Reload this Page >
Top Flite GS P-47 sports scale; diary of a build
Old 01-22-2015, 04:43 PM
  #1626
TonyBuilder
TonyBuilder's Avatar
Originally Posted by stevegauth30
I really like that setup a lot. Wait, listen....... YOINK!
That was me stealing the idea.
Go for it Steve, this setup is really not that hard to do, honestly not much more then the way the kit is setup with thoes two large ugly controll arms and the pushrods all over the place.
TB
Old 01-23-2015, 02:47 AM
  #1627
TonyBuilder
All looks good on the elevator joining.
Good movement up and down.
Linkage is smooth and works great.
I just need to clean it up and sand the elevator down a bit and it is ready to cover.
TB
ID:	2066841   Click image for larger version
ID:	2066842   Click image for larger version
ID:	2066843   Click image for larger version
ID:	2066844   Click image for larger version
ID:	2066845   Click image for larger version
Old 01-23-2015, 03:56 AM
  #1628
WacoNut
WacoNut's Avatar
TB,
Nice installation on the elevator linkage. I think I will use that on my next build.
Later!!
Anthony
Old 01-23-2015, 03:58 AM
  #1629
TonyBuilder
Thanks Anthony!
TB
Old 01-23-2015, 04:21 AM
  #1630
TonyBuilder
Here are a few schemes I have been looking at, please feel free to offer some choices as I am open to most of the unusual schemes!
I I like this one as it is shinny and the brushed aluminum will look good with minimal overlay painting.
This one is ok but probably been over done.
Another unusuwal one but plane Jane.
Maybe!
I really like this one as it falls in the Angie relm and would look good along side. Plus the ladis not bad
- Miss Fire / Rosie Geth II, P-47D-25-RE, s/n #42-26628, coded 'LM-C' and flown by Capt. Frederick J. Christensen Jr. of 62nd FS / 56th FG,
This one could be cool too.
TB
ID:	2066850   Click image for larger version
ID:	2066851   Click image for larger version
ID:	2066852   Click image for larger version
ID:	2066853   Click image for larger version
ID:	2066854   Click image for larger version
ID:	2066855   Click image for larger version
ID:	2066856   Click image for larger version
ID:	2066858   Click image for larger version
Old 01-23-2015, 08:01 AM
  #1631
FlyerInOKC
FlyerInOKC's Avatar
How about something like this without the invasion stripes. I know you would probably need to use some decals instead of painting it all but it would look great!
Name:	Tarheel Hal Republic P-47.jpg
Old 01-23-2015, 08:17 AM
  #1632
TonyBuilder
Ok, I am going with Miss Fire for the scheme of this build.
TB
ID:	2066899   Click image for larger version
ID:	2066901   Click image for larger version
ID:	2066902   Click image for larger version
ID:	2066903   Click image for larger version
ID:	2066904   Click image for larger version
ID:	2066905   Click image for larger version
ID:	2066906   Click image for larger version
Old 01-23-2015, 08:47 AM
  #1633
scoobiemario
My Feedback: (8)
scoobiemario's Avatar
Miss Fire, that was going to be my vote. Other one I like is Air Cooled Injun, but I could find only nose art picture. , http://s274.photobucket.com/user/jae...8thFg.jpg.html
Old 01-23-2015, 10:18 AM
  #1634
TonyBuilder
Scoob, that's a good one, I'm choosing on eas of finishing too. No checkered cowl, no fully covered tail feathers (painted) and minimal overlay colors. Miss Fire is not bad as fare as that goes.
Just got confirmation from JTEC as to the size and what the muffler will look like for the DLE85
TB
ID:	2066940   Click image for larger version
ID:	2066941   Click image for larger version
ID:	2066942   Click image for larger version
Old 01-23-2015, 10:20 AM
  #1635
FlyerInOKC
FlyerInOKC's Avatar
Good looking muffler should be just the ticket.
Old 01-23-2015, 10:26 AM
  #1636
TonyBuilder
Yes and I'm glade I get to use the DLE 85 too.
