Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Phase 3 EF - 16
Old 01-07-2008, 09:29 PM
edberg
edberg's Avatar
Default RE: Phase 3 EF - 16
Its been fun flying this but I'm thinking I should move on to something more challenging, possibly another edf with landing gear. It's been a great introduction to jets and it has held up great, including the electronics. But it's starting to bore me, I have flown this nearly every weekend since the day I bought it so the airframe is pretty worn out, and there are some deep gashes on the bottom of the intake. The damage is all cosmetic though, the plane still flies like new.
I'm thinking of selling the thing to make money for a new radio, I have never sold an airplane before so I don't know where to start pricing it. How much do you think I should be able to get for a worn out EF-16 with 2 HS-55s?
Old 04-02-2008, 07:54 PM
phippsa3
phippsa3's Avatar
Im undecided on whether to go for the Kyosho F-16 or this Phase 3 model.
Anyone with experience of these models your ideas would be most welcome.
Thanks guys.
Old 04-10-2008, 05:11 PM
JDMjdawg
ORIGINAL: phippsa3
Thanks guys.
I second that! I'd also like to know the pros and cons of each
Old 04-11-2008, 08:06 AM
phippsa3
phippsa3's Avatar
Ive been checking out the specs of both and the phase3 looks the better option.
The all flying tail means that rolls will be crisper. Its slightly larger so you can get a bigger battery in there.
The kyosho looks better but i will paint the phase 3 myself. Just have to watch the weight.
Old 04-18-2008, 08:26 PM
P. Richards
P. Richards's Avatar
Phase 3 is the best foamie F-16 on the market it flies great slows
down for landing and does not tip stall.
I have flown a high powered version of a 90mm F-16
and the flight characteristics are the same. It is a good ducted fan
trainer and should give you months of enjoyment, if you leave
it stock and just go fly. The speed control works great and the
fan unit pushes the plane around at approximately 65 to 70 m.p.h.
in a diving high speed pass. I use the Thunder Power 2070mah 11.1 (3) cell packs
and the extreme V2 2200mah 11.1 (3)cell packs. good for approximately
5 minutes of flight using throttle management.
P. Richards aka SwatTeam
Old 07-14-2008, 04:33 PM
  #31
kingpin112
I can't decide yet which plane i want to buy, a Phase 3 EF-16 or the Electrifly L-39, both planes looked very good.
As for the F16 i have some Dymond 3S-2250mA 18C lipos weight 191gr, can i use these for the F16 or is it too heavy?
Old 07-15-2008, 03:53 AM
  #32
jakcharles
My Feedback: (10)
Ok I have a question my phase 3 F-16 flys great and I luv it. But I was flying it this weekend and came out of a dive haulling butt and all of a sudden the motor stopped but I still was able to land it. I touched the ESC and it was burning up. I am running a 3s 2200 mah battery and was wondering if the motor is still good. I am prepared to buy a new esc but just wanted to see if I have to buy a new motor also. I am kinda new to electrics so can someone help me out.
Old 07-18-2008, 10:33 PM
  #33
friedclutch
ORIGINAL: kingpin112
191g on the battery? NO PORBLEM. My 2250 Lightning power 25C packs weigh in at 208g and launches are still very easy. Must make sure you place the battery into a location where the plane balances ok.
edit... (with the lightning power lipo) I flew for 6 minutes yesterday and only had to put 1300mah back in. I did lots of WOT passes and high alt motor off stalls. Gonna go for 8 min tomorrow and see how much power is used up. I like to complete a turn at half throttle and slowly roll it on to wide open throttle 100 yards before the runway. I like the jet way better than my Stryker C.
Old 07-19-2008, 05:59 AM
  #34
kingpin112
Well, i ordered a Phase 3 EF-16.
Config:
- 3S-2250mA 18C Dymond lipo
- Dymond D60 (20Ncm) servos
- Jeti REX 5 MPD Micro receiver
- Stock fan/engine/esc
Old 07-21-2008, 09:40 PM
  #35
hairlip
My Feedback: (65)
hairlip's Avatar
does anybody know what the actual motor size is? What engine (bigger of course) will fit ?
Old 07-29-2008, 08:57 AM
  #36
kingpin112
ORIGINAL: friedclutch
How did you balance your CG with the 208gr lipo?
Other question:
Because of the lipo weight the fan should be mounted on 4cm which i did.
When i mount the exhaust the transparent pipe is larger then the black exhaust (about 3 cm).
Can i cutoff the 3cm from the transparent pipe or should i leave it as it is?
