Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Air Hogs Aero Ace!
Old 01-24-2009, 03:38 PM
  #6901
Garrett1234567
Default RE: Air Hogs Aero Ace!
Keep us posted micro, I want to see a true micro 3dish plane. A quick update on my MCX, I stripped one down to just frame, and batt and it flies fine. My next step isto make a cardstock deathstar and put around it. If anyone knows of some cardstock plans let me know.
Old 01-24-2009, 07:02 PM
  #6902
FERNDALE AIR FORCE
FERNDALE AIR FORCE's Avatar
I just flew the vapor around a pole on the porch, very fun. Then I got to attacking the goofy dog. Once he saw the plane and it was about to fly onto the porch he took off. And then everytime he went to whine at the door I'd come back at him. I found this quite amusing, the dog did not.
Tim
Old 01-24-2009, 08:10 PM
  #6903
FERNDALE AIR FORCE
I just got some inverted spirals out of the Vapor, and I had the camera going. I'll go work on the Vid.
Tim
Old 01-24-2009, 10:24 PM
  #6904
FERNDALE AIR FORCE
OK, here's the vid, http://www.badiusownersclub.com/vide...ideo%20one.wmv It's really short. The vapor will go for 10 minutes in a light breeze, 15-20 in a nearly windless condition. I stopped because as the disjointed credits state I clipped a bush, with the rudder, inverted. Everytime I think I have this little marvel figured out, I find something else it will do.
I under stand that it costs 4X an aeroace, but it's worth it I think.
Tim
Old 01-25-2009, 12:18 AM
  #6905
Garrett1234567
Tim, Can i bnf it with my mcx tx?
Old 01-25-2009, 12:42 AM
  #6906
micro_builder
micro_builder's Avatar
I bound my mCX heli TX to my Vapor with no issues. Garrett you mentioned a micro 3D...
http://axonracing.com/catalog/produc...products_id=44
http://www.youtube.com/watch?v=OtgFhGdnLII
http://www.youtube.com/watch?v=sBMKELgAxIU
Theres a thread on it over at RCG in the micro/indoor forum. Its flown with other electronics but
the PZ Vapor Brick with the 4th channel rudder mod and a brushless motor/ESC would do the
trick too.
Nice flying, Tim. This bird sure doesnt like to be upside down much, with less angle of attack, more
sustainable inverted flying could be possible.
Nick
Old 01-25-2009, 02:10 AM
  #6907
FERNDALE AIR FORCE
Nick, I was stunned that the plane held inverted. That was part of my problem. I can get about 2 seconds of standard inverted flight out of it. So when I got inverted, no big deal, then it held in a spiral. So amazing.
Tim
Old 01-26-2009, 01:31 PM
  #6908
ahaacobbler
ORIGINAL: trroadster
if that happens then I suggest we all find a new "home".
Anyway, I'm also building the pilatus P4 sailplane for AA components from the site sited above.
I built the Pilatus P4 from those plans. The plane was amazing. It is actually the only ace that I have ever lost. It would climb on the lowest throttle setting. I got it up about 20 or 30 feet and then decided to let it come back down. It had a plan of its own and kept right on climbing with no throttle. I watched it climb, staying approximately over my flying space for maybe 20 minutes, at which point it was just a tiny speck. Then it started heading out to sea. It was sad, but so amazing, it was almost worth it. I have no doubt that it stayed in the air for at least an hour, maybe several hours and finally landed with a nearly full battery.
more recently, I built the plane again, but scaled it up to I think 150% with simple photo copier scaling. The wing span is now 40 inches if I remember correctly. This one is also amazing. It flies so smoothly - no porpoising. I like to take it out in a light breeze and just float it in place.
A couple of things that I learned about this airfram with the AA electronics are that:
1. You need some dihedral. On the 1:1 scale plane I pulled the wingtips up with a thread streached between. That worked wll, but the rounded shape of the wing was kind of funny looking. The 1:1.5 scale one has some dihedral molded into the center and a lilttle more molded into the wings at the spot where the wing starts to taper. This looks and flies great.
2. You need a lot of weight up front to get the cg right. I guess this makes sense, because the design is taken from a plane designed to have a pilot that weighs as much as the airframe sitting about as far forward as possible. I put the r/x and the battery as par forward as possible and still had to add a lot of weight. I should measure it, but I am sure that it is more weight than the whole rest of the gear. For my next round, I was kind of thinking of extending the nose a few inches and maybe changing the whole rear fuse to CF rod so that I can get the CG forward without adding so much weight.
Good Luck,
Cobbler
Old 01-28-2009, 12:20 AM
  #6909
trroadster
Hi Guys
Time for an update from my little aircraft factory. Two new planes, one tetsed and a proven though sensitive flyer and one just built and so far untested. The "F15" uses the guts from my first AA bipe. It was initially built to try the Jetscream fans but there was not enough power for more than a slow descent. So back to the drawing board, out came the exacto and AA guts were stripped (RIP #1) and added to the "jet". After some elevator trimming it flies well but slowly around the hanger where we do our indoor flying. It is made of 1 mm depron so is very light and susceptible to any air movement such as a heating duct.
The ME262 was inspired by Tim. In a Pmail we were talking about the Jetscream and scratch builts for it's fans. He mentioned that IF he were to try one it would be a ME. Hmmm thinks I, the mattell? AA clone/competitors included a sorta ME262... Using that for a size guide, a 3 view and a photocopier led to an evenings fun cutting out and assembling my 262. The wing chord was extended 1 cm to give a larger area. It weighs 28.6 grams including paint. The ducts are paper and may well be abandoned after a test flight. We'll see on thursday.
