DLE30!
#5151
Mike,
Hating those expensive lessons (how low can you really go....and survive?).
Re: crank runout, betting if it's bent, it'll be pretty obvious? Thinking .002"-.003" measured at the prop driver, but it's been a while since I messed with one. Wouldn't argue with somebody that has more recent experience.
#5152
ID
Hi you have the prop retaining bolt or nut so to speak and that can bend fairly easy due to impact. The crankshaft itself is another story, Since there just a short snout that pokes it's head out the case from the bearing, which make's it very difficult to bend under the best of circumstances.
However the threaded area can bend in the radius or thread relief, but again is not the end of the world and as a rule can be straightened.
The TIR of the hub shaft and the crankshaft do not always have the same runout,most of the threads are sloppy and I have seen the prop hub run out as far as .008-.009 before on a new engine. Check the actual crankshaft for a true reading not the prop hub shaft.
Anything over .002 warrants some investigation as to why it is that far out, bearings are cheap, replace them with good quality bearings and yes heat will have to be used, that green goop the chinese use is very high heat and a PITA to get loose. Good Luck.
#5153
Hi guys, I see in the manual that DLE recommends using Stihl, but it's not available in my area. Poulan is available here but I didn't see any synthetic for after break in. What else can I use?
ID
All glow engine's have a close fit between the crankshaft and the front housing which needs constant oiling where as the gas engine are not built that way. Most are open with a spacer on the crankshaft between the bearing's to set the end play.
#5162
ID
Most 2 stroke glow engine's won't have seals in the rear bearing's, some of the 4 strokes will.
Gas engines are another story all together, I have had more than my share of them apart and so far the rear bearing always has had the rubber seals, but not all have
seals on the front bearing. If I replace the bearings I always get them with the seals for both front and rear, there is just to much debris then can get in that front bearing W/O them to suite me.
#5164
DaleD
#5169
I'm having a hard time getting my DLE 30 to stay at low idle. I have 2 gal through it so far and changed the plug to a NGK, running a 18x8, am hoping it's just a break in issue. When I blip the throttle it will drop down to low idle but soon after return to a high idle. I don't have a tach yet so I can't tell you the rpm's. Other than that the engine runs great!
Any idea's?
Any idea's?
Any idea's?
Any idea's?
DaleD
#5172
#5173
My Feedback: (17)
drube,
What you describe is a low speed mixture setting. I can't remember for sure whether you have to lean it or richen it. Try leaning it a little at a time, if that doesn't work slow richen it. It won't take much of a change to straighten it out. Maybe someone else can say which direction to go.
Chuck
Chuck
