FUNJET
#1101
ORIGINAL: jriley1974
I have FJ with 4S 2600 and HET 2w-20... what prop should I use? thx.
I usually run mine with a 4.5 by 4.1 APC prop, with a 2500mah pack the funjet is light and nimble and plenty fast.Your battery will be fine if its a high quality cell, if its a HK/HC pack then no guarantees, speed costs and you get what you pay for when it comes to electronics, batteries especially.
#1102
CO
ya go with what he said 5.1x4.5 my be to much I have never ran the 2w-20 just the 2w
I tend to go bigger on the props and batt's being i am just over 5000 feet and it's hot dry air
I run hot set up's so I also can't fly when the temp is over 70f
if you have a watt meter play with that and some props and watch the amp's to the motor and if you go over the amp's rated for the motor watch the heat and remember to throttle manage
#1103
WA
Flew it with square 4.75 prop but with very short bursts, which I will only do till I get my wattmeter. Batteries are new too so just breakin' them in. What Mega or ARC motors do you guys recommend? Have you guys tried the HC/HK 2836 3200kv?
#1105
WA
Got a 3S setup already on another FJ, which I like to fly more.
This 4S one is my speed fix - just got to find the right prop and battery combination. So far my HET setup gives me 5 minutes of conservative flying with good battery reserve. I'm happy with its speed of about 100mph+, would be nice to have another minute or two flight time with out weighing it down to much.
#1108
ORIGINAL: blkz2801
Is anyone bungee launching their FJ? And if so, how are you doing it?
http://www.rcgroups.com/forums/showthread.php?t=33639
#1109
CO
nice info on the bungee being my funjet weighs in at 3 1/2 pounds and 4 with motor cooler i made
heres a test video
http://www.youtube.com/user/b1bman#p/u/13/Kz6KO5yFtqw
and one with it in the plane
http://www.youtube.com/user/b1bman#p/u/12/Y-QkdBz6xoQ
heres a test video
#1111
SC
Were can I get a 4.75x4.75 carbon prop?
Cp
#1112
SC
Just to give you guys a heads up
MicroDan has a motor that will work on reg. ESC. By that I mean in the past if you run 4 cells or more you had to have a ESC with a switch rate of 16 hz.
So he now has one that will work at least with a scorpion brand ESC ( I used a 90 amp)
Numbers
2700kv...... out runner.....stronger mags. then in his current motors...reduced number of mags. on bell.......different wire pattern....with prop on the motor it clicks to each mag. field
makes a very cool sound when it free wheels ( high whine )
4 cells Turnigy 2650 30-40 c 10% used
APC 5.5x4.5 prop
amps 59 -60
watts 750 -800
weight less then 2 oz
Field tested on site using my FunJet...No radar but est speed around 125 mph with tested APC prop unlimited vert...does not slow down at all
Switched motor last night onto Stryker test bed will fly this am as it's due to hit 100 here today
Video to be shot this weekend
So we now have a 60 -70 dollar motor.... lite weight.... will run on 4 cells maybe more...and you can use your ESC not e-flight brand which is limited to 60 amps.
GREAT customer service...will make you a custom motor if you want....Oh and Dan uses perm sealed bearings
STAY TUNED FOR UPDATES!!!!!!!
Chippedprop
Numbers
APC 5.5x4.5 prop
amps 59 -60
watts 750 -800
Chippedprop
#1115
SC
ORIGINAL: picard1
So who is this microdan and how can I contact him?
This is his website
http://www.gobrushless.com/shop/
Great motors for a FJ I helped develop the 2900kv which must have a ESC that will switch at 16hz...like a e-flite 60 amp which means your limited to 60 amps......which is why he is developing a new line of motors.......I think this new one may be able to go to a higher cell count........testing will find out.
#1116
The HET 2W20 is only 60 bucks and pushes 130-135mph on 4s2600 40c packs with a regular ol 80A esc, runs around 850-900 watts at this level. With a 2500 30c pack its at 125mph.
#1118
MD
I realized i need a light set-up because my landing area (back yard) is through a couple of trees and then about 90' of grass...
So, what I would like is a 3S set up with the potential to throw in a 4S (and a BEC) if I go to the local field with my larger birds.
I was leaning towards the Typhoon 2W-20 and a 4.75 x 4.75 prop.
I wanted to run it past you guys before i ordered it... Is the Mega 16/15/3 a much better motor and worth the extra 35$
On either motor if I went to the 4S what prop and ESC would you all recommend, I don't need "insane" speed b/c I'm NOT "beefing-up" the planes structure...
Sorry, one more question... Specific battery sizes/manufactures that do and don't fit 3S and 4S?
Thanks ahead of time!
#1121
SC
Hey guys
I've been out of the loop lately....here's what I've been working on
A new motor from MicroDan which WILL work with ANY ESC...it's not ready for production YET..but will be shortly
Check it out on my draggy Stryker.....I have run 1 time on the funjet...est. speed in the 110 to 120 range
http://www.youtube.com/watch?v=ZJh1MTM2S-0
Cp
Cp
#1122
TX
ORIGINAL: greggK
Thanks blkz,
What size ESC on the 4S
Thanks blkz,
I had the Turnigy plush 80 amp ESC, worked great. I kind of miss that setup. I now how a 5S setup from the guys from RC Foam Fighters
#1123
SC
#1124
NC
chippedprop
Were you attending yesterday?
http://news.yahoo.com/video/greenvil...video=21816991
I thought I saw you waving in the video.
Just kidding.
Gryphon
Just kidding.
Gryphon
