This is not an exaggeration. We fly three times a week, about 8-10 flights a day, each of us. In 1,000 flights or more, we have had no documented issues proving the receivers were at fault in any crashes. I say they are bulletproof and would have no fear using them in anything. Do I have other planes and helis worth a lot of money? YES. Do I use them in those airframes? NO, mainly because those planes and helis were purchased before the orange receivers existed. Bottom line, buy one or two, and have no fear.
#55
ORIGINAL: ATVAlliance
I have a couple of the cheap AR6200's I bought from oomodel. They look IDENTICAL to the ''real deal''. Even down to the stickers on the back of them and their SAT recievers.
I cant say with certainty that they are clones...but assume so because of the following...
1. They dont have the updated firmware. Meaning when you manually test a ''brown out'' condition...the LED doesnt flash...just links back up and stays solid amber/orange.
2. WHY would Spektrum dump a large amount of these RX to a distributor/s to be sold to the public that
It's a pretty blatant copyright violation.
At least with the "Orange" RX's there is NO attempt to make them look like Spektrum products.
The other 6ch clones I've purchased at LHS' and local shows also make no attempt at looking or being marketed as Spektrum RX's.
As I mentioned earlier, these have EXACTLY the same circuit boards as the Orange 6ch and both have proven to work exactly the same way, which in this case has been problematic for me... the 6CH's likely have a firmware bug carried over. Some people may have better luck if their firmware code is a different rev but there is no way to tell what you have.
#56
ORIGINAL: goirish
That disclaimer is a way of preventing someone from sueing them for false advertising.
It basically tells you that they are an exact ( visually ) copy... something that is technically illegal as it represents the product as being from a different company than the one that sold it.
#57
ORIGINAL: Tony Iannucelli
I've done slant distance tests out to 1800 feet w/o any problems with the Orange RX's.
The problems I've had with the 6Ch are not due to range or brownouts... ( it occurred within 50 feet of me repeatable on three different 6CH RX's, but not so on the other RX's. )
Just a firmware glitch, that hopefully has been corrected by now.
BTW: To those denigrating the multiple node ( satellite ) systems... here's some empirical evidence for you....
There is a You Tube video up where someone in the U.K. took a Spektrum RX out to 2.2 kilometers line of sight slant distance ( 7217 feet! ) on a stock setup, utilizing FPV for visual control.
He then proceeded to replace the TX's antenna with a directional Yagi type and was able to achieve another .7 kilometers of distance.
#58
MN
ORIGINAL: opjose
#59
ORIGINAL: opjose]
While I dont know enough to say that the 6ch Orange RX is or isnt the same as the board used in the "suspect" AR6200's I own. I can say that the Orange RX 6ch only have a single antanae lead(short red one). The "suspect"6200's have dual antane on the main RX, as well as the Sat RX too. Looks in every way the same as an original one. Only thing, the ones I bought from oomodel came in a clear plastic zippy bag and no documenatation whatsoever.
Ive not bought the sats for the Orange RX 6ch...so Idont know about their antanae setup.
#60
I'm sorry but what does that prove? I don't think anyone is doubting that the multiple node system works. Just that it doesn't seem like it should be needed. Neither Futaba or Hitec do satellite rx and their systems work just fine.
You can operate any and all multinode Spektrums WITHOUT the satellite very well if you elect to. They are not "needed". They are an extra measure of safety though.
The multiple nodes permit better reception out to far longer distances. Much longer than what normal RX's can handle.
Try the same thing with a Hitec or a Futaba single node system and see.
And lest you respond with "but we don't fly our planes that far"... remember that this long range test is indicative of better overall sensitivity and multipath image rejection.
Some Futaba's do feature multiple antennas to try to achieve better results and eliminate multipath problems too, but they don't feature a remote AMP and node.
That's why our Jet guys all swear buy JR/Spektrums and throw in as many nodes as possible to elimate any POSSIBLE chance of LOS failure. You don't HAVE to do this, but it's cheap insurance.
#61
While I dont know enough to say that the 6ch Orange RX is or isnt the same as the board used in the ''suspect'' AR6200's I own. I can say that the Orange RX 6ch only have a single antanae lead (short red one). The ''suspect'' 6200's have dual antane on the main RX, as well as the Sat RX too. Looks in every way the same as an original one. Only thing, the ones I bought from oomodel came in a clear plastic zippy bag and no documenatation whatsoever.
Preferably of the side with the SMD's, not the trace side.
