New Evolution 10cc gas engine
Old 07-23-2013 | 03:27 PM
  #1551
dwreel's Avatar
Default RE: New Evolution 10cc gas engine
When I fly I watch the airplane. A few years ago I glanced at the T/X and when I looked up the plane wasn't where I thought it should be. I was lucky, and spotted it before something bad happened.
Old 07-23-2013 | 03:36 PM
  #1552
Falcon6667's Avatar
ORIGINAL: Franco2fly
You don't know what your missing I adjust peak within a <div>Couple hundred RPM both top end and bottom. You can </div><div>also see the differences in the air but it takes many flights. </div><div>I've been using Vess and Zoar props. I have more time</div><div>on the 15cc engines than on the 10cc</div>
does the 15 have the same bolt pattern as the 10? what is the 15 turning for a prop?
Old 07-23-2013 | 06:26 PM
  #1553
hold the transmitter up eye level that way u can see the plane and transmitter
Old 07-23-2013 | 07:42 PM
  #1554
Is there a dedicated thread to the 15cc. I'm curious as to what<div>RPM and prop people are settling on? I've gone from Vess 14/6</div><div>to Vess 13x8 but find that needle setting is very critical. I mean</div><div>one click can make a difference in solid run or in flight quit. Is</div><div>This normal?</div>
Are you using muffler pressure to your fuel tank.Must do this on the EVO engine.
BCCHI
Old 07-24-2013 | 03:52 AM
  #1555
Yes I use muffler pressure same bolt pattern but a few mm's wider. And telemetry is nearly<div>Useless without the iPhone interface I listen to spoken altitude and airspeed AFTER I have</div><div>Everything sweet. During initial runs I listen to temp and RPMs as well</div><div>As rx voltage. I NEVER take my eyes off the plane. A tip here, you want to keep the dongle</div><div>away from your body for best reception. I'm using one of those jogger arm bands and</div><div>a single earphone. </div>
Old 08-11-2013 | 07:43 AM
  #1556
Hi guys,
just after I ordered the 10gx I noticed on the manual that gasoline with octane 87-93 is to be used, the only problem is that here in Europe (ch, de, fr, au) the lowest octane possible is 95....
so, is anyone flying it on 95, any issues I should expect because of it?!
many thanks,
dorin
Old 08-11-2013 | 07:58 AM
  #1557
Is you octane measured/rated by the same standards ours is? Here in the states, it would just be a waste of money running anything higher than required.
Old 08-11-2013 | 08:16 AM
  #1558
flyinwalenda's Avatar
I run AV Gas that is 100 octane low lead. I use it more for the lack of smell.stench versus vehicle gas. No difference in performance.
Old 08-12-2013 | 09:32 AM
  #1559
not the same bolt pattern.
14x8 is what I'm using on the 90 currently. I'd go higher however I'm already mowing grass with the 14
Old 08-12-2013 | 05:16 PM
  #1560
CiprianGugu's Avatar
My Feedback: (17)
Originally Posted by dorin_boca
Hi guys,
many thanks,
dorin
Dorin,
In Europe gasoline is rated differently than here in the states. 95 over there is like 87 or close to it. Use 95 and you will be fine.
Old 08-13-2013 | 06:25 AM
  #1561
My Feedback: (17)
Found this information on US vs. European Octane ratings that seems to be consistent.
USA (AKI/PON) --- Europe (RON)
87 = 91
89 = 93
91 = 95
93 = 98
Old 08-13-2013 | 06:34 AM
  #1562
Many thanks for all the replies! Can't wait for the weekend to see it flying!
Old 08-14-2013 | 07:29 AM
  #1563
I was trying to tune my 10cc today and it was very sluggish at idle. I wound in on the low idle until it was nearly closed and I got excellent response from idle to full noise with 10x8 prop. Very responsive however Im a bit concerned though as manual says 5 3/8 turned out from closed I cant get that many turns on the screw. What am I doing wrong?
Old 08-15-2013 | 07:09 AM
  #1564
Is it new? Assuming it is since you are using the 10x8. Break it in per the instructions, move to a recommended prop like the 12x8 and then get the tuning right.
If its not new, I'm not really sure and will let others respond. The low speed needle shouldn't have needed much turning from the stock location. The high speed needle does need some adjustment.
Old 08-15-2013 | 08:11 AM
  #1565
My Feedback: (19)
I'm setting up one of the 10cc engines for a friend. I have many years experience with larger gassers but this will be the first with these smaller gas engines. Has anyone used any sort of Pitts muffler on this engine? I can make the stock muffler fit but it will require considerable cowl cutting and an extension to get the exhaust out of the cowl. A Pitts would resolve all these issues. I'm open to any suggestions.
Old 08-15-2013 | 08:47 AM
  #1566
rhd-RCU's Avatar
My Feedback: (36)
A pitts for the OS 50 series will work.
Old 08-15-2013 | 08:49 AM
  #1567
My Feedback: (19)
thanks
Old 08-15-2013 | 11:43 PM
  #1568
Thanks mate ill do that yeah it was new. Just bloody was skipping and so sluggish I thought it was going to fall out of the ski. Was like a two stroke with power band LOL
Old 08-16-2013 | 09:18 PM
  #1569
Originally Posted by Pete Bergstrom
Yes I did do some testing with this and my experience was that the plugs lasted only about a 1/2 hour of running. It has been a little while and others may be having better experience with this. We also experimented for a while with standard glow plugs and E85 gas with some success but again had a plug longevity problem. In the end we like the ability to control exactly the ignition point with the electronic ignition.
That has been my luck with the gas glo thing,gave up on that about 30 years ago.
BCCHI.The old C&H guy.
Old 08-20-2013 | 12:49 AM
  #1570
Hi guys,
I finally finished installing the Evo10 on an ESM Iconic XL when I noticed it is way too nose heavy, so now I have to take the ignition unit from under the firewall and place it inside the fuselage.
Now THE question is how close to a servo or receiver can it be placed? I will power everything with a 2s LiPo with an IBEF from troybuildmodels.
Are the current ignition modules noisy as they used to be? I found lots of post pretty much predicting crash on what I want to do, but latest one is dated 2008...
Many thanks for suggestions
Dorin
Old 08-23-2013 | 07:02 AM
  #1571
Hi Dorin,
Not sure if you've gotten your question answered, but the best and safest way to ensure that you're not too close to the Rx with the ignition is to do a range check with the engine RUNNING. This way if there's any noise interfering you should be able to see it before you're in the air. You should always try to keep it as far as you can from the Rx, but the unit is decently well shielded. The spark plug high voltage wire is more prone to causing inference so try to keep that away from other electronics if you can.
Jimmy
Old 08-24-2013 | 05:37 PM
  #1572
I had trouble keeping the ignition wire on the spark plug. I finally gave up and used safety wire to ensure the spark plug wire stays in place. I have completed break-in runs on my Evo-10 cc gasser but have not had my maiden flight on the new Pheonix Spitfire as yet.
Best wishes and good safe flying.
Heli-NuBee (AKA Roger the radial rabbit)
Old 08-25-2013 | 11:36 AM
  #1573
Engine should still be under warranty no?
Bill S.
Old 08-26-2013 | 01:52 PM
  #1574
just because your in Russia, why would the warranty not apply??
Bought on a gray market? No dealers there?
Too bad, good luck with it!
Bill S.
Old 08-28-2013 | 07:22 AM
  #1575
Castrol Actevo is not the best oil for this engine (petroleum based) . After new parts installed, try a full synthetic good quality oil.
Best regards
