DLE30!
#1976
ORIGINAL: captinjohn
Ask TOM....Maybe he will write a book on his wonders about the carby venturi![X(]
ORIGINAL: dale691
Has anyone else noticed the venturi problem with the carby. Is a velocity stack the answer?
ROFLMAO!!!!
Ya think he'll publish sequels to the first one?
#1977
CA
I don,t hear that much about blowback on the DLE30cc engines. I never had any on my DLE 30. Capt,n
#1981
One very good way to cure a lot of the spit back is to use a tapered velocity stack anh install a wire mesh screen on the largest intake of the stack. The fuel will be stopped long enough to be drawn back into the engine. I have read that it makes fuel economy better....not sure on that! Its more the way you drive/fly...your mileage may vary.
Hey...where is Antique lately????
#1985
The shovelhead motorcycle engine is one that many custom chopper owners are proud to own. This V-Twin powerhouse was manufactured by Harley Davidson beginning in 1966 and ending in 1985, and reflected refinements from the other types of V-Twin engines Harley had produced such as knucklehead and panhead engines......Capt,n
#1986
OH
The above referenced refinements endeared it to some, and to others it became the "Troublehead"
#1987
ORIGINAL: jedijody
My wife gave me a ration one time for buying an airplane, the next week I went to the casino, blew $300, came home drunk and tried to accost her. She's warmed up to airplanes some.
ORIGINAL: Super08
Speaking of which, seeing as I ordered a Cyberplate from Richard I figured I should get the engine. So I placed an order for one from my dealer. Oh well, now I guess I am going to need another plane. Dang it never ends does it? Can't think of allot of better ways to spend money though, my wife begs to differ.
BC
#1989
bcchi, have you heard from Grumpy lately? I kinda miss that old coot! Capt,n
ADDED Has anyone tried a bud can exhaust on a DLE 30 Yet? http://www.rcuniverse.com/forum/m_73..._1/key_/tm.htm
#1990
BCCHI Got to fly Sat. The Ignition that came with my DL30 took a dump.So I put in a old one I had in the trailer.Built a new Super Ignition for it Sunday.
AMA 2500
#1991
My Feedback: (7)
FL
Lost the ignition on my DLE30 yesterday. I thought using an A123 battery with the battery eliminator was OK the guys at Troy Built say you need to use a voltage regulator also. Just ordered a new CDI and voltage regulator $130 later prblem solved
#1992
How did you lose the ignition system? Did I read this post right? Did I just see 2 ignition failures from 2 different guys. Ok you got to clarify what exactly happened. Was it user error or did the ignition just go south? Please be long winded and spell it out. I have to ask. Still on the fence on which engine I want for the T-craft. It will be either the DLE30 or the Zenoah G26ei. If your ignition failed how many hours do you estimate you had on the engine before failure? Would it be a warranty issue?
P.S. How did we go from the original subject to Harleys, bar stools and blow? LMAO.
Glenn
Glenn
#1993
CA
Guess I am the odd man out. I have run two rcxell ignitions on A123 batteries for two years now, one has about 100 flights and the other about 30. No problems or failures as of yet. I know, I know.
#1994
Ok this question is a little off topic but topic related. Here goes.
1. I have found a wholesaler overseas (alibaba) I can get an engine for a dang good price and the price includes shipping. The savings are substantial.
2. Has anyone here ever done business with them? If so how was the service and how long did it take to get your merchandise here?
I would appreciate any response.
Glenn
[email protected]
Glenn
[email protected]
#1995
ORIGINAL: bcchi
Yes,I talked to him yesterday. He is just hanging out and hiding from the bad guys.
AMA 2500
AMA 2500
#1996
<span style="color: #ff0000">Alibaba is a manufacturer and distributor database, not a vendor for anything, many, many, companies listed there.
</span>
<span style="color: #ff0000">Many people have done this,many with good results, some get burned, it's a roll of the dice and you will have no warranty here in the states. One trip back to China for a warranty
repairand your savings are gone.
</span>
#1997
ORIGINAL: willig10
Glenn
Glenn
#1998
I understand your aim is to get the best price possible (according to your previous post about capitalism at work
) but let's say that your investment gains are likely have have an unacceptable risk associated.Why don't you just bite the bullet and order your engine from Jody?
The time you have already spent (and continue to spend) plus the risk you take. I dare say the engine will cost you more than buying locally
#2000
My Feedback: (55)
ORIGINAL: fitson
Howard
