E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
E-FLITE BLADE CP PRO
Old 09-06-2006 | 05:34 PM
  #101
Default RE: E-FLITE BLADE CP PRO
I have to stay out of the school yard behind me or go and take off and land on the baseball field. Seems they like the grass real long these days, on a 30 size machine it just cuts the grass... hahahaha....
I have to find some length of that tubing, I keep losing pieces of it...
I was hoping someone had a similar problem and already figured it out, saving me the trouble...
One more ???? What's the biggest LiPo we can fit?
Old 09-06-2006 | 06:54 PM
  #102
Psikelly's Avatar
I use Thunderpower and Id suggest going no larger than 1320 Mah. Any more capacity than that and youre adding more weight than you want
Old 09-07-2006 | 06:48 PM
  #103
Hahaha... Fixed my own problem.... Covering was cut on one of the blades and I turned the gain on the tail mix a tad... Still getting used to it, I've only flown about 3 packs and hoped around for 2 getting used to the machine...
Anyone use the MaxAmps packs? They have the 1500 pack that's a tad bit longer...
Old 09-08-2006 | 06:55 PM
  #104
Psikelly's Avatar
OK new Q. Hopin someone can answer this. Im now flying the CP Pro and I bought a Spektrum DX6 because I want it for my parkflyers but also because it can be used on micro helis such as the Pro. BUT, being able to adjust the throttle curves doesnt concern me much because even if I do fly 3D its only gonna be rolls and loops so the curves arent gonna matter a whole lot.
On the CP TX there is the slide beside the throttle so you can idle up, on the Spektrum there is no such trim adjustment for the throttle. So my Q is how do I trim up the throttle??
If there is a way to trim up the throttle then what do you do in the event of a crash to quickly shut it down??
I would really like to see a setup guide for the Spektrum to be compatable with the Pro.
Old 09-08-2006 | 08:53 PM
  #105
Commander_Bob's Avatar
The throtle trim is more like pitch trim but if its all the way up you have to do the trim and the stick so if u want to trim it higher you can make the pitch links a little longer and leave the trim at the bottom so if your in a crash you will only have to move the stick back.
Hoped this helped
Old 09-08-2006 | 08:59 PM
  #106
Psikelly's Avatar
But if I have my throttle full, then raise my trim up, not only does it increase pitch slightly but it also raises my headspeed more. Correct? So what I was concerned about is that what if I needed that extra throttle that the trim produces?? Or is there a setting on the TX that will increase my throttle a little more than the stick normally produces? Does that make sense?? I know what I mean but its hard to explain. Hope this is fairly clear
Old 09-09-2006 | 06:16 PM
  #107
As far as I know yoo can't get more head speed but by making the pitch links longer you will get more lift and will make your throttle stick have a higer max lift.
Old 09-09-2006 | 08:13 PM
  #108
Psikelly's Avatar
So if Im in idle up mode , sliding my throttle trim to the top wont increase headspeed?? This is what I was wondering about but couldnt seem to word it before. Brain freeze I guess
Old 09-10-2006 | 07:27 PM
  #109
I'd imagine that it would but im not shur. There is a dial on the Tx that will change the head speed when the stick is at 50% but I don't think it changes the total head speed.
Old 09-10-2006 | 07:55 PM
  #110
Psikelly's Avatar
Hmm.. Im confused lol heres no dials on the Spektrum. I guess this is why they recommend it for micro helis.
Old 09-11-2006 | 06:55 PM
  #111
Oh I didn't know you were not using the stock Tx.
Does anyone's heli go up and down slowly during a hover?
Old 09-11-2006 | 07:45 PM
  #112
blax1's Avatar
Hello Everyone,
I’ve seriously been considering purchasing one of these, BUT just reading this forum and some others, (and also reading between the lines) are these heli-s any good?[>:] They look great on paper, BUT what is the reality, do they stack up? I hope so, the concept is great.
Cheers Ralph.
Old 09-11-2006 | 07:50 PM
  #113
I an new to flying so I don't have any other helis to compart it to but I was in the same place you were and I went for it and I love my heli. I am already flying and all I have done is damage some blades (still useable no vibration)
I would recomend this heli strongly but I would also recomend getting an extra lipo
Old 09-11-2006 | 10:16 PM
  #114
Its Great!
Old 09-11-2006 | 10:48 PM
  #115
Has any one tried pre flight? If so is it any good?
Old 09-12-2006 | 08:09 AM
  #116
whats pre-flight, is it a sim?
Old 09-12-2006 | 12:34 PM
  #117
ORIGINAL: Commander_Bob
i just ordered the pre-flight and cable off of ebay.
It should be here next week, I can tell you then
Old 09-13-2006 | 06:10 PM
  #118
Yes preflight is a sim. Also to late I also ordered it of ebay because it was only 40$.
Old 09-14-2006 | 12:18 AM
  #119
blax1's Avatar
OK thanks for your help people!!
Old 09-14-2006 | 06:19 PM
  #120
I just redid my CP Pro, because the tail shaft was cracked and now it wont lift off. I replaced the entire main body, and installed the electronics correctly, but the helicopter just wont go up. I fower it up to full throttle and full throttle trim and it still wont go. The tail gear is warped, but im going to fix that, and it shouldn't affect the main blades. When i turn it off, the pitch seams to seem a little negative.
--Wingman1331
Old 09-14-2006 | 06:50 PM
  #121
blax1's Avatar
Some how you don't seem to have positive pitch, can you dis-connect the motor and check for positive pitch with a pitch guage?
I dont have a PRO!! What are the specs?? Do they run minus 10 degree's and positive 10 degree's like most other heli-s??
If you have good head speed it must be pitch!!!
lets us know the outcome.
Cheers Ralph
Old 09-14-2006 | 07:03 PM
  #122
Fried my 3-1...is there a better after market one i can use...or do i have to buy the same stock one?
Old 09-14-2006 | 07:10 PM
  #123
i believe in normal mode its -2 to +12 and idle up -12 to +12, its just that its not getting the higher pitchs. Anyway i can manually change that?
Old 09-14-2006 | 07:33 PM
  #124
blax1's Avatar
Well if its got +5 or more it should hover must be something wrong with set up[]
Old 09-14-2006 | 07:49 PM
  #125
Wingman, I'm not trying to insult your intelligence here, but I made this mistake. Is the motor plugged in reverse? If you want a fool proof way to test, get a light leaf or piece of paper. Place it below the the blades. Bend the paper or leave to a tee pee shape, as this increases surface area. Then when you spool up, if the leaf goes shooting up, its reversed, if it gets blow away, the polarity is not your problem.