Anyway, here are a couple of pics
ID:	1121523   Click image for larger version
ID:	1121524   Click image for larger version
ID:	1121525   Click image for larger version
ID:	1121526   Click image for larger version
Old 01-28-2009, 01:21 AM
  #6910
FERNDALE AIR FORCE
Wow, TR. Nice birds. I remember that PM now that you mention it, but otherwise it was gone. Please take credit for your bird. You built it etc. Thanks for remembering me though. It means a lot.
Tim
Old 02-02-2009, 10:26 PM
  #6911
FERNDALE AIR FORCE
Check this one out. http://www.modelflight.com.au/parkzo...cro_sukhoi.htm It speaks for itself.
Tim
Old 02-03-2009, 11:09 AM
  #6912
Garrett1234567
Yea i saw that a few weeks ago. I have to have it. Keep us informed if you here anything about it
Old 02-05-2009, 07:04 PM
  #6913
FERNDALE AIR FORCE
Hey guys, I got a new bird. It is not a micro, but I thought I would share it anyway. The plane is on sale at hobby people, but I won mine in an airplane lotto. It's a VQ Models VTO. The kit is outstanding and the build is going much quicker than most foamies.
ID:	1128297   Click image for larger version
ID:	1128298   Click image for larger version
ID:	1128299   Click image for larger version
ID:	1128300   Click image for larger version
ID:	1128301   Click image for larger version
ID:	1128302   Click image for larger version
Old 02-09-2009, 08:26 PM
  #6914
tornado875
Hellow all been a while since i posted because my Aero ace broke. I cant find one anywere!!!! all sold out and gone. but i found a great replacement. its bigger faster stronger. funner!!!!! but little more $
http://www.eworldtoy.com/racorcskyaia.html
Old 02-09-2009, 08:27 PM
  #6915
tornado875
No offense but this is AERO ACE thread plz stay on topic. this isnt CRAP with AA inards
Old 02-10-2009, 01:53 AM
  #6916
micro_builder
ORIGINAL: tornado875
....i found a great replacement. its bigger faster stronger. funner!!!!! but little more $
...this is AERO ACE thread plz stay on topic...
[sm=confused.gif]
Relax man, this is a long, old thread, staying 100% on topic is nearly impossible, especially
since the AA has dropped in popularity over the past year or two. Off topic planes around
here is quite the norm, as you yourself showed in your first quote above. Sometimes these
old threads get a life of their own and become more than what they started, and in a low-
traffic forum like this, it doesnt really matter.
Old 02-10-2009, 02:06 PM
  #6917
FASTCRASHER
FASTCRASHER's Avatar
TRROADSTER THAT ME262 IS AWSOME!!
SO HOW DID IT DO??
Old 02-10-2009, 05:16 PM
  #6918
tornado875
your right micro builder. srry.
Old 02-11-2009, 12:05 AM
  #6919
micro_builder
No worries man
Old 02-11-2009, 03:03 PM
  #6920
chris1379
Tim
Have a look at:
http://www.modellbauvideos.de/x-twin...zzy-chick.html
Wow, that's a great flying plane. Silverlit, are you paying attention! Build it and they will come. But seriously, I have a few Power Hawks still in the box. Maybe I'll do something like this with the electronics.
Chris
Old 02-13-2009, 01:46 AM
  #6921
trroadster
The ME-262 JetScream Mk II flew tonight. I removed the long paper ducts and added a pair of "pinching ducts" as on the Jet Mite. With a little elevator tweaking it flew well. Unfortunately our indoor site is a bit too small for this plane. I did manage one complete circuit, coming within inches of the walls... but then shut it down. Once it warms up a bit (-23 C here tonight) I will try it outside. I will post pics of the mods soon.
Also have a C-119 to show you guys. Flys slow and scale like.
Old 02-14-2009, 04:06 AM
  #6922
chris1379
I don't know if you guys follow RC Groups but I picked up a Thunderbird glider tonight at Hobby Lobby. Upon searching, I found [link=http://www.rcgroups.com/forums/showpost.php?p=6062313&postcount=1196]THIS[/link] . A few posts later, he shows the [link=http://www.rcgroups.com/forums/showpost.php?p=6121492&postcount=1213]bottom of it[/link] .
I kept reading and found [link=http://www.rcgroups.com/forums/showthread.php?t=476593&page=82]more of them[/link]
Chris
Old 02-14-2009, 09:04 PM
  #6923
FERNDALE AIR FORCE
Very cool Chris.
Now that the VTO is done I am having the need to build jones. My major problem is that I am out of ace gear, and out of rx's for my regular gear. Maybe I'll just fix the Beaver or the micro-cessna.
Did you guys see that kyosho has a Christen Eagle II? I might need one.
Tim
Old 02-14-2009, 10:00 PM
  #6924
tornado875
I know im not the first one to notice this but AA are gone everywere! the internet the store..............
i live in a small town with one store. WALMART [:@] They havent had for over a year. they say Air hogs stop making them. SO PLZ have a heart post a link so a 13 year old kid(me) can get a new one and teach my friend to fly.
Sigh they dont make them like they used too.............
Tornado875
Old 02-18-2009, 10:10 AM
  #6925
Garrett1234567
Tornado, i have a NIB Radio Shack Star Scream i might be persuaded to sell. PM me if your interested.
