DL-50 engine
Old 05-01-2008 | 04:05 AM
  #1676
Default RE: DL-50 engine
ORIGINAL: paulflys4fun
Right after making a prat of myself thought i would try and ask another question. Got the DL to tickover at 1,900 rpm, and rev upto 7,000rpm. The only thing is that at throttle shut on the tx i get 1,900 rpm, at 1/4 throttle i get 6,800 rpm, at full throttle i get 7,000rpm. What do you lads do to make the throttle curve more useable?
If you have a JR tx, use a throttle curve and move 'point 3' to 30% leave everything else as it was, should be bang on.
Old 05-01-2008 | 04:58 AM
  #1677
Bob Pastorello's Avatar
My Feedback: (198)
Regarding throttle/carb non-linearity.... another point to consider. The relationship of the take-off points at the servo and the carb arm. The DL's I've gotten have a fiber "arm" that can be installed on the carb, or (as I've done) modify the throttle butterfly shaft to take the blue aluminum arm that comes in Hitec servos that can't be used for real control surfaces. That makes the take off point on the carb to be roughly 5/8" from center.
Then, on the servo, use an arm of 3/4", and adjust it so that the arm is moving nearly straight during the idle and low throttle movements (for those not familiar, this is "mechanical expo and differential").
When setup this way, there is very good resolution and sensitivity of response from the engine at the very low stick movements (desired), while becoming somewhat "numb" toward the top 1/3rd of stick travel (also desired).
Then, apply the curve/mix from the TX features to fine tune.
For many, this will be way too much work, energy, time, and effort, and will require too much planning..... for those, you'll never be happy with the response of these engines and carbs. They simply are not linear at all, nor sensitive enough where we need them to be.
Old 05-01-2008 | 11:37 AM
  #1678
Hi,
I still have the old engine mount stand off, and would like to replace for the new one. How long are they, 3"? Let me know. I have the engine on a GP Yak 54 and it's tail heavy so 3" will good for me to balance. Anybody else use the GP Yak. not a bad plane but not much clearance for the prop. I broke a prop last year because of the soft landing gear, it flex a lot.
Eric
Old 05-01-2008 | 07:20 PM
  #1679
My Feedback: (114)
another picture of the new one
Old 05-01-2008 | 07:43 PM
  #1680
I notice on the ignition it says SV
I think this is one of those SV or HH motors from China, not a DL.
Old 05-01-2008 | 08:10 PM
  #1681
Yea, I agree. Just checked DL usa web page, did not see any mention of a version 3 for the DL 50. I think if their really was, those guys would be one of the firsts to let us know!
Old 05-01-2008 | 08:23 PM
  #1682
Has SV / HH / LSPRO or what ever brand you want to choose colouring, and prop bolt pattern, crankcase style etc
I would say its a new version SV 50, but not a new DL50
Old 05-01-2008 | 09:32 PM
  #1683
Ralphbf's Avatar
My Feedback: (27)
What's funny is they are using the reed off a Homelite Super XL.
I know because it's the same reed as the 48cc BME twins use.
Old 05-02-2008 | 06:58 AM
  #1684
Sorry for the delay in responce but the pictures are direct from the manifacturer. SV engines claims to be the manifacturer of he DL Engine Line and is producing both the DL50 V3 and DL100.
They have the DL50V2 but have claimed to have inproved it by changing reed valves for more power and changing the case to fit internal changes to lower vibration. it also looks more like a DA. I did not ask why they changed from 4 to six bolt pattern.
I have both a DL100 and DL50V3 on the way for testing and if all goes well the Planes will be ready to take to Joe Nall for all to see.
ID:	941324   Click image for larger version
ID:	941325   Click image for larger version
Old 05-02-2008 | 08:07 AM
  #1685
pupmeister's Avatar
Although anything is possible, and admittedly the pictures of the DL100 on DLEnginesAustralia and DLUSA are most probably of one of the prototypes of the engine, the engine shown in PerFlight's post is very different to the engines shown on these web pages. Besides the obvious difference of the milled / cast engine case, the prob hub and engine mount are also vastly different.
Cheers
Pupmeister
From DLEnginesAustralia
and from the previous post
Old 05-02-2008 | 08:32 AM
  #1686
My Feedback: (114)
The SV version looks better .
