New .90 gas engine (15cc)
Old 10-10-2010, 06:30 AM
  #326
airborne2.4
Default RE: New .90 gas engine (15cc)
ORIGINAL: a1pcfixer
ORIGINAL: airborne2.4
Duct work added?
You want the air entering the cowl, to get directed over the cooling fins on the engine.
Also, more opening for exit is preferred.....as in open the cowl beneath the engine, on the cyl head side.
Again, this is the old cowl I used for my OS .61FX. I did a little cutting for the JBA carb, needle adjustment screw and maybe 1/4'' for the muffler.
Had to turn the muffler and used the Ultra Copper High Temp RTV Silicone to reseal it, I don't think I'll need a pitts . I carefully applied it to the exhaust port, then apply the paper gasket that came with motor (I have watercolor paper that's ticker than this gasket lol lol, have 20+ yrs as an artist under my belt) I also applied the Ultra Copper on the muffler. Forgot to use thread lock on the muffler assembly screw, hence the reason why the muffler has all that goo on it.
ID:	1513811   Click image for larger version
ID:	1513812   Click image for larger version
Old 10-10-2010, 06:42 AM
  #327
skip1320
Sorry to hear Bob,I flew my funtana 40 yesterday,good wing loading at 6 lbs 8 0z RTF,good thing cause i had a dead stick,no problem just tuning,did one more quick flight after checking plane over,will try again today,try to get some video too,good luck!
Old 10-10-2010, 07:42 AM
  #328
airborne2.4
ORIGINAL: Bpar4
Messed up my engine Friday. The lower end of the connecting rod broke and sent my shiney new spinner flying through the air when it stopped. The lower end of the con rod had a piece break off. The bushing insert on the lower end was still on the crank pin and it came off easily when pulled on it. So the bearing hadn't galled. The engine hadn't been run much and I followed the the instructions for the first 15 minutes with an APC 13x9 prop @3,500 rpm.And decided to fly the rest of the break in. The plane took off easily at less than 1/2 throttle and was running with a burble. I had started and stopped the engine several times taxiing the plane around before I got up the gumption to take off. I had flown several laps (six maybe) in the pattern when it stopped. On dis-assembly there were little shards of aluminum all through the crankcase. When I took it apart, the piston and cylinder wall had no marking. So, I think it is ok and just need the rod replaced. Will try to post a pic of the rod later.
Fuel tubing: Try this stuff from Sullivan. It sure makes using small tanks very easy. It is very flexible. Don't know how long it will last, as this is my first use. http://www3.towerhobbies.com/cgi-bin...?&I=LXXWD2&P=7 Unfortunalely, it only comes in two sizes but the small is flexible.
Bob
Sorry to hear about that.
I always use this http://www3.towerhobbies.com/cgi-bin...?&I=LXD739&P=M
Old 10-10-2010, 10:42 AM
  #329
bhoges17
Well my Top Flite P51 65in deadsticked 4x today. Weird since it runs great on the ground. During testing on ground we ran the plane inverted and straight up. During flight it stalls and full throttle about 2mins in. Tried it again on the ground and after 3min ran great. Any clues?
Old 10-10-2010, 10:56 AM
  #330
airborne2.4
LS needle maybe to lean, richen it a little at a time Jody?
Old 10-10-2010, 11:05 AM
  #331
jedijody
jedijody's Avatar
Sounds like a tank, clunk, or clunk line problem. What size is the tank?
Old 10-10-2010, 01:43 PM
  #332
bhoges17
Think the tank is a 420cc. Now if the LS needle off why would that effect the high end? Seems like it runs great from 0-100%. Isnt LS needle just for 0-50%. We are gonna redo the tank line and start from scratch.
Old 10-10-2010, 02:07 PM
  #333
jedijody
jedijody's Avatar
The low speed circuit contributes fuel through the entire RPM range, if large enough (~1/4 turn) adjustments are made to the low speed needle the high speed mixture can be adversely effected. Always finish a tuning session with a re-check of the high speed needle setting.
Old 10-10-2010, 05:34 PM
  #334
skip1320
http://www.youtube.com/watch?v=ZV-DiVffmzk Crappy video! Good wing loading and Power!
Old 10-10-2010, 06:16 PM
  #335
93octane
My Feedback: (9)
ORIGINAL: Bpar4
Bob
Thats not cool..Sorry..could you post some pics of the rod?... just got this engine and Im a little concerned...never saw that happen...Hope mine stays together...Hope yours will be OK
Old 10-10-2010, 08:09 PM
  #336
regets ama
glad to see you got the engine running nicely,,,,,,,,,,,hope you enjoy its performance
Old 10-10-2010, 09:57 PM
  #337
captinjohn
ORIGINAL: skip1320
Good sound....I agree with you on video Quality. Maybe different camera seting would help...or a different camera! Looks like a fun airplane to engine combo. Best Regards Capt,n
Old 10-11-2010, 03:07 AM
  #338
Kostas1
Kostas1's Avatar
ORIGINAL: brockettman
I've got about 90 minutes of run time on my engine. I'm using Poulan synthetic oil @ 20:1. My plan is to finish up the 1/2 gallon I started with, then go to a 32:1 mixture.
