Echo BME twin
Old 01-06-2008 | 01:33 PM
  #276
av8tor1977's Avatar
Default RE: Echo BME twin
Found some more pics. Like they say "...a thousand words..."
AV8TOR
ID:	843876   Click image for larger version
Old 01-06-2008 | 02:12 PM
  #277
av8tor1977's Avatar
One thing that doesn't show in the pics is the smoke oil injector I made out of a 1/8" male pipe thread x 1/8" compression tube brass fitting and a short length of 1/8" copper tubing. The two mufflers somewhat spread apart, with each having dual exits makes a neat smoke trail...
AV8TOR
Old 01-06-2008 | 02:20 PM
  #278
AV8TOR: Nice Photos of making mufflers. I noticed on your prop hub several small holes. Are they for set screws? Thanks Capt,n
Old 01-06-2008 | 03:50 PM
  #279
av8tor1977's Avatar
Hi Captain, and thanks!
Yes, I went ahead and put some set screws on the collar where it goes over the crank. The crank has been converted to right hand threads as you know, and I've never had problems with prop adapters coming loose, but I figured for the few minutes work to add the set screws, the added security was worth it, especially since this engine is double it's original size....
Take care,
AV8TOR
Old 01-06-2008 | 04:44 PM
  #280
RysiuM's Avatar
ORIGINAL: av8tor1977
Thanks for the last picture. This is giving you the idea, that the ulgy looking part (shown on the last picture) can be finished to such nice pro-looking mufflers (shown on the previosus pictures). It is really cool.
Old 01-06-2008 | 07:11 PM
  #281
av8tor1977's Avatar
Thank you Rysium!!
There is a saying that "Genius is 99% perspiration and 1% inspiration."
My saying is that nice work is "99% perspiration & patience, and 1% inspiration!!"
AV8TOR
Old 01-08-2008 | 12:49 PM
  #282
Ralphbf's Avatar
My Feedback: (27)
I went to the bearing house to pick up a front bearing, a 6901rs, they want $45.00 a piece.
Does anyone know of a better place to buy one?
Old 01-08-2008 | 01:01 PM
  #283
RysiuM's Avatar
I used Boca Bearing: http://www.bocabearings.com/main1.as...ksearchbearing
and VXB Bearing: http://www.vxb.com/Merchant2/merchant.mvc?Screen=SRCH
Old 01-08-2008 | 01:11 PM
  #284
Ris...Thanks very much for the Boca bearing shortcut. Best Regadrs Capt,n
Old 02-01-2008 | 02:01 PM
  #285
what models does the reed cage from? i found a few homelite reeds on ebay and was hoping that a few of them would do
Old 02-01-2008 | 05:56 PM
  #286
tim220225's Avatar
XL series saws. The reed assembly is like a pyramid with 4 petals. These were or are also used on the 61cc Echo twin conversions some of us have done.
Old 02-24-2008 | 12:33 PM
  #287
ORIGINAL: jlew
WELL I GOT IT RUNING.IT STILL NEED SOME TUNING AND ANOTHER IGNITION . I MADE THIS ONE AND IT WAS FOR A SINGLE,SO I ADDED ANOTHER CAPACITOR AND COIL TO START THE TWIN AND IT BREAKS DOWN HERE AND THERE.I HAVENT CHECKED THE RPMS YET BUT IT WILL SURE IDLE AT A LOW RPM.I HAVE A 22-8 BAMBULA PROP ON IT......HERES A LINK TO A VIDEO .DONT MIND MY TEST STAND THIS IS ONE OF MY BETTER ONES
http://www.rcuvideos.com/item/4K0FY37PQS559N25
I FIXED THE LINK SO IT WOULD WORK AGAIN
Old 03-22-2008 | 02:22 AM
  #288
Ralphbf's Avatar
My Feedback: (27)
This is a little off topic but I just got my 62cc Echo twin running.
http://www.rcuvideos.com/item/80HMB3SYWNYB42GR
I just wanted to share it with the group.
Old 03-22-2008 | 03:09 AM
  #289
av8tor1977's Avatar
Nice Ralph. You make me want to get after mine... One of these days... How about some nice close up pics??
Nice job on your twin too jlew. What rpms do you get with that prop?
AV8TOR
Old 03-22-2008 | 11:32 AM
  #290
Ralphbf's Avatar
My Feedback: (27)
I've started off with a 22x8 APC and she is still pretty rich on the top end.
I now have about 1 1/2 quarts through it and will put another quart in it before I adjust the high side.
If I just idle it it hardly gets warm to the touch.
It like a few drops of fuel to start when cold, but hand starts much easier than my G-62.
I'll have some numbers soon.
Ralph at rcignitions is selling ignitions for these for $75.00 with a lifetime guarenty, that includes crashes.
Gas-Glow is pretty cool stuff but I've never had an engine idle like this does.
You can count the rpm by the exhaust.
I purchased 2 more ignitions for my other twins and hope to sell off a couple of running engins to recoupe
some cash for other projects.
I just purchased a one of a kind Bellanca like the Miss Veedol in this months AMA mag.
It's the Miss Columbia. 2 weeks after the Linberg flight, Miss Columbia flew from New York to Berlin non-stop.
She has 150" wing spand.
The plane is about 80% complete, and I fell in love with her the 1st time I saw her.
I may have her ready for the Scale Masters coming up .... well just maybe.
ID:	910391   Click image for larger version
Old 03-22-2008 | 11:47 AM
  #291
buck1856's Avatar
My Feedback: (49)
great sounding.Im going to have to get mine done.Planning on putting it in a 101" Byrons T-6 i have all built up,no glass or primer yet,just built.
Old 04-22-2008 | 06:54 PM
  #292
does anybody have a spare reed cage lying around? i cant find one for the life of me.
Old 04-23-2008 | 12:11 AM
  #293
Ralphbf's Avatar
My Feedback: (27)
There is a reed cage for sell on E*ay.
The trick thing to do is make your own reeds out of shim stock.
search using Super XL reed
Old 04-23-2008 | 06:47 AM
  #294
can you pm me a link? i cant find it
Old 04-23-2008 | 02:10 PM
  #295
Ralphbf's Avatar
My Feedback: (27)
It's gone now.
Just keep checking, Outdoor Power Equipment > Chainsaws > Parts & Accessories.
They come up from time to time
Old 04-23-2008 | 09:36 PM
  #296
what thickness are the reeds or at least the thickness of the shim stock i should use?
any drawings of the shims i can go by?
Old 05-23-2008 | 02:10 AM
  #297
My Feedback: (15)
Does anyone have a BME echo twin crankcase they would like to sell or trade.
Thanks,, motorhd
Old 05-27-2008 | 10:34 PM
  #298
Good luck, I couldn't find one last year after begging for several months.
Old 05-28-2008 | 12:16 AM
  #299
Ralphbf's Avatar
My Feedback: (27)
Guys this is just one of those projects that is just so cool
that no one in their right mind would give it up even if you didn't plan to do it for years.
I ran mine on gas - glow and it ran good.
I purchased an ignition for it from rcignitions for $75.00 and it runs even better.
Sorry
Old 05-28-2008 | 12:21 AM
  #300
buck1856's Avatar
My Feedback: (49)
I stopped asking and begging after i talked to every person i think that bought at least 2.I started asking shortly after the first page.Somone said a person in California bought the rest with another person and the 2 where going to produce some twins.But they had a falling out or somthing.I wish they would come forward or somone could find out who it was and if theyd be willing to part with what they had left to at least break even and give the rest of us a chance.
