ASP/MAGNUM FS400AR Rebuild/Overhaul
Old 03-22-2014, 05:47 AM
  #2851
Don Cunningham
Well I will try to give you the steps I took
1. I tore down the engine because it was not run for 15,20 years
2. The inside of the engine was full off junk ( castor ) I replaced the main bearings, remove the piston rings and cleaned the ring grove,all parts were cleaned. # 4 ring was replace, I broke it, this is one of cly. that has no compression. Thats why I wonder what I did wrong.
4. How do you perform a leak test?
5. Cam timing was good I lined up the spots on the gears. I made sure the it was right on.
Because of no compression I removed plug and inserted a dowel. I then turned until rockerarms did not move. Piston was at high point. I then ajusted valves. With the head off, I put my hand over the cly. and I thought I had good compression.
Thank you Don Cunningham
Old 03-22-2014, 06:58 AM
  #2852
Carosel43
Hi Don
You say you have no compression? now when you say 'no' do you mean none or that its very weak? if it is weak I would not worry too much and as long as you can turn the engine smoothly I would run the engine and see if the rings come in. use a small ish prop and get the rpm up and the engine leaned out (not fully) fairly quickly. I would run it for about 2 minutes to warm it up and then open it up. Don't screw the life out of it, but you need to get the engine upto temperature and the rpm up a bit as well.
If you have no compression at all do as bj suggested and put some oil into the cylinder. Swirl it around so the ring and valves are covered in oil and see if you still have nothing. if so then most likely a valve is stuck
Old 03-24-2014, 03:44 PM
  #2853
BJ64
BJ64's Avatar
The other thing to maybe look at are the valve seats/faces and/or guides themselves...?
Everything is pretty small on these things, but it might be worth giving the valve seats and faces a decent eyeball - make sure there isn't a ding somewhere due to ingesting a bit of junk, or a scratch or burn-out excessive wear... or just bad engineering somewhere (??)
BJ
PS - I'm guessing there's no cracked rings... holes in piston crowns or anything else obvious...?
Old 03-27-2014, 12:59 AM
  #2854
BJ64
BJ64's Avatar
Keleo arrived today
Will have to fire the 400 with 'plumbers pentagon' pipe and do a quick vid - then fit the Keleo and do the same... just for a sound comparision if nothing else.
I have no idea if there's any performance gains etc. to be had with the Keleo, but I'll say one thing for sure - it's a work of art. The workmanship is impeccable.
Simply Divine.
BJ
Old 03-30-2014, 11:39 PM
  #2855
Carosel43
I was able to fly my 400 on Saturday having mixed up my new fuel. The engine ran pretty well but judging by the colour of the mess coming out of it I feel it really is not long for this world despite improved performance. Once this gallon of fuel has gone (I have about 4 flights worth left) then I will retire the engine for the time being
Old 03-31-2014, 10:34 AM
  #2856
Kmot
My Feedback: (24)
Kmot's Avatar
Seems you have this thought before Jon!
Old 03-31-2014, 11:25 PM
  #2857
Carosel43
Lol yeaaa, but this time I think it really is final as I desperately need the space in the hangar. I have another model I can hang the 400 on if I want to, but right now its awaiting a new laser for me to test fly before it goes into the sea fury
Old 04-01-2014, 10:41 PM
  #2858
Kmot
My Feedback: (24)
Kmot's Avatar
How's that video coming along BJ?
Old 04-02-2014, 02:14 AM
  #2859
BJ64
BJ64's Avatar
Its.... um... "coming"
BJ
Old 04-16-2014, 12:53 AM
  #2860
SJN
Look what just showed up
The little 180cc moki is not that much larger than the ASP 400.....just a little more meat on the bones
ID:	1987405   Click image for larger version
ID:	1987406   Click image for larger version
ID:	1987407   Click image for larger version
ID:	1987408   Click image for larger version
Old 04-16-2014, 03:20 AM
  #2861
tim750r
Very nice, I didn't know Moki did a 180cc...
