Reload this Page >
~~Sig Kadet Brotherhood~~.
Old 06-27-2015, 03:06 PM
  #2726
ETpilot
ETpilot's Avatar
Michael good show on the flying. It is a good feeling when you get to do it on your own. Building also has its rewards. Your build and the covering looks very good. There is a learning curve to using Koverall. My LT-40 is the second time using it. I started covering the fuselage and found I was short on Koverall. I had to be a bit judicious applying what I had. I used dress liner on the bottom but the dress liner-Koverall seam looks terrible. But it's on the bottom so it will not be easily seen.
I'm going with latex so it will be interesting to see how it turns out. I'll be spraying too.
ID:	2106073   Click image for larger version
Old 06-27-2015, 03:34 PM
  #2727
michaelnel
michaelnel's Avatar
Your covering on the fuse looks great to me!
I just finished covering the vertical stabilizer. Each one comes out better than the last. Next is all the control surfaces... do you guys use one piece and wrap it around, or cover each side of the rudder, elevator, and ailerons seperately?
I think the fuselage will be the easiest for me. Pretty much all flat sides, and mine is a current SIG kit so the fuselage is mostly light ply, not sticks.
Old 06-27-2015, 06:39 PM
  #2728
soarrich
My Feedback: (98)
soarrich's Avatar
=michaelnel;12062104 I think the finished product will be nice, but man, what a labor-intensive and expensive process to use this stuff.
But is so beautiful. It's like a woman having a baby, right afterwards "never again", then they forget the pain and just see the beauty.. and it's so much fun making...:^)
Old 06-27-2015, 08:25 PM
  #2729
flyingagin
flyingagin's Avatar
Originally Posted by spaceworm
There are much less expensive alternatives to Polycrylic for finishing Koveral or dress liner or Solartex or non spec glider polyester. Search for covering with fabric here on RCU for many threads (polyester threads heh-heh) I have finished polyester dress lining with hardware store water base acrylic to good effect.
Sincerely, Richard
The plane in my avatar is covered in dress lining. An Old quart of Nitrate Had a little rust in the can, so it came out a motley brown with one coat of nitrate) for a real tight shrink, The I used Rustolium to paint it. Did not spend to much on covering and painting.
Ken
Old 06-28-2015, 04:19 AM
  #2730
skylark-flier
skylark-flier's Avatar
I sure know what you mean about covering being expensive today. I enjoyed every minute of covering my latest with koverall but the cost - not so much. Covering actually cost me more than building it. HOWEVER, once done it looks like a million dollars - and you gotta know that it'll be unique.
I gotta tell you, that wing and stab looks great too.
Press on my friend, press on.
Old 06-28-2015, 04:38 AM
  #2731
michaelnel
michaelnel's Avatar
Thank you.
Today I will get the rest of the covering done. Control surfaces and fuselage, then I will start the PolyCrylic coats, 3 total. This thing will fly someday. Sure glad I bought the ARF so I am able to fly that while this slow process goes on.
re: The ARF. The covering on that thing won't stay tight. I have tightened it three times now using an iron and following the method in the manual. When I finish, it's tight as a drum.
I take it out to the flying field and after it sits in the sun in the pits for a while, all the black stuff loosens back up and looks like hell. Wrinkles all over. We live in an area where the humidity is super low, but the temperature is often over 100 degrees in the shade. The SIG Oracover or whatever they call it does not do well in the heat.
Old 06-28-2015, 05:51 PM
  #2732
acdii
I hate plastic covering. It goes on easy, can look OK, but does not hold up to hanger rash well, where the Koverall and Dope can take a beating. Any spot that got rubbed wrong are easily touched up with dope. My Cub looks great, and my Biper is coming out very nice. Only thing I found is the red tends to come off on the towel when cleaning up. It also came out really light compared to the Chipmunk I covered in dress liner and rustoleum. I think that one, since I have to do some covering repairs, I may strip it and ultracote it.
Old 06-28-2015, 06:26 PM
  #2733
michaelnel
michaelnel's Avatar
Maybe the problem with the ARF's covering is that the wood is still full of moisture from Vietnam. It is super low humidity here (like 15%) and the black covering absorbs more heat than the white. The moisture gets baked out of the wood in the hot dry air, the black sags and loosens up (the white stays tight). Maybe eventually the thing will acclimate itself to this dry climate and stop shrinking.
Old 06-29-2015, 04:20 AM
  #2734
spaceworm
Which type of final coat of red is coming off on the towel with cleaning up? Are you using something like Windex to clean up with? Glow fuel or gasoline or a mix? Does "light compared to the Chipmunk" refer to color or weight? If you hate plastic, why are you going to use ultracote? These are genuine questions I am curious about, not flippant remarks. Thanks for your comments.
