DLE30 rear induction conversion!
Old 03-18-2010 | 10:53 PM
  #451
PlaneKrazee's Avatar
My Feedback: (14)
Default RE: DLE30 rear induction conversion!
ORIGINAL: Tired Old Man
PlaneK.,
The retaining strips actually permit a more even and consistent reed seal but there's a caveat. On my stock 30 I tossed the reed stop and substituted a retention strip with some real screws. If you leave the bottom edge of the strip square it generates a stress riser in the reed. You should radius the forward bottom edge of reed retainers.
Yes, I agree with the radius. MVVS uses this in thier 58. 8.
The new MT35 uses metal reeds.
Old 03-19-2010 | 12:43 PM
  #452
<span style="font-family: 'Times New Roman'; font-size: medium; "><div style="margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; background-image: initial; background-attachment: initial; background-origin: initial; background-clip: initial; background-color: rgb(255, 255, 255); font-family: Arial; font-size: 12px; background-position: initial initial; background-repeat: initial initial; ">anybody has any idea what is the best advance timing for this engine. I've been playing with it last year and I can't remember where it was first when I bought it! Thanks</div></span>
Old 03-19-2010 | 01:17 PM
  #453
jedijody's Avatar
28* BTDC
Old 03-19-2010 | 01:37 PM
  #454
Old 03-20-2010 | 11:07 AM
  #455
Cyberwolf's Avatar
RC can you tell us what your engine was doing before.
Old 03-20-2010 | 11:19 AM
  #456
My engine couldn't idle less then 2800ish and die right after landing. Last November when it got cold it turned horrible. it kept dieing on first roll! <div>
</div><div>
</div>
Old 03-20-2010 | 08:54 PM
  #457
I'm running mine in a Pilot yak also. I never actually tried to see if the engine would do the tilt and die thing, I just wanted a reliable low idle. Before my best reliable idle was 1900-2000. Now 1600-1700 will putter all day. A plane that floats with a high idle sucks, so this makes me very happy
Before, if I throttled back abruptly, it would sometimes kill the engine, Now I can bounce the throttle up and down with nary a whimper. It seems like the Cyberplate makes the low speed needle less sensitive, and much easier to tune also.
I am running 100LL avgas in mine, as the local fuel is hit and miss. 7800 rpm on 19 by 8 Xoar.
With any luck, tomorrow will be a nice day, and I can actually fly it, I am sure the flame-out on landing will be gone.
Has anyone else found the low end easier to tune? or Is it just my imagination?
Thanks again Richard for a great product
Cheers
R.D.
Old 03-20-2010 | 09:25 PM
  #458
Cyberwolf's Avatar
Hi jfckelly
The low end adjustment was one of the first things that Jody made mention of to me, said that was alot less sensitive, which stands to reason, the bottom end is not in a near flooded state all the time.
I'm pleased you like your assy. These sort of posts almost make it worth the time and effort *L*
Old 03-20-2010 | 09:30 PM
  #459
Super08's Avatar
Richard I put up some pics of my engine with your new backplate in the DLE30 thread if you wish to see them.
Old 03-21-2010 | 08:55 AM
  #460
Cyberwolf's Avatar
Hi Doug
Yes I seen them , very clean set up ,it should be a winner all the way around now.
I like to see very sanitary setups such as yours is.
Richard.
Old 03-24-2010 | 08:22 AM
  #461
Cyberwolf's Avatar
Has anyone else done any testing with the rear carb assembly?
I have had several late comers wanting an assembly, so depending on what happens between now and when I get these finished there might be a chance of another small run of parts.
Old 03-24-2010 | 08:43 AM
  #462
While I'm sitting here waiting "patiently" would some of you "experts" tell us waiters how the install went. Specifically, how the plate installed on the motor. Any suggestions? Cautions? Thanks
Old 03-24-2010 | 08:57 AM
  #463
Perhaps a 5 min video helps.I could have videoed mine. But its too late now.
Old 03-24-2010 | 02:42 PM
  #464
Plug an play just that simple, an makes for easy tuning, mine is running fine. vess 19A 7780 Thank You Richard
Old 03-24-2010 | 04:32 PM
  #465
Cyberwolf's Avatar
There is a set of instructions that comes with the plate assy, its as Hutchi says plug and play or it should be. I'm back out to the shop just popped in for a min and checked mail.
BTW for those of you that are waiting, the progress is going great much better than the first run of parts.
Richard.
Old 03-24-2010 | 04:43 PM
  #466
My Feedback: (14)
Temp 56 degrees, 32% humidity. sea level
30:1 oil, 64 oz of fuel thru it.
Vess 19A 7800 rpm peak.
Added 1 oz of castor to the gallon of Mobil 2T fuel and got 7900 peak.
I'll switch to Pennzoil Air cooled @ 32:1 and see what happens.
Old 03-24-2010 | 08:51 PM
  #467
Plug and Play. Not like Windoz. Really, thanks guys.
Richard, good idea on the instructions. Some of us need em more than others. Thanks
Old 03-24-2010 | 10:06 PM
  #468
Super08's Avatar
With how well Richard has written up the instructions a person would be hard pressed to mess up and do it wrong. Like it has been said it is plug and play. From anyone that has had the chance to run theirs it solves all known issues with the engine.....I just wish it would warm up here so I can run mine. Maybe Sunday.
Old 03-25-2010 | 09:32 AM
  #469
Cyberwolf's Avatar
I can't take all the credit on the instructions, I wrote up a set and sent them off to Jody to refine. So you can thank him.
Old 03-25-2010 | 11:19 AM
  #470
Thanks to both of you!
Jody, thanks for the great service on my ignition module and the complete explanation of the issue. Got it back on and running.
Old 03-25-2010 | 01:09 PM
  #471
My Feedback: (25)
ORIGINAL: Cyberwolf
Richard.
Thanks for the update and glad things are going better for you on this run.Can't wait-but will for my Cyberplate to get done.Thanks for the hard work Richard.
Old 03-25-2010 | 07:37 PM
  #472
Cyberwolf's Avatar
I'm finishing up the outside of the parts now, this is a slow process, but like all things I have found another way to do this faster I hope. This is where a CNC would come in very handy.
Now if I can just get one of my 4 legged kids to get well I'll be in fat city.
What a terrible feeling ,you know there in pain and can't do nothing about it cept take um to the doc and that dosent seem to always work out for the best.
Old 03-25-2010 | 08:27 PM
  #473
My Feedback: (25)
Sorry to hear about your 4 legged kid and understand how hard that is.I feel more for our 4 leeged kids then our grown 2 legged one.Hope all gets better,take your time my engine is not going anywhere.
Old 03-25-2010 | 08:55 PM
  #474
Antique's Avatar
Surprise, surprise, you added oil and got more power...
People still think 100-1 oil is better ????
Old 03-25-2010 | 09:09 PM
  #475
My Feedback: (14)
ORIGINAL: Antique
I was already running at 30:1 Mobil 2T sythetic. Then added 1 oz castor. Mobil is know for very clean burning but higher temps and reduced rpm.
I'm switching to Pennzoil air cooled at 32:1 and see what I get.
