RCGF Engines
yes they are. I covered it in the same pattern as Hazel Sigs clipped wing Cub, except I didn't want blue and white.
this is another picture of it. I was making a pesentation to a nursing home. Had lots of fun with the residents.
that was very kind of you [sm=thumbup.gif]
Regarding the question of a 26cc power.... I am flying a 540 EdgeT Lanier it is an old plane with 14 pounds of weight, I remember that I askhere in RCUwhat kind of propeller to use because the 18x8 was not doing it job,someone recommends to use what they call the best of both worlds 17x8N (APC) 7800rpm and it was the answer to my problems, I’m not a hotdogflyer but I like to do some stuff, not enough powerto do 3D, now I’m flying my Edge 75" 25% with good power that came from my RCGF 26cc,the engine Ihave isone of the older versions with many many hours on it, I bought use it and still good.I have read that this 26cc engine will performgreat between 10 to11 pounds range.<o></o>
on my way to the LHS. I do have a 18/8 APC on hand.
I do agree that the Xoar is a much better quality/performing prop, but IMHO the 18x8 will provide too much load for the engine , so I suggest you use a 17x8.
Karol
Karol
Watch the rpms on these engines they eventually will fail if you over rev them, remember they will unload in flight adding to the peak.They have caged roller bearings in them that have rpm limits.
Always use the recomended prop sizes. If you need more speed, higher rpm's, you should think about a different engine. The new 20cc and 32cc can both rev higher than the 26cc.
Gregg
In what way is it not running smoth?
Check your battery power or it could possibly be caused by the ignition.
Karol