Sincerely, Richard
Old 06-29-2015, 09:04 AM
  #2735
acdii
Sincerely, Richard
It is all SIG dope, the blue doesnt come off, but the red bleeds. Ultracote is much easier to work with than monojoke, it shrinks tighter, and sticks better. The best plastic I used was from SIG, but they don't make it anymore. On the Chippy, I used Rustoleum and that bugger came out too heavy, never doing that again. Sticking with Dope or WB paints and poly or Klass Kote.
Old 06-29-2015, 10:29 AM
  #2736
soarrich
My Feedback: (98)
soarrich's Avatar
I've never used it, but I saw a thread where the guy was painting $10,000 turbine planes for people, he was using Rustoleum, and the planes looked great. It may take a different technique than you are using.
Old 06-29-2015, 01:34 PM
  #2737
TomCrump
TomCrump's Avatar
Rustoleum does not produce a heavy finish. If it did, few of my models would fly.
Rustoleum's high hiding properties allow lighter coats to be applied, and still maintain good coverage. I've painted several airframes with it, and I'm completely satisfied.
Old 06-30-2015, 03:15 AM
  #2738
N1EDM
I'm just joining this discussion... How does Rustoleum stand up to 15% Nitro??? I have to paint some fiberglass pieces with it. How about primer for use over fiberglass???
Are there different formulations of Rustoleum that I should use, or is it just plain old Rustoleum from the Home Center?
Bob
Old 06-30-2015, 03:33 AM
  #2739
TomCrump
TomCrump's Avatar
I use the Home Center variety of Rustoleum, purchased in quart cans.
Will it hold up to 15% fuel ? Probably, if you wipe it down, immediately after contact.
I use automotive primers, over fiberglass. If an aerosol is desired, Duplicolor high build is my choice.
Old 06-30-2015, 03:44 AM
  #2740
N1EDM
Thanks......
Bob
Old 06-30-2015, 06:58 AM
  #2741
FlyerInOKC
FlyerInOKC's Avatar
Tom, is that little yellow and green number a Cessna 195 and who's design is it?
Mike
Old 06-30-2015, 10:00 AM
  #2742
acdii
The spray cans of rustoleum do not hold up to any nitro, but the can stuff does. The thinners used in the spray must change the properties a bit as nitro will wrinkle it up. I think mine came out too heavy since I used white and it took a couple coats to come out even, where the colors only needed one. I may not have thinned it enough either, all I know is my chippy came out a pound heavier than it should have and that was after covering it. My SIG Cub with Koverall and dope is very light. In fact I hovered it briefly the other day, and with some practice and maintain a hover.
Old 06-30-2015, 11:17 AM
  #2743
TomCrump
TomCrump's Avatar
Mike
The model; is an IKON N'West Cessna 165. Although smaller, and fabric covered, the Airmaster shared some design features of the 195.
Old 07-03-2015, 02:17 PM
  #2744
ETpilot
ETpilot's Avatar
I got around to making my tail wheel assembly. A couple of bad practice turns in the 3/32" music wire. Figured out what it needed. Then I made the tail wheel assembly. Second picture is rough install. Last picture, picture not too good, is final install with pivot tube CA'ed in place. I will add epoxy later. Wheel is under pivot tube and turns super easy. It should work good. I will cut wire stock when vertical fin is in place and I can check it against rudder.
Next week I will do the final painting. Nothing fancy. Just good colors for weak eyes.
ID:	2107212   Click image for larger version
ID:	2107213   Click image for larger version
Old 07-03-2015, 02:25 PM
  #2745
ETpilot
ETpilot's Avatar
Well, looking at the picture it dawned on me that I did not allow for the horizontal stabilizer. Now I remember why I cut the pivot tube a bit longer. Easy fix. Cut a longer tube and replace. Good that I caught the error now.
Old 07-04-2015, 05:43 AM
  #2746
mortyspals
My Feedback: (47)
Hoping this is still the Kadet owners site.
Old 07-04-2015, 05:53 AM
  #2747
mortyspals
My Feedback: (47)
I would like to join. I have three Kadets, a 20 + year old kit built three channel Senior, a five year old tail dragger Senior arf & and an early print built three channel Seniorita. All three are still flying. Neal Smith Alexandria, Va.
Old 07-05-2015, 04:17 AM
  #2748
skylark-flier
Hey Neal! It sure is the place - always glad to meet another brother. Welcome to the SIG Kadet Brotherhood! Gotcha logged with #187. And, next time you happen to find yourself anywhere near Page County I'm hoping you've got a plane or two with you. I've got the finest flying site anywhere in the Shenandoah Valley just 2 miles from my back yard. Wide open spaces galore!
