Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 DLE 20cc Gasser! (Data & Links 1st Post) >
Old 10-22-2010 | 07:24 PM
  #1251
w8ye's Avatar
My Feedback: (16)
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
I put mine on a wooden saw horse, it can shake much like the fuselage does.
Old 10-22-2010 | 09:57 PM
  #1252
w8ye's Avatar
My Feedback: (16)
ORIGINAL: karolh
Thinking of putting one of these in an old Great Planes Big Stick 60 and would like to know whereabouts is the best starting location for the CG for best all around flight performance, and also should ALL thrust lines be kept at '0' degrees as specified on the plans.
Karol
Balance on the spar
Everything zero-zero
Old 10-22-2010 | 10:01 PM
  #1253
I have my Ultra Stick set with zero thrust offset, but have a little rudder to throttle mix.
Old 10-22-2010 | 10:03 PM
  #1254
w8ye's Avatar
My Feedback: (16)
With the DLE 20 you may have to put the servos in the tail?
At least you can out the tank on the CG
Use some 3 1/2" wheels
it will need to be a tail dragger to clear the carb?
Old 10-22-2010 | 10:14 PM
  #1255
Oh yes:
At least you can out the tank on the CG,
Yes
Yes:
Carb no, 17 inch prop yes?
Old 10-22-2010 | 10:20 PM
  #1256
w8ye's Avatar
My Feedback: (16)
The Big Sticks from Great Planes come more or less with the intentions of it being a nose wheel plane. The instruction are scant for making it a tail dragger.
Old 10-22-2010 | 10:24 PM
  #1257
The Ultra Sticks have a symmetrical airfoil, no dihedral, bigger control surfaces, lighter weight, tail dragger.
Old 10-22-2010 | 10:32 PM
  #1258
w8ye's Avatar
My Feedback: (16)
I love Ultra Sticks and have flown them for years but you cannot get them right now.
Old 10-22-2010 | 10:35 PM
  #1259
G`Day<div>Am thinking of buying the Pitts wrap around muffler for the DLE20cc gas engine, the Box canister muffler that came with the engine sticks out the side by 1'', does the Pitts muffler stick out less on the side or the same? Needs to go inside the cowl of a P-51 60 size!</div><div> </div><div>Also how much air flow does this engine need to stay cool? </div><div>I have air intake just under the cowl behind the prop. Is this enough?</div><div>
</div><div>dutchy50 </div>
Old 10-23-2010 | 02:15 AM
  #1260
as far as cooling air goes it is not the size of the intake that really maters it is the size of the outlet. you will need about 3 to 1 outlet to inlet
Old 10-23-2010 | 04:40 AM
  #1261
a1pcfixer's Avatar
My Feedback: (7)
This is good for all the larger sticks;
Create a block of wood to put between the fuse & the L-G (1/2" or thicker)
Make it about 3/8" longer in front of & behind L-G. Harden the groove the L-G sits in, then when finished, drill some lightening holes in the L-G groove.
For just a few ounces weight you'll be able to increase your prop-to-ground clearance.
Old 10-23-2010 | 10:21 AM
  #1262
SpinnerRow's Avatar
Stick that pipe and header on there!
Old 10-23-2010 | 04:46 PM
  #1263
Richard D Bahmann aka/Wrongway's Avatar
My Feedback: (42)
My 20 has just passed the one gallon mark...woo hoo... only took like 40 flights...
http://www.youtube.com/watch?v=yDM-U9S2L4A
Old 10-23-2010 | 05:40 PM
  #1264
ORIGINAL: Richard D Bahmann aka/Wrongway
Hi
40 flights ,....................................: ) , that cost you how much ?
Michel
Old 10-23-2010 | 05:50 PM
  #1265
My Feedback: (42)
ORIGINAL: michel gravelle
Hi
Michel
4 dollars in gas and 18 dollars in broken props....
Old 10-23-2010 | 07:31 PM
  #1266
I flew mine once today, huge winds, but that brings me up to 18 flights. No dead sticks, huge power with the Vess 17-6, dare I try a 18-6? It is really fast now, I hate to try a 10 or 12 pitch prop. I really don't think Ultra Sticks are supposed to go this fast. It was cold, about 50F, so the lift and power was very impressive today.
  #1267
[X(]
Old 10-23-2010 | 07:41 PM
  #1268
CGAV8R's Avatar
That little stick on the left will slow it downjust kidding with ya
Aaron D.
Old 10-23-2010 | 08:07 PM
  #1269
My Feedback: (42)
Man I had that 17x8 wind surfing today at idle and two clicks...see vid above....
Can we do thrust reversers?
Hey Mr Hoffman, I had the 18x6 on there already... it was my favorite for my flying....Got 8200 out of it... got some new design 18x6 on order....should spool up to mid 8k....I truly need a bigger plane with this motor....The 17x8 in above vid rarely got over half stick....half stick on my setup is just below half throttle.
Old 10-23-2010 | 08:37 PM
  #1270
The second DLE-20 I have is going on a profile 3D plane, an OMP Razor Yak. What prop is appropriate for it, Vess 19A? This engine is incredible...
Old 10-23-2010 | 08:51 PM
  #1271
My Feedback: (42)
Dont know until someone tries it. I look for as big a prop as I can get and still get spool up....gets me out ot trouble when I need...otherwise give me good airflow over control surfaces when in low power maneuvering.
There are also two schools of thought on prop pitch...on my Saito profiles I love the 4 pitch. 6 and 8 are different feel, maybe for different style. Now on the other hand...I tried a 33x8 on my DA150 Extra....Did not like the run out feel...prop felt done at half throttle....could hover and do pogosticks with it but regular aerobatics were not as much fun...
My guess based on absolutely no info...the 19 might take it out of the power band...
Old 10-23-2010 | 08:56 PM
  #1272
I hear you, one test is worth 1000 opinions!
Old 10-24-2010 | 05:52 AM
  #1273
lazyace's Avatar
My Feedback: (126)
just got a funtana 100 , 81/2 lbs what do you guys think dle 20 ?
Old 10-24-2010 | 08:30 AM
  #1274
ORIGINAL: lazyace
I had a Funtana 125 that I flew with an RCGF/Aeorovate 26cc. They're rated at the same power as the DLE 20 but are 8oz (or so) heavier. At 10.5lbs., it flew great. Take that down to 10lbs even with no loss of power and.... I think that might prove out to be pretty nice?
BTW, APC 18x6w worked really well on that combo. No surprise here if it was found that prop would work well on a lightly loaded DLE 20 as well.... if you have the clearance for that big a prop.
Old 10-24-2010 | 11:43 AM
  #1275
My Feedback: (26)
Most of the discussion about planes for this is engine is about 3D flying. How do you think the DLE 20 wouldwork in the Top Flite P-40 Warhawk ARF .60-.91? I know it's just speculation but I want to hear some opinions.
P-40 Specs
REQUIRES: Engine: .60 - .91 cu in (10 - 15cc) 2-stroke
OR .90 - 1.20 cu in (15 - 20cc) 4-stroke
Distance from firewall to prop: 5-7/8"
Wingspan: 64.5"
Wing Area: 722 sq in
Weight: 9.75 - 10lb
