EXI-450 discussions/mods/scale projects
#2501
MO
RE: EXI-450 discussions/mods/scale projects
Just take a FA-18 and make a low level high speed pass over them and watch as they try to swim back to shore! Splintered boat and no shots fired!
#2502
[link=http://www.hobbycity.com/hobbycity/forum/forum_posts.asp?TID=284]Here's a new inexpensive 2.4 radio coming out soon. Eat ***** and die spektrum.[/link]
#2503
PA
#2504
Geez, why doesn't Spektrum just make things correctly is the first place? Their business model is to make crappy products and back them with a liberal warranty. They will replace things at the drop of a hat, but it would be better to never have to ship them back at all.
#2505
PA
I have a DX7 so it really does not affect me (YET!!). The recall notice does not say what the defect really is.
Jim
Jim
#2507
MI
ORIGINAL: eaterofdog
LMAO...they're making tons of $$$$ and they keep helicopter and plane parts hopping. I've had two DX6's...CCPM problems, and DX7....brownouts due to crappy antenna connector. Lucky for me.....I didn't smash my helicopter, but my F-16...well, it didn't fare too well. None of the electric were injured, so I'll just order a bare bones for $50 and build another. BTW....it will be hooked to a FUTABA......not a SPUNKTRUM.
#2509
MI
Hey crash, my dad's a tv repairman and he has an awesome set of tools. I can fix it.
#2510
Ok, I'm working on putting my exi together but have a question about mounting the servos. I'm taking them off my belt cp which has a thick plastic frame. On the esky they were just mounted with sheet metal screws, do you install them the same way on the metal frame exi? It doesn't seem like there is that much frame for the screw to bite into.
#2511
MI
ORIGINAL: jeffk464
NO....in the EXI kit, there should be some plastic NUTS...they're small and black in color. You MUST put a nut on each screw. I have a tiny set of needle nose pliers I use to hold the nuts while tighting the screws. It's the worst part of putting the EXI-450 together....installing servos.
#2513
MI
ORIGINAL: babyhuey
CA the nuts to the back of the frame rails.
LMAO.....didn't think of that one.....might work.
#2515
KY
ok guys. question.. i installed a new one way bearing.. i oiled the bearing.. i notice the heli is not as "punchy"... do you think the oil is making the one-way bearing slip?? i was thinking about taking it back out and rinsing the oil back out with some contact cleaner.. i am using a 12t pinion, thinking about going up to a 13t..
#2516
MI
ORIGINAL: sheerider1026
#2517
MI
Hey guys....checking in. Got the new 2.4 gHz antenna for the DX7....it still kicked out on me. All I can say is...."Spektrum, YOU'RE FIRED!!!!!!", 3 bad radios is enough for anyone.
Say hello to FUTABA......... It's not 2.4gHz, but I NEVER had a Futaba screw up on me...ever.
#2518
IL
Good Luck Crash. I hope the Futaba works out better for you.
What does anybody think of this [link=http://www.cnchelicopter.com/servlet/the-753/CNCHELICOPTER-XME-dsh-60A-ESC-for/Detail]60A ESC/BEC[/link]?
#2519
KY
WOW. it has a 100a burst.. does it sound too good to be true?? for the price, i would give it a try.. the 3.0a bec is appealing
#2521
MI
ORIGINAL: grawyl
I found decent 40A and then I found this for $4 more and thought wow!
We hit 100 pgs....hanging in there.
#2522
ORIGINAL: grawyl
Edit: I am trying to score a JR 6102 TX + RX off someone for $60. Maybe I won't be grounded til I get my DX6i back.
#2523
IL
ORIGINAL: crashcrash
Ya know....I went from 30a to 40a thinking I'd gain some, and I did. But 2x the required? Isn't that a tad OVERKILL? A good 30a will do the trick nicely if you wanna pay for it (Pheonix...etc).
ORIGINAL: grawyl
#2524
PA
Hi all,
Still working on my EXI. I think I have all the parts except for the esc and blades. What does everyone think of the esc from Castle Creations. I have one on my HBK2 and have not had any trouble with it yet.
Jim
Jim
#2525
MI
ORIGINAL: reel109
Hi all,
Jim
Hi all,
Jim