And here's the SIG Kadet Brotherhood, as I've got it today:
[TABLE="width: 507"]
[TR]
[TD]1[/TD]
[TD]-[/TD]
[TD]Gary Harris[/TD]
[TD]66[/TD]
[TD]-[/TD]
[TD]mike109[/TD]
[TD]131[/TD]
[TD]-[/TD]
[TD]UPF-7[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]-[/TD]
[TD]soarrich[/TD]
[TD]67[/TD]
[TD]-[/TD]
[TD]beevo[/TD]
[TD]132[/TD]
[TD]-[/TD]
[TD]neons[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]-[/TD]
[TD]N1EDM[/TD]
[TD]68[/TD]
[TD]-[/TD]
[TD]Lowvoltage[/TD]
[TD]133[/TD]
[TD]-[/TD]
[TD]Flyboy14901[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]-[/TD]
[TD]Live Wire[/TD]
[TD]69[/TD]
[TD]-[/TD]
[TD]skylark-flier[/TD]
[TD]134[/TD]
[TD]-[/TD]
[TD]proszak59[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]-[/TD]
[TD]5skyhawk172[/TD]
[TD]70[/TD]
[TD]-[/TD]
[TD]hugh durden[/TD]
[TD]135[/TD]
[TD]-[/TD]
[TD]wildbills21[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]-[/TD]
[TD]zippome[/TD]
[TD]71[/TD]
[TD]-[/TD]
[TD]Cloud Cruiser[/TD]
[TD]136[/TD]
[TD]-[/TD]
[TD]hairy46[/TD]
[/TR]
[TR]
[TD]7[/TD]
[TD]-[/TD]
[TD]shepard62[/TD]
[TD]72[/TD]
[TD]-[/TD]
[TD]SIGPlanes[/TD]
[TD]137[/TD]
[TD]-[/TD]
[TD]p-Yock[/TD]
[/TR]
[TR]
[TD]8[/TD]
[TD]-[/TD]
[TD]DeferredDefect[/TD]
[TD]73[/TD]
[TD]-[/TD]
[TD]rexperk[/TD]
[TD]138[/TD]
[TD]-[/TD]
[TD]rrengineer[/TD]
[/TR]
[TR]
[TD]9[/TD]
[TD]-[/TD]
[TD]archie05[/TD]
[TD]74[/TD]
[TD]-[/TD]
[TD]M. Boesen[/TD]
[TD]139[/TD]
[TD]-[/TD]
[TD]hogflyer[/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]-[/TD]
[TD]tomgreen[/TD]
[TD]75[/TD]
[TD]-[/TD]
[TD]whatwheel[/TD]
[TD]140[/TD]
[TD]-[/TD]
[TD]Firewalkerd1[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]-[/TD]
[TD]n2ryd[/TD]
[TD]76[/TD]
[TD]-[/TD]
[TD]Wagon1[/TD]
[TD]141[/TD]
[TD]-[/TD]
[TD]Flight Risk[/TD]
[/TR]
[TR]
[TD]12[/TD]
[TD]-[/TD]
[TD]race61[/TD]
[TD]77[/TD]
[TD]-[/TD]
[TD]paulhold[/TD]
[TD]142[/TD]
[TD]-[/TD]
[TD]ratshooter[/TD]
[/TR]
[TR]
[TD]13[/TD]
[TD]-[/TD]
[TD]Slavko[/TD]
[TD]78[/TD]
[TD]-[/TD]
[TD]groundstrike[/TD]
[TD]143[/TD]
[TD]-[/TD]
[TD]Steve Westphal[/TD]
[/TR]
[TR]
[TD]14[/TD]
[TD]-[/TD]
[TD]lkruse[/TD]
[TD]79[/TD]
[TD]-[/TD]
[TD]adreliable661[/TD]
[TD]144[/TD]
[TD]-[/TD]
[TD]cforcht[/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]-[/TD]
[TD]flyingagin[/TD]
[TD]80[/TD]
[TD]-[/TD]
[TD]earlwb[/TD]
[TD]145[/TD]
[TD]-[/TD]
[TD]kb8ife[/TD]
[/TR]
[TR]
[TD]16[/TD]
[TD]-[/TD]
[TD]JPNYGAARD[/TD]