Old 04-16-2014, 03:27 AM
  #2862
tim750r
I've a question about valve clearance as I'm about to look at mine.
If I understand correctly, the cams actually rotate at 1/8th crankshaft speed and have 4 sets of cam profiles. Is it safe to assume that the 'land' between the cam lobes (and therefore the valve gap) will be consistent on all four, or should the clearance be measured for all four sets of gaps if you see what I mean?
Old 04-16-2014, 03:41 AM
  #2863
SJN
The 180 has replaced the 150 model....same size, just larger bore.
Tim, it should be messured all sets, as the cam gear is not perfectly centered......you will see when you measure :-)
Even my new moki manual says to check the clearance 2 places, as it has 2 sets running in a planet gear.
Old 04-16-2014, 03:50 AM
  #2864
BJ64
BJ64's Avatar
Sensational motor, SJN.
But... over AU 4 grand??
That's a bit out of my league.
I notice you said "not that much bigger than the ASP 400".
The ASP is 60cc, the Moki 180cc. Are they just running bigger bore/stroke?
BJ
PS - just looked at your pics. A bit deceptive at first glance, but I reckon it's a lot bigger. And probably quite a bit heavier too?
Old 04-16-2014, 07:03 AM
  #2865
Carosel43
Hi Tim, if memory serves the 400 radial has 3 pairs of cam lobes and rotates at 1/6th crank speed.
Old 04-16-2014, 07:35 AM
  #2866
tim750r
Ah, thanks that saves a bit of time! Don't know where I got the idea it was 4 sets...
Old 04-16-2014, 10:21 AM
  #2867
SJN
Yea, is is ofcourse a lot larger CC wise, but I ment the dimensions are not that much larger :-) . It weighs 4.3kg, and the ASP if I remember is about 3kg....i think.
Cant wait to get it installed, and fired up....and wont miss the corrosiveness of methanol and nitro :-)
BJ
Old 04-17-2014, 04:46 AM
  #2868
BJ64
BJ64's Avatar
Where's SignorTelemaster when you need him?
You MUST run your Moki on Methanol + CDI (just kidding )
BJ
Old 04-17-2014, 11:27 AM
  #2869
Kmot
My Feedback: (24)
Kmot's Avatar
Oh Sonny, I am sooooooooooooo envious!!!
Congrat's!!!
Old 04-17-2014, 01:58 PM
  #2870
SJN
Thanks Tom :-)
Old 04-17-2014, 02:35 PM
  #2871
SrTelemaster150
SrTelemaster150's Avatar
Corrosiveness of methanol/nitro is a myth as long as raw fuel is not left in the engine.
BJ
Imagine what a 25% power boost on methanol would be like.
Old 04-17-2014, 02:42 PM
  #2872
SJN
Well, here is my before, and after shots of my engine.
Im sure that if it was run on gas, it would not look like this
ID:	1987743   Click image for larger version
Old 04-18-2014, 12:10 AM
  #2873
Carosel43
Telemaster is correct, glow fuel is no problem as long as its not left to sit in the engine. When that happens it attracts water and things go very nasty. Generally 4 strokes are more resistant to rust than 2 strokes as they never have any raw fuel in the crankcase which is why I personally think the intake mod for the 400 is a bad idea as raw fuel is being introduced to the crankcase. That said, if an engine is run regularly its far less of a problem
Old 04-18-2014, 07:02 AM
  #2874
SrTelemaster150
Have you seen the latest intake (tub/plenum) mod for the Saito FA-450R3/FG84R3? http://www.rcgroups.com/forums/showp...&postcount=163
On the FG84 it turns a 23X12 @ 6240RPM. That's about 7.75HP & the CHTs are within 4F on all 3 cylinders. The stock backplate only baseline turned that prop @ 5600RPM & CHTs varied widely.
Old 04-18-2014, 07:14 AM
  #2875
SrTelemaster150
I think the biggest problem there is lack of adequate crankcase breathing. That leads to condensation build up. Unlike singles & boxer twins, there are no positive/negative pressure pulses to move crankcase gasses out & pull fresh air in.
