Extreme Flight 87" Yak 54 - Build & Fly
#376
PA
RE: Extreme Flight 87" Yak 54 - Build & Fly
really bad case of pneumonia, they drained 2+ liters of fluid from my left side, right side was fine the whole time, odd.
Was in Childrens Hosptial of Philadelphia for 2 weeks.
#377
My Feedback: (51)
Wowser's buddy... glad to hear you're back on your feet again.
I too have had some rough times lately... I recently found out I have Leukemia, started some good meds that are working well and I'll have to get a bone marrow transplant in the next month or so (as soon as they find a donor match). They give me pretty decent odds so I'm looking forward to getting that over with and by then it'll be close to our flying season.
Anywho... nuff of that ole stuff...
More pics guys... more pics! Certainly someone has started building the plane?
#378
My Feedback: (12)
The Landing Gear in the photo is not attached yet, I just sat it in the recess to snap the picture. Inside the plane is a LG plate and some angle aluminum. The mounting bolts go through the aluminum for extra strength.
The Hatch attaches with 4 screws, to at front and two at rear. It also has CF alignment pins at the front that slip through holes in the Bulkhead. Chris said he flies his with only the two rear bolts and the CF pins holding it on.
#381
IL
I'll weight that for you on Saturday at Larry's shop.
ORIGINAL: Maudib
Drew,
I'm curious... how much does the tuned pipe, header, joiner hose & clamps weigh together?
Drew,
#382
IL
Plane is perfect. Not one wrinkle on the covering. For those of you who have the 68" yak, it's just like that but bigger. The ailerons look proportionally larger than the 68". Hole in the fuse is cut for the carb on the DA. Stay tuned. Plane will be done by Saturday w/ video and pictures of the build.
#384
IL
I threw some pictures up on the site
http://extremeflightyak.shutupandfly.com/what's_in_the_box.htm
I put some of Splat's pics up there too.
#386
IL
Not sure, but the stand offs that come w/ the DA will work.
ORIGINAL: Maudib
Awesome Drew... keep up the good work.
And just to confirm... the standoff length required for the DA-50 is 2.5" correct?
#387
Drew,
Chris told us on a post some pages back that the we need 2.5" standoffs, DA always suplies 3.2" standoffs with the engine, but I know that they have shorter standoffs for the 50, I just dont know what lenght are the shorter standoffs that DA has!
I have been trying to reach Desert Aircraft to ask them but the phone has been bussy al day long!
what lenght are the standoffs that you have???
jose
jose
#389
My Feedback: (17)
KY
i have a set of the 2.5 inch stand offs and i need the 3.25 inch stand offs so if any one want to trade each others stad offs let me know i will also take the 3 " stand offs
#392
My Feedback: (51)
They are the posts that distance the engine from the firewall. You order them in the length you need in order to put your prop washer just outside the cowl. If they are too long, you stick out too far... if they are too short you need to add blocks to space them out further. (It also effects balance... somettime you push the engine out a little further on purpose in order to help twith a tailheavy plane... evidently not the case witht eh EF Yak)
In this case, the 2.5" standoffs are just the right.
#394
My Feedback: (51)
Absolutely...
And you can be sure that Chris' template for installing the DA-50 has the correct amount of offset so that the 2.5" standoffs place the spinner in the center of the cowl...
#395
WA
BRRRRRRR!!! 26 deg. 40 mph N.E. wind and 6" of snow with more to come tonight. That still didn't stop me from driving 8 miles to the post office and mail my deposit for the YAK. Now for the wait for the 1st boat.
#396
If you want Fligth Hawk
85 deg, 5mhp NE, blue sky and beautiful beach, the runway is 1000 meters and very good eat and drink, ¿where, in Puerto Vallarta?
#398
Is Chris calling everyone on the waiting list or just the first lucky 20? I have been on the list for close to a year and even called one time to make sure I was still on the list. I haven't received a call yet. ***?
Todd
Todd
#400
My Feedback: (51)
Not sure if he's calling... he sent an e-mail out to those that were on the list asking them to call in with their deposits...
You should call right away!!!