TB
Old 01-23-2015, 03:31 PM
  #1637
TonyBuilder
So for the noes art the vinyle decal is not going to be the best qulity so I either have to have my airbrush artist do the pinup or I can use a slightly different modle. These water transfers are very good and the best qulity short of hand painting.
So I got a couple from vintage guitars.
TB
Old 01-23-2015, 05:11 PM
  #1638
TonyBuilder
I got a good start on the rudder.
I added about 3/4 to 7/8" to the LE of the rudder for the rounded LE.
The sweep on the tip is in and shaped, most of the work is done and I can go ahead and install the pocket.
TB
ID:	2067053   Click image for larger version
ID:	2067056   Click image for larger version
ID:	2067057   Click image for larger version
ID:	2067058   Click image for larger version
Old 01-24-2015, 05:01 AM
  #1639
TonyBuilder
Getting a start on the rudder hinge pocket.
First I cut the fo hing block out of carbon fiber laminet.
I glue that in with a block of base wood.
then the CF strips followed by the balsa stick.
One side done, I screwed up the hing block tab on the stab as I did not ad 1/4" of the CF strip so they are a 1/4" sort.
I got it right on the rudder.
TB
ID:	2067157   Click image for larger version
ID:	2067159   Click image for larger version
ID:	2067160   Click image for larger version
ID:	2067161   Click image for larger version
Old 01-24-2015, 02:17 PM
  #1640
rt3232
T/B
Will the C/F just slide on the rudder as it moves ? when I build another big bird I will be using a lot of your ideas.
Thanks for sharing
Cheers Bob T
Old 01-24-2015, 04:36 PM
  #1641
TonyBuilder
Bob, if you are referring to the hing cap. I can't be 100% sure but my guess is that the slot is so one can accses and install the hing bolt, then the tab cover is screwed to cover the hinge. So being I am not actually using the hinge blocks like I am and did on the prototype and Angie these are just scale details. Using the carbon fiber replicated the hing pretty good. One could also put a HD hing here and then in the finishing cover it with the tabe.
TB
Old 01-24-2015, 05:04 PM
  #1642
TonyBuilder
Default Rudder
The top half of the rudder hinge pocket is completed.
Carbon fiber tabs for the hinge linkage covers.
CF strips in between the tabs, as on the stab.
The top hinge pocke is complete leaving the more complex lower pocket to do.
One thing I realize is that in most modles that don't have the fatter lower section on the rudder is that most rudders are fatter (wider) in general foe strengthen making it one size and not having the wider lower section. I think the fuselage is the corect withdth at the ende relatively but the top porting of the rudder is not as thin as the full scale.
I will not be doing the scale rudder on this build, saving it for Angie.
Here you can see how the tab is looking, more scale in my opinion.
I am starting to do the cut out for the elevator tourqe rod and controll arm.
Tomorrow I should get most of this done.
V
TB
ID:	2067368   Click image for larger version
ID:	2067369   Click image for larger version
ID:	2067370   Click image for larger version
ID:	2067371   Click image for larger version
ID:	2067372   Click image for larger version
ID:	2067373   Click image for larger version
ID:	2067374   Click image for larger version
ID:	2067376   Click image for larger version
ID:	2067377   Click image for larger version
ID:	2067378   Click image for larger version
ID:	2067379   Click image for larger version
ID:	2067380   Click image for larger version
ID:	2067381   Click image for larger version
ID:	2067382   Click image for larger version
ID:	2067384   Click image for larger version
ID:	2067385   Click image for larger version
ID:	2067386   Click image for larger version
ID:	2067387   Click image for larger version
ID:	2067388   Click image for larger version
ID:	2067389   Click image for larger version
ID:	2067390   Click image for larger version
ID:	2067392   Click image for larger version
Old 01-25-2015, 04:20 AM
  #1643
TonyBuilder
Default Rudder linkage
Got the rudder linkage done this morning.
I like to use stuff I have and if that doesn't work I will manufacture something.
I'm not doing the scale linkage like I am doing with Angie as this is sports scale
I am using the Sullivan arms as I did on "My Babby"
I think this will be a good in between setup from full on scale to hidiouse push rods.
