Welcome to Club SAITO !
Old 11-04-2019, 05:55 PM
  #43376
Captcrunch44
Well I don’t know if that’s a mark but ther the same cam not like the one you have with the funny lobe separation
Old 11-04-2019, 06:10 PM
  #43377
Glowgeek
Can you spare a couple of those cams Crunchy?
Old 11-04-2019, 06:15 PM
  #43378
Captcrunch44
they will go out tomorrow
Old 11-04-2019, 06:16 PM
  #43379
Glowgeek
You're the best!.
Old 11-04-2019, 06:39 PM
  #43380
Captcrunch44
holy cow i don't get on the desk top vary often this is different. the pics are so big!! well lonnie the cams will head your way tomorrow.
Old 11-04-2019, 06:52 PM
  #43381
Glowgeek
The one cam I tried that had the line on it would not time correctly on my 45. With the alignment tool in the camshaft oiling hole the cam box could not be installed with the crank pin at tdc. The crank pin would end up slightly off to the left or right from tdc but never straight up.
Old 11-04-2019, 07:03 PM
  #43382
Captcrunch44
yeah both these cams came out of crashed 45 one the cylinder looked like new and the other vary low time. you can see the 3rd has been run a lot and i have a couple more high time ones.
you will have too let me know what other parts you need i might just have a good used one.
Old 11-04-2019, 07:05 PM
  #43383
Glowgeek
Fa 45 Intake and exhaust valves and a 50 carb?
Old 11-04-2019, 07:11 PM
  #43384
Captcrunch44
hmmmm
intake and valves I can probably help with 50 carb I don’t think so.
Old 11-04-2019, 07:15 PM
  #43385
Glowgeek
Originally Posted by Captcrunch44
hmmmm
Sorry, I meant a set of valves.
To complete the third 45 I need a set of rocker covers as well. Doesn't have to be the old sandblasted style, can be the new shiny chrome ones that came on the 56 or 62.
Old 11-04-2019, 07:31 PM
  #43386
Captcrunch44
ok I will send you this
Old 11-04-2019, 07:34 PM
  #43387
Glowgeek
A treasure trove of parts! Thanks
Old 11-04-2019, 07:42 PM
  #43388
Captcrunch44
any thing else before I seal the box
Old 11-05-2019, 03:12 AM
  #43389
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I see that head those early blue rocker cover gaskets. They require some serious delicate surgery to remove. Nice to see you fixing Glowy up. Gary fixed me up with rocker covers for the Psychobillie 82.
Old 11-05-2019, 04:51 AM
  #43390
Glowgeek
Crunchy IS awesome!
I have a special tool for scraping out pesky rocker cover gaskets; a small Snap-on screwdriver held vertically. Perfect fit and works fast without gouging.
The same screwdriver has a magnet in the handle which I once used to remove and install the valves. I thought about that and decided that magnetizing the valves is probably not a good thing to do!
Old 11-05-2019, 04:58 AM
  #43391
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
If the piston was steel that would make for interesting running.
I have a telescoping thing with a strong magnet on the end, it can find things that my eyes can't. And with two numb finger tops I lose stuff on occasion.
Old 11-05-2019, 05:16 AM
  #43392
Jesse Open
Jesse Open's Avatar
Crunchy IS awesome!
The heat and impact of running will demagnetize the valve anyhow.
Old 11-05-2019, 05:26 AM
  #43393
Glowgeek
Good to know. We talking minutes here or hours?
Old 11-05-2019, 05:53 AM
  #43394
Jesse Open
Jesse Open's Avatar
Minutes
Old 11-05-2019, 08:13 AM
  #43395
Quikturn
My Feedback: (12)
Quikturn's Avatar
I have a Saito 45 special and recently picked up a std fa-45 which needs a clean up before a run. It also has a pronounced tick over. Valve adjustment maybe?
On the special, the carb is improved and the intake tube is a larger diameter. So the cam is different? I thought the valves may be larger on the special as well but I could be wrong.
Old 11-05-2019, 12:09 PM
  #43396
Captcrunch44
yes the 45 special has a high lift cam.
Old 11-05-2019, 12:10 PM
  #43397
Captcrunch44
Hmmmm
Old 11-05-2019, 12:22 PM
  #43398
Captcrunch44
Here you go old 45 on the top and the new 45,50,56 on the bottom
Old 11-05-2019, 01:02 PM
  #43399
FlyerInOKC
FlyerInOKC's Avatar
Hey acdii how did your Liberty Sport project come out?
Mike
Old 11-05-2019, 01:26 PM
  #43400
Glowgeek
In addition to the higher lift cam the 45S has longer tappets, shorter pushrods & pushrod covers, a different cam gear housing as well as a different back plate to accommodate the larger newer syle carby. The intake manifold may be different as well. All other parts are the same.
Note: In the picture of the two camshafts above it is evident by counting the number of teeth from the timing mark to the lobe centerlines that the 45 has not only less lift than the 45S but also has a wider lobe separation. I haven't degreed the two cams to determine whether or not the cam timing has been advanced on the 45S vs. the 45 but I suspect it has.