I'd love to compare them to both the Orange RX which I highly doubt are the same but who knows... and to the real 6200's.
When I've compared the Orange 6CH RX's to the black and silver clone RX's I purchased at an LHS I found the boards to be identical with identical traces. Only the types of capacitors used varied a bit.
If anyone is interest I can post pics...
The Orange had only one antenna, but the black and silver clone had two, so after I had the problem with the 6CH I also tried soldering on the second antenna to see if this improved matters. The support circuitry is there for BOTH antennas on the Orange RX's.
#62
ORIGINAL: opjose
Any way you could post a close picture of the circuit board w/o destroying yours?
While I dont know enough to say that the 6ch Orange RX is or isnt the same as the board used in the ''suspect'' AR6200's I own. I can say that the Orange RX 6ch only have a single antanae lead(short red one). The ''suspect''6200's have dual antane on the main RX, as well as the Sat RX too. Looks in every way the same as an original one. Only thing, the ones I bought from oomodel came in a clear plastic zippy bag and no documenatation whatsoever.
T-Ball with my sonis running me ragged right now...so thats why I said "I'll make no promises." LOL. I'm liable to forget about this thread until I get back to work on Monday. I dont get online much at home as I work with computers and networks for a living. Just makes me want to not even think about a D*#M computer till I get back to work. LOL
#63
MN
ORIGINAL: opjose
Actually it proves quite a bit... someone better versed in antenna theory could give you quite an earful too...
You can operate any and all multinode Spektrums WITHOUT the satellite very well if you elect to. They are not ''needed''. They are an extra measure of safety though.
#64
I'll make no promises here, but will see what I can do. I think I have a plane on the bench right now that I have one of these 6200's in. I could snap some pics and upload sometime tonight or this weekend.
It would be interesting to compare them though, particularly against a real 6200.
#65
MN
ORIGINAL: opjose
http://diydrones.com/profiles/blogs/...e-flights-with
So please stop bashing the range of others without first doing your homework.
#66
You elected to "bash" multi-node RX's as if they are/were somehow inferior, indicative of absolutely NO KNOWLEDGE of antenna theory.
The Aurora system you cited does NOT utilize a stock antenna setup.
How about doing YOUR homework instead?
#67
MN
ORIGINAL: opjose
Oh, PLEASE....
You elected to ''bash'' multi-node RX's as if they are/were somehow inferior, indicative of absolutely NO KNOWLEDGE of antenna theory.
#68
So at this point lets just settle on saying both systems can do ~2km distance which is more then the average r/c user will be doing and be happy.
#69
MN
ORIGINAL: opjose
I don't dispute that.... I only dispute the implication that multi-node systems are somehow inferior, they are not.
#70
Let me circle back. Spektrum marketing/packaging tends to imply that satellite rx are required for the average user to reliably use their rx.
This is true.
This is compounded by the fact that they designed the AR8000 (and others I'm guessing) to require one to work.
As a very loose analogy: Your car will drive just fine without the spare tire too, but your better off with it in the trunk.
So one of two things is true, either the rx itself is an inferior design which needs a satellite to function reliably for the average user,
I'm not saying which one is true, personally I'd really like to know which one it is.
Multiple reception paths are almost always better than single ones.
Multiple reception paths help overcome the polarized nature of antenna transmission and reception patterns.
http://en.wikipedia.org/wiki/Antenna_diversity
Spektrum/JR includes the satellite on many RX's and makes it optional on others.
You DO NOT HAVE TO BUY the satellite if it is not included, but your assured better performance/reception if you do.
I'd advise people not to sweat it on the smaller planes, but maybe opt for the satellite options on the larger ones, and/or planes with a lot of internal wiring/plumbing...
or it's just marketing bs to get you to buy more stuff from them. I'm not saying which one is true
Some might argue it is... others may tell you that this is a superior way to hook up multiple servos on larger planes.
I agree with the latter, but those who argue the former, probably don't have the larger planes that may take advantage of it so they can't see the rational.
#71
MN
ORIGINAL: opjose
#73
ORIGINAL: Iherling
I am posting for a buddy. He just bought a spectrum DX6i radio. I am told that you can get receivers called ''orange receivers'' that are compatible with this radio. They are quite inexpensive. When researching I find them on Hobby King and ebay. Thay say they are compatible with and Spectrum that is DSMX or DSM2. Does anyone know if these will work with the above mentioned radio?
The listed receiver is AR6210 for that radio
thanks</p>
thanks</p>
