Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Extreme Flight 87" Yak 54 - Build & Fly
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 03-19-2005, 11:53 AM
  #3376
jrjohn
My Feedback: (24)
Default RE: Extreme Flight 87" Yak 54 - Build & Fly
Please help, What size did ou guys have to drill the holes in the cowl so that the gromets would fit. The plans say 1/8. I doesn't seem like thats possible
JOhn
Old 03-19-2005, 12:22 PM
  #3377
Maudib
My Feedback: (51)
Maudib's Avatar
Well I can't exactly recall... seems to me the odd size like 5/32 or 11/64...
Best way to be happy with your selection is to drill a piece of scrap cowl (maybe fron the coolin cutout) and drill a selection of holes and try them out. You want the grommet to JUST fit the interior, maybe a smidge bigger than the hole.
ORIGINAL: jrjohn
JOhn
Old 03-19-2005, 12:41 PM
  #3378
jrjohn
My Feedback: (24)
David, 11/64 was the charm. I wonder how long these gromets will last before the cowl eats through them. thats usually what happens, and if you don't catch it in time, the screw starts hogging out the hole. I wonder if Chris can tell us where to buy a couple dozen of the white gromets so a guy could change them every couple weeks.l
JOhn
p.s. How you doing???
Old 03-19-2005, 01:01 PM
  #3379
Kregg
My Feedback: (45)
Kregg's Avatar
Some of you guys might be interested in my custom photographic cockpit build thread that I just started. This Yak is a awesome aircraft and deserves a equally awesome cockpit to finish up the presentation. The kit only weights a couple of ounces, so you do not have to worry about that! be sure and get the extra points at your next IMAC competition. Check it out.
http://www.rcuniverse.com/forum/m_27.../anchor/tm.htm
ID:	246074   Click image for larger version
ID:	246075   Click image for larger version
Old 03-19-2005, 01:09 PM
  #3380
jpa2002
My Feedback: (115)
jpa2002's Avatar
jrjohn, would it be a good idea to put a piece of brass tubing through the grommet, and maybe that would help? I have never tried it, but I my do that. Something similar to the way the brass grommets go in our servo rubbers.
Jon
Old 03-19-2005, 01:12 PM
  #3381
jpa2002
My Feedback: (115)
jpa2002's Avatar
Question for you guys using the 4" Tru Turn spinner. I ordered one with a Menz/Mejzlik cut, but I don't have my prop yet, so I was wondering if someone could tell me if the spinner cut looks correct. I would like to be able to run my MSC prop also, and the cut just doesn't look like Tru Turn's pic and it doesn't look big enough to me.
Your help is appreciated!
Jon
Old 03-19-2005, 01:48 PM
  #3382
flyingcrazy
My Feedback: (28)
This is the menz cut .
Old 03-19-2005, 02:02 PM
  #3383
RTK
RTK's Avatar
I do not know what everyone else does, but I always leave my spring attached on the carb just in case of this.
Glad to see it all worked out well.
ORIGINAL: ten pillows
Since we are sharing mishaps... let me share mine. We no sooner than got my Yak in the air then the throttle linkage came disconnected. Fortunately it was at a low speed, so 35 minutes later, when the gas ran out, we dead sticked it in.
Old 03-19-2005, 02:05 PM
  #3384
BBriBro
ORIGINAL: Kregg
That looks fantastic !! I wish I would have seen this before I built mine ! I guess it's never too late to change it
ORIGINAL: jpa2002
That looks like the standard cut. Was the package marked "menz cut" ?
Old 03-19-2005, 02:38 PM
  #3385
jpa2002
My Feedback: (115)
jpa2002's Avatar
Thanks for the photo, that helps. Yep, the package was labeled MENZ. Here is a pic of it.
Jon
Old 03-19-2005, 02:56 PM
  #3386
coche
coche's Avatar
Jon, thats not a menz cut spinner!
ask them to ship you the correct one!
with that cut you wont be able to use the menz prop!
Old 03-19-2005, 03:03 PM
  #3387
coche
coche's Avatar
this is the one you bought!
Old 03-19-2005, 03:05 PM
  #3388
Maudib
My Feedback: (51)
Maudib's Avatar
Kregg, that's really cool lookin... sut I do miss a head to go with that girl pilot...
BBRiBro... does that mean I can have your "old" one?
JrJohn, today is the 4th day of chemo... doing pretty good... not too much sickness from it yet. There will be a steep decline in how I feel in about a week. I have 2 more days of it before the transplant.
Old 03-19-2005, 03:13 PM
  #3389
BBriBro
Maudib, I wouldn't go that far I still like mine, and for the difference in price, I'll probably stick with it. But I am curious what a setup like that costs.
Old 03-19-2005, 06:38 PM
  #3390
rcaviator-RCU
My Feedback: (20)
Old 03-19-2005, 07:36 PM
  #3391
wgeffon
ORIGINAL: jpa2002
Jon
Mine is cut like that and I am using a Menz-S 24x8 with no problem.
Old 03-19-2005, 08:31 PM
  #3392
jrjohn
My Feedback: (24)
ORIGINAL: jpa2002
Jon
jon, I think the gromets get eaten from the outside (the fiberglass) I'm going to epoxy the threads for the first 1/8 inch so the threads can't do any cutting, but again I think it's the fiberglass cutting the gromet. I wonder if anybody else has a fix for this problem
John
Old 03-19-2005, 09:34 PM
  #3393
Mike Parsons
Mike Parsons's Avatar
Just as an FYI I used a 3/16.
-Mike
  #3394
DrFun
DrFun's Avatar
For the cowl mount cut some CA hinges and CA them inside the cowl screw holes. It prevents the screws to eat and crack the cowl.
Of coures you have the rubber gourmets but CA hinges work good as a second means or protecting the cowl.
I learned this trick in RCU and it works.
Old 03-19-2005, 10:49 PM
  #3395
jrjohn
My Feedback: (24)
Cobra, I'd like to see a picture of that if possible
thanks
John
Old 03-19-2005, 10:53 PM
  #3396
jrjohn
My Feedback: (24)
Just wondering how to mount a fuel dot. Are you guys cutting out a big hunk of foam to do it?
or is there another fuel fill system that I'm not aware of?
John
Old 03-19-2005, 10:57 PM
  #3397
turbo4
turbo4's Avatar
anyone using the stock DA muffler without cutting the cowl on the side?(to clear the muffler)
Old 03-19-2005, 10:59 PM
  #3398
wgeffon
John,
My fuel dot is mounted to the side of the cowl.
Old 03-19-2005, 11:16 PM
  #3399
jrjohn
My Feedback: (24)
ORIGINAL: wgeffon
John,
Now I feel dumb for asking, The solutioon was so simple that I couldn't see it!
Wayne, did you epoxy a small piece of wood to the inside of the cowl to give it some strength?
Thanks for the reply
John
Old 03-19-2005, 11:23 PM
  #3400
wgeffon
ORIGINAL: jrjohn
Yes. For strength and because the cowl is thin.
The threads on the dot bottom out before it actually tightens into the cowl. The wood takes care of that.
I wouldnt recomend putting the fuel lines anywhere near the foam. One leak and your gonna have problems.
