Reload this Page >
Top Flite GS P-47 sports scale; diary of a build
Old 05-05-2015, 04:45 AM
  #2076
FlyerInOKC
FlyerInOKC's Avatar
Looking good TB! Love the video! Only thing missing is the bombing.
Old 05-07-2015, 01:51 PM
  #2077
TonyBuilder
TonyBuilder's Avatar
Back at the wing today. I got the left side inner door hooked up and both are working well, next will be the upper and lower doors. My plan is to get the wing done this weekend. I would like to have the plane ready to fly next weekend when I go to Apache pas as they have a really big grass runway, great for maidens. Maybe I will play hooky next week and get her done.
TB
Old 05-07-2015, 07:04 PM
  #2078
rt3232
T/B
Works for me, but I like your pic's and comments as I save a lot for reference.
Cheers Bob T
Old 05-08-2015, 03:06 PM
  #2079
TonyBuilder
Pics will post in the morning of the completed main gear and gear doors.
TB
Old 05-09-2015, 03:33 AM
  #2080
TonyBuilder
Default Main Gear
The main gear is completed, both sides have working doors.
Once I have the air hooked up I will do final trimming.
They are not perfectly matched but close enough. When I do the Miester I will do the doors first making two identical sets then cut them in.
The gap is a little bigger on the left wing and I will make the right to match as I don't want any binding issues.
The inner doors are adjustable as to the throw on the open position and once I am ready to install them for good I will set them equally.
The gear is set so it is flat to the wing when the doors are closed and the wheel is inside. This gives the wheels a slight toe in. If I want to change that I would have to sand the gear strut to change the angle but I don't think I will do that on this build, a little toe in cant hurt.
TB
ID:	2094765   Click image for larger version
ID:	2094766   Click image for larger version
ID:	2094767   Click image for larger version
ID:	2094768   Click image for larger version
ID:	2094769   Click image for larger version
ID:	2094770   Click image for larger version
ID:	2094771   Click image for larger version
ID:	2094773   Click image for larger version
ID:	2094774   Click image for larger version
ID:	2094775   Click image for larger version
ID:	2094776   Click image for larger version
ID:	2094777   Click image for larger version
ID:	2094778   Click image for larger version
Old 05-09-2015, 03:49 AM
  #2081
TonyBuilder
Default Gear door detailing
Now that the gear doors are installed on both sides I am doing the door detailing.
Upper door.
The hinge is a single Robart hinge pin that is flattened on one side and tap threaded with a 1/72 tap, then bolted with two button head screws.
Once the doors are covered I will use stainless steel screws.
The frame is detailed with carbon fiber strips
The linkage is a miss mash of the parts that are supplied with the gear. The ones that come with the gear are to long and hard to get the geometry right so I made my own that are shorter and more manageable.
this method works good and should hold up to the riggers of RC flying.
TB
ID:	2094780   Click image for larger version
ID:	2094781   Click image for larger version
ID:	2094782   Click image for larger version
ID:	2094783   Click image for larger version
ID:	2094784   Click image for larger version
ID:	2094785   Click image for larger version
ID:	2094786   Click image for larger version
ID:	2094788   Click image for larger version
ID:	2094789   Click image for larger version
ID:	2094790   Click image for larger version
ID:	2094791   Click image for larger version
Old 05-09-2015, 04:04 AM
  #2082
rt3232
T/B
I like it
Cheers Bob T
Old 05-09-2015, 04:12 AM
  #2083
TonyBuilder
Default Inner doors
Detailing on the inner door is done with balsa sticks and .05" thick sheet styrene.
Inner door.
The hinge is a piano hinge with a removable pine.
Bracket that is attached to the door is aluminum angle cut down, tap threaded with two 2/56 button head screws.
I went with a smaller quick link and drilled it out to house the cylinder rood.
A flat grove is cut into the rod as I cut the treads off, this is a much better way to install then with a clevis or ball link.
The door is adjustable so I can get the proper open setting. The cylinder does not close all the way so it keeps constant pressure on the door in the closed position.
The balsa framing is 1/4" sticks installed to give the contouring desired.
I went with the styrene because it is very flexible and will couture to the different elevations of the frame and the curvature of the door.
There is a wheel indentation at the hinge to allow the wheel to pass the door when it goes in and out.
The sides are the same styrene cut and sanded. The styrene is very easy to work with and gives a great surface for painting and detailing.