Old 07-30-2008, 02:29 PM
  #37
jbarnes
I just cut mine off. Flys fine.
Old 07-30-2008, 08:38 PM
  #38
friedclutch
I balanced the plane exactly how the instruction said. You will want to place your fan in the futhest back position that they show. The battery can now be adjusted easily to attain correct C.G. Even my really light 1800 mah pack can still be used with the fan in that position.
Old 07-31-2008, 03:28 PM
  #39
kingpin112
I maiden my EF-16 yesterday. I had a big problem to get the plane straight, the ailerons where not correct alaigned (fabric error), so i had to do a lot of trimming to correct this.
But know it's correct, the lipo is almost in the end position of the cockpit.
I leave the end of the pipe at his length, the tube is not as wide as the fan, so it should blast more air in this position as when i make the pipe smaller (wider diameter).
[link=http://ymmv8q.bay.livefilestore.com/y1pcX4G8tnk82KP_1r7hIC01_c91cDZXLRDvLKe_pRyyWSFZo5 feUCOU0uxpa_0iW5f-YAL3G0EdHM/Phase%203%20EF-16%20First%20Flight.wmv?download]Here's also a short movie of it.[/link]
Old 07-31-2008, 04:43 PM
  #40
BaracW
The longer fan tube length could actually adversly effect (although not significantly) the airflow, as it now has to travel a further path to exit. I'd bet, if you trimmed the clear fan tube to just within the end of the tail cone, you'd still have the smaller diameter, but might see a little better performance because of an inch or two less internal travel for the air.
Old 08-03-2008, 07:55 PM
  #41
hairlip
My Feedback: (65)
hairlip's Avatar
OK here is my offering to the foam god.Not flown yet
Old 08-03-2008, 08:03 PM
  #42
hairlip
My Feedback: (65)
hairlip's Avatar
[img][/img]
ID:	1003761   Click image for larger version
Old 08-07-2008, 02:20 AM
  #43
kingpin112
Nice weather yesterday, here are 2 movies of my F-16 and my cousin Kyosho Intruder.
[link=http://ymmv8q.bay.livefilestore.com/y1pncus1yPBnTu1rkpHFdwpZy3x8D2Tuqsz-nzFKLQqgBhlXHa8OlVp9g2eFf3gIDQGfXhGIQkgid0/phase%203%20ef-16%20second%20flight.wmv?download]Phase 3 EF-16[/link]
[link=http://ymmv8q.bay.livefilestore.com/y1pfJAPeHoeMRSixp8ucBDzrVjh9FHrnamPjPFWXdxc0DvjhPd tF1mMKzZxaP6KSLxWWymjTvq2NvM/Kyosho%20Intruder%2006-08-2008.wmv?download]Kyosho Intruder[/link]
Old 08-07-2008, 05:44 AM
  #44
BaracW
Anybody added the LED afterburner kits? I have been considering the one from tinybritelights.com, but not sure if there is better. Any one with some experience with others?
Old 08-09-2008, 06:41 AM
  #45
kingpin112
Just can't stop flying
http://www.youtube.com/watch?v=d_NiVjyjSEA&fmt=18
Old 08-14-2008, 11:06 AM
  #46
MerlinFan
My Feedback: (27)
Here's mine.
ID:	1011408   Click image for larger version
Old 08-14-2008, 11:11 AM
  #47
MerlinFan
My Feedback: (27)
http://www.youtube.com/watch?v=rFrHt5nFF7k I have a flycam one.
Old 08-20-2008, 07:17 AM
  #48
skrez
My Feedback: (15)
Hi Guys,
I have been thinking about getting one of these for my 1st jet. Can I run this stock using TP extreme3s 2070 and v 3s2200 packs or do I need to increase the size of the esc. to a 40 amp?
Regards,
Frank
Old 08-20-2008, 09:23 AM
  #49
BaracW
I am no expert, as I have only just got mine to flying status, however, stock specs call for a 3S battery in the 1800-2200mah range. I'd say if they are 15C or better, you should be in good shape as is. You'd only need to change the ESC if you swapped motor or fan to a higher amp drawing combination. Stock, from my research, draws about 24 amps max.
Old 08-30-2008, 09:49 AM
  #50
kingpin112
Crashed mine last week, didn't know what cause the failure, the plane went suddenly up and down when i flew about 2 meters high, very strange.
Repaired it today and looks good after repair.
Measured all electronics and went for a test.
suddenly the plane begins to burn !!! ... caused ... ESC
I think the ESC was the failure when the plane came down, bad for now is that my plane has been destroyed.
