ME 109 Scratch Build from Midwest Plans
I ordered some Randolph tautening nitrate dope from spruce…. Will tighten up the silk then apply KlassKote epoxy paint to fuel proof. Since I have the KlassKote on hand…. We’ll see what type of heavy mess i can create with that combo. LOL
Hye Flyer, I'm currently finishing a Quickie 500 race plane exactly the same way. The wing is dope, and tissue, except the wing tips, which are double covered with silk and tissue. Whatever color scheme I decorate my plane with is color tissue. It will get approximately 5 coats of nitrate before clear KlassKote. The fuselage is 3/4 oz. glass cloth applied with MinWax polyurethane, and then clear coated with KlassKote. If you overcoat polyurethane with KlassKote give it 4 or 5 days to gas out. With this procedure I get good looking models, that have light weight finishes.
Hye Flyer (07-10-2022)
Say, Hye Flyer,
Wow, I've just built a arf(seagull) and I can appreciate how much more difficult it must be with your en devours, all I can say is there isn't much room to take the hobby any further, you have reached the top of rc class in my opinion.
Cheers
Darren
Cheers
Darren
Hye Flyer (08-02-2022)
Darren, I've been at this building, and finishing part of the hobby for about 65 years. It's a little work, but worth it. Yesterday I sprayed an all balsa fuselage with clear KlassKote as I describes in my earlier post. It came out great. The wing has white craft tissue on it, and will get a color "paint" scheme of tissue, and finally clear KlassKote. The airplane should be finished next week. If you are interested there is picture of one of my models on page 17 of the June issue of Model Aviation. That model was painted with K&B Super Poxy which is no longer available. If K&B paint was still available I would be using it. KlassKote is a little pricey, but very user friendly. .
Still waiting on the Randolph taunting dope to arrive from Spruce… takes a long time when not in stock in So Cal. I have glued down (nitrate) the silk… just need the nitrate tautening to tighten up a bit then KlassKote to finish/fuel proof.
#32
So i really screwed up… was so excited to have received the tautening dope from spruce that I wanted to apply to the silk on the wing asap. Well, without checking the labels, it was not until the last quarter of the wing did i realize i just covered the silk in NON tautening dope (cans look identical). I was mortified. Quickly I thinned the correct tautening nitrate dope and began to brush brush brush trying to penetrate the drying nitrate dope… omg. It tightened up a bit but still not where i wanted it.
Epic fail. This will become another flying brick with as much epoxy KlassKote that will be needed to harden the silk. Ugh…
#33
Non-tautening nitrate dope used to have a blue dye in it, to differentiate it from tautening nitrate. That way you knew what you were about to use when you opened the can. Having said that I've use non-tautening in applications similar to what you are doing without problems. Non-tautening will shrink some, but not as much as tautening. I think you will be fine after switching over to tautening nitrate. It will take 4 to 6 coats of dope (or more) just to fill the silk, so your first coat of non-tautening nitrate is only a small percentage of the total dope finish. Good luck. I sprayed clear KlassKote on my newest Quickie yesterday, and flew it today.
Hye Flyer (07-18-2022)
#34
Thanks for the input… several coats of tautening dope and no more wrinkles even after my mess up. Still the longest build I have ever done… If i could, i would change the title to The Petrified ME 109 Build.
#37
Got a lot done this past weekend. Designed and laser cut the canopy for Col. Klink.
It began with the mockup.
Then the files were sent to the laser
You can follow the rest
All and all, I think it turned out pretty darn well. Time for final assembly and details.
Also ordered my colors from KlassKote
search-n-destroy (09-07-2022)
straitnickel (10-08-2022)
#43
I know this is an old post, however, due to an issue of copyright infringement claims by a newcomer, I would like to know if anyone out there knows for 100% who owns, if not in the public domain based on US copyright law of pre 1970 publications) the copyrights to the Midwest ME 109 model airplane design in either the 33" or 48" size? There is a guy who is claiming copyright status on these and many of the Veco planes that by all accounts, have been in the public domain for years, if not decades. When asked for proof of his claim, there was no evidence given and it seems he was only trying to scare away competitive kit makers. It would be most helpful for many if there were definitive answers to such questions...
#45
My question has no direct relationship to this thread or any posts here other than the same person who is claiming to own the copyright to this particular Midwest model has used my images from this documented scratch build (including of my plane in the back of my old Ford truck as seen above) on his website to sell a short kit version without my permission, but that is a different story.
I am simply asking for anyone who knows for sure who owns the copyright to this particular model.
#46
Thanks for the reply, but i was asking for a definitive answer regarding copyright ownership of the ME 109 designed control line kit.