You can see that the wheel just clears the door at the indentation.
The wheel sits in the wing with plenty of room and still does not bottom out.
Doing the three spar wing really paid off.
TB
ID:	2094794   Click image for larger version
ID:	2094795   Click image for larger version
ID:	2094796   Click image for larger version
ID:	2094797   Click image for larger version
ID:	2094798   Click image for larger version
ID:	2094799   Click image for larger version
ID:	2094800   Click image for larger version
ID:	2094802   Click image for larger version
ID:	2094803   Click image for larger version
ID:	2094804   Click image for larger version
ID:	2094805   Click image for larger version
ID:	2094806   Click image for larger version
ID:	2094807   Click image for larger version
ID:	2094808   Click image for larger version
Old 05-09-2015, 04:28 AM
  #2084
TonyBuilder
Default Lower door
The lower door is balsa stick framed and styrene covered.
The door is held with three 2/56 button head screws tap threaded into the gear lower strut.
Balsa is glued to the door and sanded to the desired contouring.
The styrene skin is glued to the frame, then trimmed and sanded flush, the sides then get glued, trimmed and sanded.
The door tapers as it goes from the bottom to the top as to clear the ole strut.
The wheel will get shimmed with fiber washers to keep the wheel from rubbing on the door.
The wheel sits high in the wheel well and once it is shimmed it will still not bottom out.
I will prime the inner side of the doors, sand, then add rivets and paint yellow. I will cover them first.
TB
ID:	2094810   Click image for larger version
ID:	2094811   Click image for larger version
ID:	2094812   Click image for larger version
ID:	2094813   Click image for larger version
ID:	2094814   Click image for larger version
ID:	2094815   Click image for larger version
ID:	2094816   Click image for larger version
ID:	2094818   Click image for larger version
ID:	2094819   Click image for larger version
ID:	2094820   Click image for larger version
ID:	2094821   Click image for larger version
ID:	2094822   Click image for larger version
ID:	2094823   Click image for larger version
Old 05-09-2015, 05:03 AM
  #2085
Elcorro
Elcorro's Avatar
Beautiful work Tony! Your work is inspiring, and enjoyable to watch as you progress. Kinda off the subject, but could you point me in the right direction and show me how to post pics. Thanks
Old 05-09-2015, 01:27 PM
  #2086
TonyBuilder
Just go to reply, then click on "go advanced" scroll down and select "manage images and it will bring up the upload window.
TB
Old 05-09-2015, 01:40 PM
  #2087
TonyBuilder
Been fine tuning the gear getting them all lined up and trimmed.
I flipped the wing to operate the gear as they will be when in flight to make sure they are locking in the up.
I added the lip to the lower door for the inner door to close onto.
The finishing touches to the wheel well.
Some pics of how the gear will look with the plane upright.
Next I will cover the doors, prime and detail with rivets.
TB
Name:	gear 2 011.JPG
ID:	2094929   Click image for larger version
Name:	gear 2 001.JPG
ID:	2094930   Click image for larger version
Name:	gear 2 002.JPG
ID:	2094931   Click image for larger version
Name:	gear 2 003.JPG
ID:	2094933   Click image for larger version
Name:	gear 2 004.JPG
ID:	2094935   Click image for larger version
Name:	gear 2 005.JPG
ID:	2094936   Click image for larger version
Name:	gear 2 006.JPG
ID:	2094937   Click image for larger version
Name:	gear 2 007.JPG
Name:	gear 2 008.JPG
ID:	2094940   Click image for larger version
Name:	gear 2 009.JPG
ID:	2094941   Click image for larger version
Name:	gear 2 010.JPG
ID:	2094942   Click image for larger version
ID:	2094944   Click image for larger version
ID:	2094945   Click image for larger version
ID:	2094946   Click image for larger version
Name:	gear 2 012.JPG
ID:	2094948   Click image for larger version
Name:	gear 2 013.JPG
Name:	gear 2 014.JPG
ID:	2094950   Click image for larger version
Name:	gear 2 015.JPG
ID:	2094951   Click image for larger version
Name:	gear 2 018.JPG
Old 05-09-2015, 06:43 PM
  #2088
rt3232
Hi T/B
It really look great !
Cheers Bob T
Old 05-10-2015, 12:26 PM
  #2089
TonyBuilder
Got the gear doors all detailed.