Bolted together and cut into the rudder, this will get epoxied in.
The pull-pull will enter the fuselage just outside of the hinge pocket faring.
2-56x4-40 ball links are my scale link of choice.
TB
ID:	2067540   Click image for larger version
ID:	2067541   Click image for larger version
ID:	2067542   Click image for larger version
ID:	2067543   Click image for larger version
ID:	2067544   Click image for larger version
ID:	2067545   Click image for larger version
ID:	2067546   Click image for larger version
ID:	2067548   Click image for larger version
ID:	2067549   Click image for larger version
ID:	2067550   Click image for larger version
ID:	2067551   Click image for larger version
ID:	2067552   Click image for larger version
Old 01-25-2015, 10:07 AM
  #1644
TonyBuilder
The lower hinge pick is done. Some 1/32" birch ply and easy sand did the trick.
I could not resist the scale rudder linkage.........so.
I thought I would try the scale linkage for the rudder while I was here.....why not!
So I fleped the arm around, moved the ball inks in to the closets hole, and cut the excess off.
This looks like it will work and as the rudder doesn't have much throw on it anyways the pull-pull should be fined
So far everything clears and there is no conflict with the elevator arm. I can attach some cables and see how it will perform. I may add one more hinge pint in this area to stiffing the lower half up.
I will make a cover plate to cover the cut out in the rudder like I did on the prototype.
TB
ID:	2067632   Click image for larger version
ID:	2067633   Click image for larger version
ID:	2067634   Click image for larger version
ID:	2067635   Click image for larger version
ID:	2067636   Click image for larger version
ID:	2067637   Click image for larger version
ID:	2067638   Click image for larger version
ID:	2067640   Click image for larger version
ID:	2067641   Click image for larger version
ID:	2067642   Click image for larger version
ID:	2067643   Click image for larger version
ID:	2067644   Click image for larger version
ID:	2067645   Click image for larger version
ID:	2067646   Click image for larger version
Old 01-25-2015, 11:41 AM
  #1645
TonyBuilder
I successfully installed the pull-pull cables and attached them to the rudder arm.
I just routed them to see if this will work and it does.
So I will glue the arm in and finish the rudder next
TB
ID:	2067656   Click image for larger version
Old 01-25-2015, 07:41 PM
  #1646
rt3232
T/B
Things are looking great, nice job
Cheers Bob T
Old 01-26-2015, 02:33 AM
  #1647
TonyBuilder
Thanks Bob, I am really liking this RTC kit. One thing I noticed is that unlike the kit version that only has a few 1/4" strigers this kit has twice as many stringers just like I did with my kit builds. I just don't get why the kit is so much weaker in design and in construction (materials) then the RTC or ARF! Really wish I would have found this before I started the Angie build, ironically I almost got the RTC after the prototype crashed but it was out of stock and I did not have a clue that it was so well made.
I laid up the tail wheel door skin. I have the doors from the prototype that I may use as they worked pretty good. That is next on the bench.
TB
Old 01-26-2015, 04:23 PM
  #1648
TonyBuilder
So I am seriously considering trying a Solo 4 blade prop for this bird. Being it will have the DLE85 it can swing the prop. I have been talking with Patrick from Solo props, he mentioned that the prop is rated for 5000 rpm max in flight. Not sure what to think about that. I have been using a 26x10 xoar prop with mid 6500 RPM and 39lb static thrust. I know the four blad will be closer to 30lb thrust with this build should be ok as I want this to come in at 30lb+- I'm thinking a 22" prop but 24" seems better as my pos Biela 22x10x4 was useless.
so has anny one within a stones throw of this thread have any info on Solo props and two strok engines. As to the 5000 rpm max,
thanks
TB
Old 01-26-2015, 04:39 PM
  #1649
TonyBuilder
Got some good news, Amy my airbrush artist (on retainer for Angie) is going to do the noes art for Miss Fire
no decals for this pinup!
TB
Old 01-27-2015, 07:28 AM
  #1650
FlyerInOKC
FlyerInOKC's Avatar
Cool! How long will it take her?