I have had very good luck with a 13x8 prop and have achieved a smooth top end at 10,400 rpm. Have not run very long at that rate but it seems to peak out very nicely so far.
Have gotten steady idle rpm of about 2200. Transition has been pretty good if I don't move the throttle too quickly. The engine is in my plane and I haven't done much mid range testing yet. I think I will move to a 14x7 prop, make a few more adjustments, and prepare to do some flying...
Still have quite a bit of blow-by, and I too am going to seal up the muffler... and re-do the muffler gasket.
Hope the snow doesn't come too soon...[X(] Our field is at 7200 ft.
You've got some nice rpm numbers there!
Do you suggest the engine as far as smooth running is concerned?
Old 10-11-2010, 05:24 AM
  #339
airborne2.4
ORIGINAL: skip1320
Yep, crappy video, but it looks like a great combo. What's does it weigh with JBA, ignition, batts etc?
Old 10-11-2010, 05:26 AM
  #340
airborne2.4
ORIGINAL: skip1320
Yep, crappy video, but it looks like a great combo. What does it weigh with JBA, ignition, batts etc?
Old 10-11-2010, 06:19 AM
  #341
skip1320
AUW 6LBS. 8 0z with few ounce,s in tank 2300 6v nimh,rcexell ignition kill,all plugged into 2.4 reciever
Old 10-11-2010, 05:15 PM
  #342
bhoges17
Well we redid the tank today and hope to fly it again tomorrow. With the 15x6prop its running about 8000. The transition is good but at full throttle it does fluctuate from 7800-8300. Its got a good idle and has power all the way though. Yesterday when it would stall in flight it would slowly start to loose power. We richened it up 2x and didnt matter and she still would dead stick. Then when we tested it on the ground it would run great. Each time it stalled in flight it was in level flight at full throttle.
Old 10-11-2010, 05:45 PM
  #343
TestPilot6
ORIGINAL: skip1320
I'm surprised about 6V. Are you talking about 5 AAs? Did you separate the Ignition Power?
Old 10-11-2010, 07:06 PM
  #344
skip1320
A JR 2300ma 6 volt nimh,to a switch and reciever with a y on ignition and rcexell remote kill switch,ch 5 for remote kill,ch 6 for power,bout 35 flight between two planes that way,would probably do the same on my 33% but i need the batt wieght on nose,flew again today,best yet,Thanks for selling a cool product Jody and Regets AMA.
Old 10-11-2010, 07:19 PM
  #345
CGAV8R
CGAV8R's Avatar
ORIGINAL: bhoges17
I know you are saying it's fine on the ground, but that sure sounds like it's overheating in flight.
Aaron D.
Old 10-11-2010, 09:13 PM
  #346
bhoges17
Thats what we thought. We richen it up on both flights and it didnt help. The way we tuned it was to get it to around max rpm and then back it down 400rpm. Think I should prop it down to get the rpms up? With a 15x6 its only doing 8k.
Old 10-11-2010, 09:27 PM
  #347
MercerAUST
Try with the low end rich (as rich as possible, but still reliable idle) and moderate lean on the top end. If this doesn't help, try the opposite. In general, for petrol engines, a rich low end allows you to lean the top end and vice versa. You might also need an hour or two of run time before you can tune out the inconsistent top end.
Old 10-11-2010, 10:04 PM
  #348
bhoges17
It has about 2hrs running already.
Old 10-12-2010, 09:51 PM
  #349
brockettman
brockettman's Avatar
Kostas1,
The engine seems to be very well balanced and has run smoothly for me from low rpm to high rpm. I have not been able to run the engine in several weeks, and probably won't get a chance to for a few more as I'm in the middle of moving.
Can't wait to get some air-time on it... May not be 'till next spring[&o]
Regards
Old 10-17-2010, 09:09 AM
  #350
airborne2.4
Had to reroute my tygon tubing....
The muffler is to close to the firewall.....any idea where I can get a spacer to solve this issue?
I'm still using the APC 14x6. Would a Vess 16x8 be to much for the JBA 15?
ID:	1518286   Click image for larger version
ID:	1518287   Click image for larger version
ID:	1518288   Click image for larger version
ID:	1518289   Click image for larger version
ID:	1518290   Click image for larger version
ID:	1518291   Click image for larger version