Doors first get covered with the brushed aluminum.
Then primed white.
Rivets on the covering.
Rivets on the inside.
Then yellow paint will finish them off.
TB
Name:	gear detailing 001.JPG
ID:	2095141   Click image for larger version
Name:	gear detailing 002.JPG
ID:	2095142   Click image for larger version
Name:	gear detailing 003.JPG
ID:	2095143   Click image for larger version
Name:	gear detailing 004.JPG
ID:	2095144   Click image for larger version
Name:	gear detailing 005.JPG
ID:	2095145   Click image for larger version
Name:	gear detailing 006.JPG
ID:	2095146   Click image for larger version
Name:	gear detailing 007.JPG
ID:	2095147   Click image for larger version
Name:	gear detailing 008.JPG
Name:	gear detailing 009.JPG
ID:	2095149   Click image for larger version
Name:	gear detailing 010.JPG
ID:	2095150   Click image for larger version
Name:	gear detailing 011.JPG
ID:	2095151   Click image for larger version
Name:	gear detailing 012.JPG
ID:	2095152   Click image for larger version
Name:	gear detailing 013.JPG
ID:	2095153   Click image for larger version
Name:	gear detailing 014.JPG
ID:	2095154   Click image for larger version
Name:	gear detailing 015.JPG
ID:	2095155   Click image for larger version
Name:	gear detailing 016.JPG
Name:	gear detailing 017.JPG
ID:	2095157   Click image for larger version
Name:	gear detailing 018.JPG
ID:	2095158   Click image for larger version
Name:	gear detailing 019.JPG
ID:	2095159   Click image for larger version
Name:	gear detailing 020.JPG
ID:	2095160   Click image for larger version
Name:	gear detailing 021.JPG
Old 05-15-2015, 03:33 AM
  #2090
TonyBuilder
Back to the wing today.
I laid up the carbon fiber pocket last night and cut it this morning.
I sand the TE of the top of the wing so I get 1.5mm thickness when the CF pocket is glued in.
I glued it in with epoxy.
This is what I am copping, the right side.
This will give me a clean platform to detail.
I will cut and install the hinges today then start sanding the wing.
TB
Name:	flap pocket 001.JPG
ID:	2096062   Click image for larger version
Name:	flap pocket 002.JPG
ID:	2096063   Click image for larger version
Name:	flap pocket 003.JPG
ID:	2096064   Click image for larger version
Name:	flap pocket 004.JPG
ID:	2096065   Click image for larger version
Name:	flap pocket 005.JPG
ID:	2096066   Click image for larger version
Name:	flap pocket 006.JPG
ID:	2096067   Click image for larger version
Name:	flap pocket 007.JPG
ID:	2096068   Click image for larger version
Name:	flap pocket 008.JPG
Name:	flap pocket 009.JPG
ID:	2096070   Click image for larger version
Name:	flap pocket 010.JPG
Old 05-15-2015, 03:37 AM
  #2091
TonyBuilder
Rcu dp
Old 05-15-2015, 04:40 PM
  #2092
rt3232
Hi T/B
Great work on the pocket's
Cheers Bob T
Old 05-16-2015, 04:07 AM
  #2093
TonyBuilder
Thanks Bob,
I am getting some more work done on the wing, actually looks like a P-47 wing now.
The flap hinges are cut and assembled.
They work really well much stronger and stiffer then Robart hinge points.
I need to tune the gaps up, at least 3/16" to 1/4" is needed so the flap and aileron don't bind.
The pocket will finish out nicely as it will be seen when in static display and the flaps are at rest.
I still need to install the flap hinges on the left side.
I started to rough sand the wing to shape the wing tips and the LE.
I got to excited and over sanded the TE of the wing tips where they meet the aileron tip, so I will just cut that out and glue in a piece of balsa, no biggie.
I normally sand the tip with the aileron installed, got excited.
I am ready to glass the center and mount the wing to the fuselage so I can build the belly.
Then final filling and sanding.
