Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Don Smith Cessna T-50
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 03-20-2013, 05:07 PM
  #1101
rhsmrt50
rhsmrt50's Avatar
Default RE: Don Smith Cessna T-50
....David......here are a couple of photos of the litho plate that I have....
Rich...
ID:	1864668   Click image for larger version
Old 03-20-2013, 05:17 PM
  #1102
rhsmrt50
rhsmrt50's Avatar
Thanks for the complement Steve......I need the encouragement........how is your project going?.........looking forward to the latest photos!!!!
Rich.
Old 03-20-2013, 05:50 PM
  #1103
rhsmrt50
rhsmrt50's Avatar
....David, I like the thought of annealing it.........my plan is to use a thin material to produce the fillets/farings between thefuselage and wing ......they were thin sheet alum attachedto the fuselage only with slot head wood screws..........they simply restedagainst the center section of the wing...........I know the easiest method is to build them up with some kind of filler.......thats fine, but I want it to really look like a seperate part installed after the paint process has been completed........I use this method on the tail group.........you will have to go back quite a few pages to view this process.......... I will see if I can find the references to this method......
Rich...
Old 03-22-2013, 05:45 PM
  #1104
WARBIRDRCER
My Feedback: (22)
WARBIRDRCER's Avatar
I stopped by RPRCBuilder's today to visit him about his vacation he just returned from. He showed me some great photos of some museum aircraft he saw while gone. Amazing how we aircraft guys always seem to find ourselves around airplanes no matter where we go
I did catch him in his shop laying out some major sections of the wing assembly. This is a very large aircraft, and I know it will present well in flight.
No photo uploads tonight I guess. I will try tomorrow.
Old 03-24-2013, 07:14 PM
  #1105
rhsmrt50
rhsmrt50's Avatar
Here is the scale drawing of the OS-Gemini-160 Twin prop drive and extension....
Rich...
Old 03-29-2013, 08:08 AM
  #1106
Mehler
Old 04-01-2013, 06:21 PM
  #1107
WARBIRDRCER
My Feedback: (22)
Here is a report of where we were at close of shop Saturday afternoon.
Old 04-02-2013, 10:47 AM
  #1108
rhsmrt50
rhsmrt50's Avatar
......looks terrific Steve.......beautiful work........keep sending pic's............
Rich.....
Old 04-21-2013, 07:51 PM
  #1109
WARBIRDRCER
My Feedback: (22)
More updates on this 21st day of April 2013,
Old 04-24-2013, 04:36 PM
  #1110
rhsmrt50
rhsmrt50's Avatar
.....Moving right along guys......what engines are you using Steve?
Rich.
Old 04-26-2013, 07:17 PM
  #1111
WARBIRDRCER
My Feedback: (22)
ORIGINAL: rhsmrt50
Rich.
DLE 20's
Old 05-29-2013, 01:18 AM
  #1112
jdhughen
Bump Bump. It's been quite for awhile. everyone still here ? I'd hate to lose this thread. I hope all are well.
Went to Joe Nall hopping to see a t-50. Lots of ww2 birds but no t-50.
Has anyone here madiened ? Murphey? Rich?
Rich, I know it's time consuming to post to your level of detail, but just a little update would help keep the fires burning
hope all is well
Joel
Old 05-29-2013, 04:37 AM
  #1113
Murphey
Murphey here...I've been working on the Song Bird...but not finished. I changed all of the servo leads and am working on replacing the ignition modules. She will fly this summer...we are in the "windy" period this time of the year...and I want to wait until a fairly calm day. Thanks for checking
M
Old 06-12-2013, 04:43 PM
  #1114
WARBIRDRCER
My Feedback: (22)
Here is an update on the T-50 for 6-12-2013
Old 06-14-2013, 06:21 AM
  #1115
jdhughen
Thanks for the update.
Looking good. What are your plans for covering ??
