Welcome to Club SAITO !
Old 03-28-2024, 06:28 AM
  #54701
FlyerInOKC
FlyerInOKC's Avatar
Originally Posted by 1200SportsterRider
That is the 62 on which I adapted an FG11 cylinder making it a 66. Sometimes you just have to do things to see if you can. As I remember it, that increased to bore to 27mm.
First inline if you ever want to sell it!
Old 03-28-2024, 09:38 AM
  #54702
Jesse Open
Jesse Open's Avatar
Good mate-up Dave. Any plane under the control of a green transmitter has to fly well. The Saito "Hobbsy Special" will serve proudly for you.
The LT-40 here is FA-72 powered, spent most of the last twenty years hauling around pontoons over a nearby lake. Plenty of power.
Now, get busy and start wearing it out!
Old 03-30-2024, 05:07 AM
  #54703
easystar123
Location: Kilrea, County Derry, N.Ireland. United Kingdom
Default Spinner nut?
Originally Posted by Hobbsy
LASER 70
LA 25 and Saito 30
I know this is an old thread and all my fourstrokes bar one are Saito and on every plane I use them with an aluminium back plate spinner except one which I have a Saito 62 with 12x6 three blade prop, the exact set up youo have on your bright yellow plane here in the photograph. But can I ask you this question, in all my 38 years of flying rc planes I've never used a spinner nut on a Saito engine. But this particular plane I have now with the Saito 62 and three blade prop I have it secured with the prop nut and locking nut. It makes it a wee bit more difficult to use the electric starter. So do you go without using the locking nut and just screw on the spinner nut over the top of the prop nut? If so , is this a safe set up? Would it throw the prop? I'm very safety conscious and would like your opinion? Kind regards Aidan.
Saito 62 with 12 x 6 three blade.
Hi there, do you just use a spinner nut over the prop nut and disregard the locking nut? If so, is this a safe set up? I would like your opinion as I am very safety conscious. Kind regards Aidan
Old 03-30-2024, 07:23 AM
  #54704
Glowgeek
When using a Spinner Nut I don't use the original prop nut or lock nut. I just tighten the spinner nut against the prop washer. Tight TIGHT!
There's little chance of it coming loose unless the engine is over primed at startup or run too lean at wot.
Old 03-30-2024, 07:39 AM
  #54705
easystar123
Many thanks. I have my Saito 62 on the Calmato Sports 40. Flys it very well.
Old 03-30-2024, 08:11 AM
  #54706
Glowgeek
Nice looking setup. The Saito FA-62 is a good match for the Calmato 40. I like your use of ball links.
A couple of friendly tips:
It's a good idea to secure the crankcase vent tubing to something. Clamped to the firewall with an inch of tubing extending below the fuse works well. Some prefer to route that vent to the muffler tail piece, via a clamped on piece of brass tubing, so the exhaust stream carries away the oil.
For a better looking exhaust sealant, teflon based plumbers paste (cheap) works good as does Swak paste (more expensive). I actually prefer Swak but I've been having satisfactory results with plumber's paste (RectorSeal T plus 2"). The excess can be wiped off after the exhaust is tightened leaving a robust, leak free, tidy looking engine.
Old 03-30-2024, 09:12 AM
  #54707
easystar123
Many thanks for those useful tips. In relation to the crankcase vent tubing, that only stays on when I'm not flying and has a fuel plug stopper at the end. When I go to the flying field for a days flying I simply remove the fuel tubing and at the end of the day put it back on again. The orange gasket maker sealant I bought in America. I've tried everything over the years and I found that this stuff works great and I've never had a muffler come loose in over 20 years using permatex. I'm just recently bought a turbo header for my Saito 72 and look forward to trying that out. In all my Saito fourstrokes I have everyone connected up to the throttle servo using the Dubro Fourstroke Throttle Linkage System. It works great.
Old 03-30-2024, 09:20 AM
  #54708
easystar123
Default New turbo muffler for Saito 72
Old 03-30-2024, 09:48 AM
  #54709
easystar123
This is the Calmato flying just over a year ago with the Saito 62.
Old 04-01-2024, 06:34 AM
  #54710
Glowgeek
Very nice, thanks for the vid.
Old 04-01-2024, 07:41 AM
  #54711
easystar123
Your very welcome. The Calmato has not been out since then as I have been flying some of my other planes. But the next time I go to the field I'm taking it with me as its due a few flights. Thanks for watching. Kind regards Aidan
Old 04-01-2024, 08:06 PM
  #54712
Jesse Open
Jesse Open's Avatar
Loved it!
Sweet music.
Old 04-02-2024, 12:08 AM
  #54713
easystar123
Originally Posted by Jesse Open
Loved it!
Sweet music.
Many thanks for your kind comments. They are great engines.
Old 04-02-2024, 01:58 AM
  #54714
Glowgeek
Default Whistling Calmato 40
Amazing speed with only an FA-56.
Old 04-02-2024, 02:57 AM
  #54715
1200SportsterRider
1200SportsterRider's Avatar
The 56 is a real torquer, I have images of one, (that I can't post) turning an HY 12 x 6 at 10,008 and a Xoar 12 x 6 at 10,001 rpm. Also one image of it idling at 1,370. Hooraw, I gottem to post.
Old 04-02-2024, 03:17 AM
  #54716
easystar123
https://youtu.be/PBna9ExMvCk?feature=shared
Brilliant and great landing also. The Calmato 40 is a nice sports plane and is ideal for the Saito 56.
Old 04-02-2024, 03:30 AM
  #54717
1200SportsterRider
It appears that someone has stolen the name.
Old 04-02-2024, 04:02 AM
  #54718
easystar123
My goodness
Old 04-02-2024, 04:27 AM
  #54719
easystar123
Default Saito 62
This float plane from 12 years ago has the Saito 62 on board. The same Saito 62 which is now on my Calmato 12 years later. In all those years ive never had to do a thing to the engine other than put fuel in it and start it up. Its still got the original glow plug .
Old 04-02-2024, 05:07 AM
  #54720
Glowgeek
Nice, Aidan. Thanks for the vid.
The 62 is running plenty rich in both vids. Saitos will run seemingly forever tuned like that.
Old 04-02-2024, 07:01 AM
  #54721
easystar123
Thanks Glowgeek for your kind comments. I like to run all my Saito engines rich and I like to see a smoke trail.
Old 04-02-2024, 08:58 AM
  #54722
Jesse Open
Jesse Open's Avatar
What prop were you using when making that 1370 RPM idle ?
Old 04-02-2024, 09:03 AM
  #54723
Glowgeek
To be honest, I do run my Saitos a bit leaner, both needles, but still within an acceptable mixture range. I adjust the high speed needle as lean as I can without sagging on extended uplines. The low speed needle gets adjusted lean enough for 20-30 seconds of reliable idle before the rpm starts to drop. Both needle adjustment are performed with the engine at full operating temp. And guess what? The engines still last seemingly forever.
Granted, most of my dozen or so Saitos are mounted to warbirds where I have a need for speed.
Old 04-02-2024, 09:11 AM
  #54724
easystar123
Good stuff. They are fantastic engines and give very little trouble.
Old 04-02-2024, 02:30 PM
  #54725
Jesse Open
Jesse Open's Avatar
Dave,
Do you recall what prop the Saito in your last pic was using when idling at 1370 RPM?