TB
ID:	2096297   Click image for larger version
ID:	2096298   Click image for larger version
ID:	2096299   Click image for larger version
ID:	2096300   Click image for larger version
ID:	2096301   Click image for larger version
ID:	2096302   Click image for larger version
ID:	2096303   Click image for larger version
ID:	2096305   Click image for larger version
ID:	2096306   Click image for larger version
ID:	2096307   Click image for larger version
ID:	2096308   Click image for larger version
ID:	2096309   Click image for larger version
ID:	2096310   Click image for larger version
ID:	2096311   Click image for larger version
ID:	2096313   Click image for larger version
ID:	2096314   Click image for larger version
ID:	2096315   Click image for larger version
ID:	2096316   Click image for larger version
ID:	2096317   Click image for larger version
ID:	2096318   Click image for larger version
ID:	2096319   Click image for larger version
ID:	2096321   Click image for larger version
ID:	2096322   Click image for larger version
Old 05-16-2015, 06:36 AM
  #2094
Melchizedek
Melchizedek's Avatar
Nice work Tony.
I love the no muss no fuse way of dealing with the control surface pockets. Will never go the hard way again.
Kevin
Old 05-16-2015, 01:53 PM
  #2095
TonyBuilder
Daily progress.
I decided it was time for the wing to meet the fuselage.
Being this is a bashed TFGS P-47 with the wings being kit built and the fuselage being the RTC there is some differences.
The wing fits perfectly in the saddle.
The way the dowels are set on the RTC is further apart and the mounting bolts are way back on the RTC.
I am using 3/8" aluminum dowels and steel bolts for the mounting.
I drilled the 3/8" dowels in and they go threw the front spar, there glued in with epoxy.
I still need to fill in the front but will do that when I do the belly.
I cut out the mounts that were to far back and glued in a new one.
Blind nut is installed and a steel bolt, I need to glue in a washer and a tube when I do the belly.
I test fit the belly and will install that tomorrow, need to go to the HS and get some 1/4" stringers.
Getting there.
TB
Name:	wing mating 001.JPG
ID:	2096406   Click image for larger version
Name:	wing mating 002.JPG
ID:	2096407   Click image for larger version
Name:	wing mating 003.JPG
ID:	2096408   Click image for larger version
Name:	wing mating 004.JPG
ID:	2096409   Click image for larger version
Name:	wing mating 005.JPG
ID:	2096410   Click image for larger version
Name:	wing mating 006.JPG
ID:	2096411   Click image for larger version
Name:	wing mating 007.JPG
ID:	2096412   Click image for larger version
Name:	wing mating 008.JPG
Name:	wing mating 009.JPG
Old 05-16-2015, 03:57 PM
  #2096
rt3232
T/B
I like it, but have to say with 2 dowels I have never had them ware out even after 20 years on my old dragon lady, and never had 1/4 plastic (not nylon) bolts come loose or brake. except when I have dumb thumbed a bird into the ground and I have to admit I have done my share.
But that is just me .
Cheers Bob T
Old 05-16-2015, 06:05 PM
  #2097
TonyBuilder
Bob, I'm new at this with relitivly less experience, just seams if I can use an aluminum dowel over a wood one I will. I have never liked the plastic bolts for holding wings on, I have had good results doing things this way so why change, gues I've gone down a serton path and can't look back
TB
Old 05-18-2015, 04:00 AM
  #2098
TonyBuilder
Wing progress.
I like to lock in T-bolts as they have this tendency to pop out or rotate. If that happens you are screwed and will have to cut it out.
So I use a piece of ply and glue that over the T-bolt and sandwich it in, not going to pop out on me.
The belly pan is glued in and came out pretty good considering it came from my first kit build.
Easy sand to finish it off
TB
ID:	2096697   Click image for larger version
ID:	2096698   Click image for larger version
ID:	2096699   Click image for larger version
ID:	2096700   Click image for larger version
ID:	2096701   Click image for larger version
ID:	2096702   Click image for larger version
ID:	2096703   Click image for larger version
ID:	2096705   Click image for larger version
ID:	2096706   Click image for larger version
ID:	2096707   Click image for larger version
ID:	2096708   Click image for larger version
ID:	2096709   Click image for larger version
ID:	2096710   Click image for larger version
ID:	2096711   Click image for larger version
Old 05-18-2015, 05:37 AM
  #2099
FlyerInOKC
FlyerInOKC's Avatar
TB, I wish I had the time to build that you do, beautiful!
Old 05-18-2015, 07:49 AM
  #2100
TonyBuilder
Thanks OKC, it does take time. I spent all day installing the belly, but it's done and ready to cover, kind of instant belly.
TB