Old 05-02-2008 | 08:51 AM
  #1687
Notice the DL100 is version 2 could your picture be version 1? the DL50 V2 has webing also on the front of the case.
Old 05-02-2008 | 09:28 AM
  #1688
Maybee the guys from DL USA could chime in here and let us know what really is going on. I read in this thread to be carefull of who you are buying a DL, some were 2nd hand refurbs being sold. I would not buy one unless it was from DL USA, this way you know it is the real deal, and you know it has been checked, has warranty and support. If their really is a version 3 then swee!!!!
Old 05-02-2008 | 10:45 AM
  #1689
tomyrcmodels's Avatar
I agree if SV group are said that New 50CC engine are the one they do modify from DL-50 v2 and make some improvment . but claims tha DL engine are made by them? I dont think it's true. I know the guy who made DL engine , his Chinese name is Dong Lin. that's why the engine call DL .like DA are from Desert Aircraft . as an friend of DL. we build the cylinder parts in the same factory (made 3mm cylinder too) . so only things I can think is SV group make copy from DL( see the cyclinder have no mark of DL. and all DL cylinder should have the DL-50 MARK on it) and try to confuse everyone who know the big name of DL but SV. it's cross of my main how ever. if this New SV engine are as good as it look, donts matter it's us DL brand or SV brand or any other brand , it's will be good for the people who like to buy because SV always have advantage about low price for sure , ha ha ")
Old 05-02-2008 | 12:10 PM
  #1690
FlyingGreg's Avatar
I have a version 2 (?) and am very pleased. I think its' a stretch to think DL would come out with a new version and not sing it's praises. This whole business sounds fishy to me.
Old 05-02-2008 | 01:34 PM
  #1691
Mitsu1's Avatar
My Feedback: (13)
I think Tomy explained it pretty clearly. [)]
Old 05-02-2008 | 02:41 PM
  #1692
My Feedback: (13)
Greetings all,
In reference to the "DL50 V3" pictured in previous posts:
The pictured engines are NOT, repeat NOT DL engines. It appears that they may be prototypes of engines made by SV or whoever, using some of the parts from the DL engines but with different crankcases. Also, SV does NOT, repeat NOT manufacture any part of the DL engines.
Regards,
Bob
www.dlusa.net
Old 05-02-2008 | 02:48 PM
  #1693
jacklegchris's Avatar
I just Googled SV and found a picture of the above engine at http://www.unitedhobbies.com/UNITEDH...idProduct=5732. There you go.
Old 05-02-2008 | 02:53 PM
  #1694
FlyingGreg's Avatar
It is as I thought, Watsona factual error.
Old 05-02-2008 | 04:49 PM
  #1695
Just as I thought also. Dont know or read much about the SV engines or if they are any good? Seems like something in the back of my mind is telling me to stay away from SV.
Old 05-02-2008 | 07:43 PM
  #1696
We can also confirm it is NOT a DL Engine.
We have an email from DongLin of DL confirming so. And also that SV do not make parts for DL, and they have not directly sold DL parts to SV either.
Cheers
Scott
DL Engines Australia
Old 05-02-2008 | 08:21 PM
  #1697
Mitsu1's Avatar
My Feedback: (13)
It does appear DL's cylinder supplier has not made DL it's exclusive client. [&o]
Old 05-02-2008 | 08:33 PM
  #1698
Also in his pics it states its a CM6 plug, looks to me more like a 14mm plug that SV use, not a 10mm CM6.
Possibly just the photo angle, but looks like the standard bigger stick through the cowl plugs that SV use with thier engines also.
Old 05-02-2008 | 09:20 PM
  #1699
just confirm from Mr Dong, the DL has no V3, Now are all V2, he told us that someone just want to copy his engine. and that thing is true that DL100 V1 has not come, but will be soon. So why shows a DL100 V2???
Old 05-02-2008 | 09:55 PM
  #1700
Whistling Death's Avatar
ORIGINAL: bobkra
Greetings all,
Regards,
Bob
www.dlusa.net
Thank goodness SV doesn't make DL engines. It is just my opinion but I think SV engines are inferior to DLs.
