Horizon Hobbies Spectrum DX6I Malfunction that destroyed my aircraft
#76
GA
RE: Horizon Hobbies Spectrum DX6I Malfunction that destroyed my aircraft
Thanks for they reply about what size cells are in the pack,
I ask this because I came across an article in the AMA mag early this(Wish I could remember which issue), anyway it was about the the short service life of AA size cells with more than 1200mah ratings. They concluded that greater than 1200ma could not be packed into a "AA" size cell and give good output, they recommend switching over to atleast a sub C size pack. I exprinced this first hand. I had a couple of good qauilty 6V 2500mah Nimah "AA" packs flew they 2 times on a 72mhz system with no problem. I switched over to the DX6i when it first came out, used the packs in a plane maybe 5 times always recharging with my triton Jr at they end of the day and awlys checked before going flying. After the 6 flight the plane loss control went to the fail sail and then picked the connection again. I landed check the pack with a multie meter and was shocked at what I saw the voltage droped and droped FAST even after one flight. I later read that article and switched over to a 6V 1200 nimh "sub C" pack made by venom. It has been working great for over a year. I mostly fly Deltas and other types of speedy planes my servo count is low so I don't bother with the high mah rated packs. I know you fly big planes I think they are freaking cool. Agree don't agree I don't care IMOP I think the size of they cell is just as important as the Mah rating. Good luck I hope it gets sorted out.
#77
1 Post
ORIGINAL: mlovitt
Taken right from the DX6i manual -
As Horizon has no control over use, setup, final assembly, modification or misuse, no liability shall be assumed
nor accepted for any resulting damage or injury. By the act of use, setup or assembly, the user accepts all
resulting liability.
One could also argue the point that if you really wanted to, you could have had an insurance policy for your airplanes.
If we accept for the purposes of this post that the damages really did occur as a result of an intermittent fault in the transmitter, then the damage occured from none of "use, setup, final assembly, modification or misuse" so the liability waiver is inapplicable in any event.
I don't own any JR gear at all, but if I'd lost close on to $6,000 to a fault that JR knew about and had admitted to in other units, then I'd be pretty damn angry.
#78
My Feedback: (73)
OK
ORIGINAL: psuguru
Statements from a vendor absolving themselves of liability have very limited value.
If we accept for the purposes of this post that the damages really did occur as a result of an intermittent fault in the transmitter, then the damage occured from none of ''use, setup, final assembly, modification or misuse'' so the liability waiver is inapplicable in any event.
ORIGINAL: mlovitt
AMEN GURU !!!! uh.... you get the man of the hour award... if you werent in the UK, I'd buy you a beer..
#79
I saw this thread on the front page and my first thought was "another RCU b(*^&*^ fest..." - the reason why so many long time RCU members leave for other sites. Irregardless I couldn't help myself and started to read. At first I was amazed that it hadn't been locked yet but it seems to be getting constructive now which is good.
I wont even add any more comments to the OP - I think we have beaten to death the fact that his attitude isn't going to help him resolve this. In my mind a couple posts such as doug47's really sum up the fundamental issue. How many RC companies do any of us know that have not had some problem at some time?
Spectrum brownouts
Futaba overhating issues
Futaba RX ID bug
Hitec carbonite gear failures
OS .46 peeling liners
OS .91 overheating
Saitos crappy bearings...
DA50 inverted dead-sticks
BME engine overheating & seizures
3W ignition problems
uncountable numbers of ARF problems like wing failures and folding LG ..
The list goes on and on. But the thing is I've owned probably half of those "effected" products I just listed and in every case either didn't have the problem myself or found a workaround/fix. We have to remember this is a hobby and considering the limited market size and how little we are willing to pay for these products we cant expect aerospace industry level quality control. Heck even world class quality control can miss problems from time to time - just ask Toyota
Another point to consider is the phenomenon that with any product in any industry its the people who have problems that most often post and publish reviews. More often than not the majority with a good experience don't take the time to say so. Easy to get the impression that every product is bad because of that.
~Jeremy
Spectrum brownouts
Futaba RX ID bug
OS .91 overheating
~Jeremy
#80
ORIGINAL: Doug47
Holy cow ! Now that's a guy who was flying the daylights out of his airplane .
When you find something like that what do you boys flying big planes do, replace them with carbon fiber or something stronger ? Doug
I found that I had actually bent the stab tubes (so bad I had to cut them off and beat them out the socket)
#81
ORIGINAL: nhulsey
Sorry but fact is fact which equals truth. Go through all the threads that have to do with radioes in the past 2 years and anyone can see that Spektrum leads the way in complaints of loosing bind.
To properly make an evaluation of this type, you'd need to know the number of units sold and evaluate as a ratio of number units sold per defect unit.
#82
CO
ORIGINAL: iflyg450
I personally would not trust the rating of a AA size NiMh above 1650 mah.
#83
GA
I wouldn't trust them after what I have read and what happened to me. I made the point becasue the battery packs that were on the plane in question when it went down were
"the pack cells are a sanyo 2300mah aa-r6". I hate to say it but I think this could be the whole problem, I am sure I just made my self the target go ahead folks fire away
#85
My Feedback: (73)
OK
its cool dont duck for cover.. I have driven 15 HITEC 5955tg's in an h9 ulty with these batts on a 2.4 9303 and 921 rx with out a single failure
#86
GA
I will try to find that article in AMA. They have the capacity but I would not trust them to put out the needed voltage for a spektrum system. Take it or leave, I had the exact same thing happen to me I changed the packs I use and the problem never came back even with the same rx and switch ect..