Joel
Old 06-16-2013, 06:50 PM
  #1116
WARBIRDRCER
My Feedback: (22)
Right now I am thinking of Stewart Systems fabric and glue.
Old 06-23-2013, 01:08 PM
  #1117
Murphey
Guys...I've been finishing up the Songbird! Just finished replacing all of the flat servo leads with twisted leads. Not for RFI issues but for cross-talk issues. When ever the electrically actuated gear would travel up or down, the throttle servo's and aileron servo's would have a case of the jitters...jitters cured! I also replaced the ignition modules. So the throttle servos are mechanically set up exactly the same, kill switch worked, gear goes up and down and ailerons and flaps operate successfully as well! So since everything but the rudder and elevator servos are in the wing...most everything has been "shop tested". Once I revise the rudder and elevator servos, I'll take her out to the field and "wet test everything...motors running, gear up and down, range check...maybe even a high speed taxi...all that stuff. Hopefully everything will go correctly...takes 2 trips to get her out there! Here are 2 photos of the right engine...not quite as busy as Rich's though!
M
ID:	1894446   Click image for larger version
Old 06-23-2013, 02:10 PM
  #1118
rhsmrt50
rhsmrt50's Avatar
.......Nice job Murphy...........Did you also repaint from red to blue??.............I see blue on the nacelle.....
Rich.
Old 06-23-2013, 03:47 PM
  #1119
Murphey
No Rich...that's the grey that the underneath of the original Songbird was painted. Just looks blue in the photo. So I've been told, the bottom was painted grey because the 50's TV cameras couldn't detect the white. There is still differing opinions about the trim colors...red or blue. My sources say red and since there most likely no one around that ever saw the original in person...I'll go with red...besides, I like red better than blue, and it's already painted!
M
Old 06-23-2013, 05:08 PM
  #1120
ludfleet
My Feedback: (10)
http://www.youtube.com/watch?feature...&v=j5-18MR8aZs
Check out this attached link, this video shows the Songbird as being white with blue trim maybe you've already seen it. Joe
Old 06-23-2013, 05:21 PM
  #1121
Murphey
I'm not going to get into that discussion other than to say...have you seen the original TV series and noticed that the trim on the "Songbird" in the YouTube...regardless of the color... is nothing like the plane in the TV series? The photo of the Songbird in flight is a screen capture form one of the actual episodes...I have all of them that are still in existence.
M
ID:	1894523   Click image for larger version
Old 06-23-2013, 06:31 PM
  #1122
SpaceRanger
The airplane in that video was not used in the TV series; the colors are erroneous. There were more than one T-50 used in the series, but the "hero" airplane seen in all the flying shots was painted white, gray, and red.
Old 06-23-2013, 06:46 PM
  #1123
Murphey
SpaceRanger...am I correct that all of the T-50's used in the TV series are "no longer with us" and that only a few parts remain?
M
Old 06-25-2013, 01:14 PM
  #1124
SpaceRanger
What remains of N67832 (the "hero" airplane seen in all the Sky King flying shots) is reported to be little more than scrap. Its registration expired on March 31 of this year. One of the stand-in airplanes, N4571N (manufacturer's serial number 3305), is owned by Jon Larson Sr. of Auburn, WA (the same person who owns the blue-and-white "Songbird" in the previously posted video), but its condition is unknown.
There was also a third airplane used on the soundstage for entry/exit shots, but its identity is unknown at this point. A fourth airplane may have been kept at the Apple Valley, CA, airport for ground shots, but this is unconfirmed. A fusleage was used for filming cabin shots; its identity is also unknown.
I am compiling histories of every T-50 built for a book, but do not yet have all the FAA registration files, and many T-50 registration files were destroyed in the past, so we may never know the identity of some of the Sky King airplanes. Some may not have been registered.
Old 06-25-2013, 01:52 PM
  #1125
rhsmrt50
rhsmrt50's Avatar
....Thanks Mike......
Rich.
