Evolution 26GT2...Good bye you JUNK.
#51
ORIGINAL: 540horses
i disagree,i have never seen several statements in a row saying my da,my 3w,my zenoah is a real piece of junk. you only hear it from time to time. companys carryover basic design and technology in the artery of design they are on. if its bad ideas you can condemn the whole line. taking glow technology and converting to gas as a dedicated gasser is a bad idea. the engines reputation proves this fact.
ORIGINAL: rslstft
You could probably get any engine brand going on a subject like this and get those who love them and those who wouldn't even use it for a fishing weight. I've never had a Evolution glow, but finally stepped up to gas recently and purchased a Evo 26 and 35. I absolutely love them both, very minor tuning and both start with only a couple of flips when cold and usually with 1 flip on the prop after warmed up. I can consistently get the idle down low enough where is seems you can watch the prop tick over. Little too low for comfort, but it WILL idle there. Power seems to be good and am still experimenting with different props. To condem an entire line of engines just doesn't seem logical, but everyone is entitled to their opinion.
Russ
Russ
#53
My Feedback: (13)
hay jbarnes,
What wooden props will be best all around size, for the Evo 26 ?
What would you recomend for my first flights ?
I used a wood symitar style prop on my G90 with good results. I'm scared to use composit or plastic props...and I know how to fine balance my wood props.
I got my P-6E in two day's ago...and what a beautiful model. It's huge, and by far my largest r/c model.
Soft Landings always,
Bobby of Maui
Bobby of Maui
#54
Got my first two flights in today with my evolution 26gt2 its running great and never missed a beat . It rely flys my sig cap 231 Great !!!!
I'm using a 16x8 apc prop !! with mobil 2t synthetic oil mixed at 32:1
heard the evolution oil was no good and this stuff was the ticket!!!
#55
ORIGINAL: Bob Paris
hay jbarnes,
Bobby of Maui
hay jbarnes,
Bobby of Maui
#58
ORIGINAL: josh*********
I just mentioned this so you could watch yours and see if you notice any unusual carbon buildup. Good luck with the EVO.
#59
I have never been more dissapointed in a motor than the Evolution 26GTII. A bear to start and will not turn up over 7000 rpm with any prop.
#60
My Feedback: (21)
KY
ORIGINAL: jramirez
What oil / ratio are you running? How have you tuned the motor? What prop make / size? Altitude? Muffler?
#61
FL
no your not wrong. the gtII IS A COMPLETE PIECE OF CRAP. repeated problems across the board again and again by experienced users. look for a string of people saying my zenoahs junk,you wont find such repeated claims on zenoahs. not meaning to insult anyone, but dont waste your money.
#62
The MVVS (or evolution) 26cc is the most powerful engine in it's class, and as such more demanding on it's users, as well as a bit more prone to failures. The comments on RCU do not reflect the real world, since satisfied users do not complain here.
MVVS took all complaints very seriously, and redesigned the engine without any power sacrifice or weight penalty.
I consider it not very fair to bash a brand engine just because some users seem to have problems with it, and just because they shout hard.
I have had a few users complaining, which could be solved by the twist of a srew driver. I also had some serious complaints, which were properly addressed by the factory, eventually leading to the abovementioned redesign. These issues, though present, did not account for an unacceptable percentage of users. The redesign should reduce this even further, whilst keeping the engine in the top of power to weight ratio engines that makes gas engines of this small capacity suitable for 3D flight.
#63
FL
ORIGINAL: pe reivers
#64
AZ
"The MVVS (or evolution) 26cc is the most powerful engine in it's class, and as such more demanding on it's users, as well as a bit more prone to failures. The comments on RCU do not reflect the real world, since satisfied users do not complain here."
#65
I have a 26GT (older version of the GT2) and I love it. runs great. just like ANY other brand of engines/radio/whatever, you can always find someone that "will never own another one".
#66
My Feedback: (68)
ok gents, please keep the attitudes to a minimum.
The reality is there are probably more satisfied users than otherwise and that's ok either way. Not every engine from every manufacturer is going to work no matter what so lets lets those who have had a negative exp speak their peace and the others to move on. I for one have one on the way and the 2 my friend own run like clockwork
#67
not had any issues with my MVVS 26, i had to make slight adjustments to get it to run right, but you should expect to do that to any engine new out of the box.
got ample power in my Showtime 90, i would recommend it to anyone
#68
FL
ok lets talk 26cc power. take zenoah g26pum case and add 12mm wide bearing to the front where the seal was on the marine motors which use only one bearing in front. its the same case for the plane motors which use 2-8mm bearings. machine hub 4 mm for 12mm bearing clearance and extra support. zenoah chung yang full circle stuffed crank for 26cc boats. red coil with fulley hand ported 26puh heli cylinder on .012 copper base gasket. zero drag seal in rear and boost bottle for cars. g26 marine piston with .8mm ring. walbro ported 257 carb. the outward appearance of the motor is stock except for the coil. the last on took 19hrs of sanding, grinding ,polishing but turned a 15x8 k prop at 16,400 rpm reliably. this motor was lost in crashbut working on a new one with g 270 car cylinder which has better ports and will use 29cc stroker crank. will out perform any 26 by a wide margin if you know how to do it. theres nothing more workable then a zenoah
#70
ORIGINAL: 540horses
11 hp at 16400 from a 26cc engine (thats 420 horses per liter) still looks like a standard typical airplane engine to me, allowable on all airfields, albeit a bit expensive when done.
To be honest, I think [link=http://tech.flygsw.org/evolution26review.htm]this report[/link] is more reliable and unbiased.
#71
I have three of these motors and really like them for one main reason, they have a small footprint that allows them to be placed in just about any plane that will accept a 120 four stroke. My opinion is that these motors are reliable and start easily but have two weak points. The chokes are poorly designed (I understand this is fixed in the GX version) and the ignitions prone to failure (two of mine have failed within a 24 month period). Horizon will not warrant the ignitions after the first few months. Not sure if the ignition units have been upgraded, my newest 26 is the GT2.
#72
FL
Hmmm...
ORIGINAL: 540horses
#73
FL
thought i might add that the helicopter cylinder is the same in apearence as the standard g26 air cylinder. motors are made more powerful from the inside. the smallblock chevy with 700hp looks the same as the 200hp version in plain paint. will put on youtube when the next motor is complete for those interested.
#74
My Feedback: (21)
KY
ORIGINAL: 540horses
snip again....my post is for intelligent people. as far as snip -do you know how to modify engines,or just look down on those who do.
#75
FL
the modifications ralph does is improvments in ignition design and he does a great job. the type of performance modifications possible is what i explore. because you never heard of me does not mean im not an authority as well.