#87
My Feedback: (73)
OK
yup to each his own (different stroke for different folks) I'v used em for the past 5 years and on some majorly power hungry planes. I have had servo's burn out and and the packs to the hit until the servo actually quit ( I guess thats how that works ) and they still keep on tickin like a rolex [:-] only if you bought a fake one hehe
#88
CO
My catalog must be old as it shows the HR-3U as only available at 1650 mah. I have been using the sanyo HR-AUX 2700 Mah A (50mm tall X 17mm diameter), Flat top (good for soldering) and the Sanyo HR-4/5AU-WT for 2150 mah (43mm tall 17mm dia)
#89
ORIGINAL: iflyg450
I think I saw it too - one of Red's battery articles. The folks at Radical RC give the same recommendations. Basically the deal is that to make the high capacity AAs (2100/2300 and even 2700) they have to make the separators VERY thin to pack in as much electrolyte as possible. This gives a high capacity but on the flip side they cant handle big amp loads. So high discharge rates and anything faster than a wall wart charger kills them quick.
These cells where first marketed for digital cameras etc where long run times on a small (couple hundred mA) load is the goal.
For TXs these big capacity cells are great - especially the Eneloops (which seem to take a quick charge better than other high capacity cells) but I too have had only bad luck with them in RX packs. Thats where A123s shine
#91
My Feedback: (73)
OK
BAAhahahahahahaha ya I guess so huh... I havent changed that junk since I started my profile.. man I guess the packs I have made for me are GOLD or somethin cause I use an H9 double vision to charge em and I just fly em prolly 4 or 5 flight then charge back up 5 years and countin.. and I will be to differ on the "can't take the HIGH DISCHARGE" when I had my ulti, I loved to slam the sticks on that one and just send it tumblin or nice tight rollin stuff. I would be jammin 15 count em 15 digital servos as far as I know the guy that has it is still flying the plane
#92
GA
Nope, You do whatever you want do, what works for you, but to blast a company that has been huge in adavncing this hobby as well as provide other and me GREAT CUSTOMER SERVICE IS WRONG! BOTTOM LINE END OF STORY! You have no idea what caused you wreck! Your using packs that may longer be up to the task. Please you and your friends don't do somthing dumb like sue it just ruins everything for everyone. If you can't handle the loss of a high dollare airplane then don't fly them go with 1/2a or control line or better yet go collect stamps. Or just suck it up Nacy. Everyone here hast lost a plane will more than likley go on loseing oh well life goes on. ALL MODEL AIRPLANE HAVE AN EXPERATION DATE ON THEM
#93
FL
From the very first post on here I had one thought,and some people mentioned it as well. Why would you fly giant scale aircraft with a park flyer radio at best? I won a dx6 at our club meeting over 2 years ago,you know where it is???? Still in the box where it belongs ,because I dont fly park flyers !
JUST MY 2 CENTS ADD IT TO THE ACCOUNT !! (PRETTY SOON YOU WILL BE ABLE TO BUY A REAL RADIO)
#94
My Feedback: (73)
OK
well like I said from the begining, setups were perfect and flew just fine LIKE THEY HAVE FOR YEARS and then not one but TWO plane sdo the exact same thing.......CHAULK THAT UP TO A FALUTY DX6i and dont get me started on horizion's AWESOME customer service they may handle piddly little stuff like broke MCX or oops I dropped my tx on the tarmac and broke three switches and a gimble. sure there great BUT ME and MANY MANY MANY others have had horrible service when we buy something and it fails like my 35% extra 260 full of 7955's, powerbox, and powerbox lipos and a new da 100 eats dirt after the right wing EXPLODES from a quarter thottle level snap roll and they say YEAH WE HAVE BEEN HEARING ABOUT THAT ISSUE SORRYCANT HELP THANKS FOR SUPPORTING HORIZION HOBBIES that gets under my skin TAKE IT OR LEAVE IT
#95
MO
Hey buddy,
Did you have the antenna oriented correctly? You know, the signal comes out the SIDES of a 2.4GHz transmitter antenna, since both times the crash occurred while low to the ground, if the antenna was straight up, and being pointed at the plane, it could have completely lost a signal.
#96
GA
I guess a clipped wing DD running a OS 25VD-DF is a park flyer or my YS 45FR powered arcomaster and Mk arrow pattern planes is now a park flyer sweet no more club dues. Don't be a snob what makes this radio a "parkflyer" it does what most glow flyers need. Its only a parkflyer radio if you have linked to park rx.
#98
My Feedback: (73)
OK
yup sure did said that in an earlier post and 80-100ft isnt really low (I dont think) I have made 5000+ flights with a dx6i and never had a failure and my setups stay consistant.. I have dumb thumbed a few like every other with little damage but never had any of my planes fail like this ITS THE FAULTY DX6i
#100
My Feedback: (73)
OK
and here we go since were on the subject let define the difference between a GIANT SCALE TX and some thing you WOULDNT FLY A GS ON
this one should be fun