[TD]81[/TD]
[TD]-[/TD]
[TD]Unclebuck21228[/TD]
[TD]146[/TD]
[TD]-[/TD]
[TD]rburke39[/TD]
[/TR]
[TR]
[TD]17[/TD]
[TD]-[/TD]
[TD]foodstick[/TD]
[TD]82[/TD]
[TD]-[/TD]
[TD]malitape[/TD]
[TD]147[/TD]
[TD]-[/TD]
[TD]rc56[/TD]
[/TR]
[TR]
[TD]18[/TD]
[TD]-[/TD]
[TD]ovationdave[/TD]
[TD]83[/TD]
[TD]-[/TD]
[TD]Dave Holmes[/TD]
[TD]148[/TD]
[TD]-[/TD]
[TD]redjack[/TD]
[/TR]
[TR]
[TD]19[/TD]
[TD]-[/TD]
[TD]joebahl[/TD]
[TD]84[/TD]
[TD]-[/TD]
[TD]Carlos G[/TD]
[TD]149[/TD]
[TD]-[/TD]
[TD]rdgettler[/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]-[/TD]
[TD]WI53072[/TD]
[TD]85[/TD]
[TD]-[/TD]
[TD]kingranch[/TD]
[TD]150[/TD]
[TD]-[/TD]
[TD]daddyvinny[/TD]
[/TR]
[TR]
[TD]21[/TD]
[TD]-[/TD]
[TD]huck1199[/TD]
[TD]86[/TD]
[TD]-[/TD]
[TD]Red Kadet[/TD]
[TD]151[/TD]
[TD]-[/TD]
[TD]MartyPetriSr[/TD]
[/TR]
[TR]
[TD]22[/TD]
[TD]-[/TD]
[TD]Top_Gunn[/TD]
[TD]87[/TD]
[TD]-[/TD]
[TD]dirtrod[/TD]
[TD]152[/TD]
[TD]-[/TD]
[TD]tomclark[/TD]
[/TR]
[TR]
[TD]23[/TD]
[TD]-[/TD]
[TD]Nergall[/TD]
[TD]88[/TD]
[TD]-[/TD]
[TD]t4[/TD]
[TD]153[/TD]
[TD]-[/TD]
[TD]c-crunch[/TD]
[/TR]
[TR]
[TD]24[/TD]
[TD]-[/TD]
[TD]acdii[/TD]
[TD]89[/TD]
[TD]-[/TD]
[TD]FlyerInOKC[/TD]
[TD]154[/TD]
[TD]-[/TD]
[TD]BigTeeEldorado[/TD]
[/TR]
[TR]
[TD]25[/TD]
[TD]-[/TD]
[TD]hutchis[/TD]
[TD]90[/TD]
[TD]-[/TD]
[TD]DELTAFLY[/TD]
[TD]155[/TD]
[TD]-[/TD]
[TD]TomCrump[/TD]
[/TR]
[TR]
[TD]26[/TD]
[TD]-[/TD]
[TD]ddewey[/TD]
[TD]91[/TD]
[TD]-[/TD]
[TD]sharpe917[/TD]
[TD]156[/TD]
[TD]-[/TD]
[TD]hiflyer15[/TD]
[/TR]
[TR]
[TD]27[/TD]
[TD]-[/TD]
[TD]dhal22[/TD]
[TD]92[/TD]
[TD]-[/TD]
[TD]jollyroger[/TD]
[TD]157[/TD]
[TD]-[/TD]
[TD]Fly North[/TD]
[/TR]
[TR]
[TD]28[/TD]
[TD]-[/TD]
[TD]Thomas Pham[/TD]
[TD]93[/TD]
[TD]-[/TD]
[TD]Cliffc[/TD]
[TD]158[/TD]
[TD]-[/TD]
[TD]dwaynenancy[/TD]
[/TR]
[TR]
[TD]29[/TD]
[TD]-[/TD]
[TD]cubkadet[/TD]
[TD]94[/TD]
[TD]-[/TD]
[TD]1320fastback[/TD]
[TD]159[/TD]
[TD]-[/TD]
[TD]oinoyou[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]-[/TD]
[TD]Greg Davis[/TD]
[TD]95[/TD]
[TD]-[/TD]
[TD]Captinjohn[/TD]
[TD]160[/TD]
[TD]-[/TD]
[TD]Jersy Hank[/TD]
[/TR]
[TR]
[TD]31[/TD]
[TD]-[/TD]
[TD]CanDo[/TD]
[TD]96[/TD]
[TD]-[/TD]
[TD]spaceworm[/TD]
[TD]161[/TD]
[TD]-[/TD]
[TD]flashpilot[/TD]
[/TR]
[TR]
[TD]32[/TD]
[TD]-[/TD]
[TD]gva1956[/TD]
[TD]97[/TD]
[TD]-[/TD]
[TD]EvanB[/TD]
[TD]162[/TD]
[TD]-[/TD]
[TD]Old_RC_Guy[/TD]
[/TR]
[TR]
[TD]33[/TD]
[TD]-[/TD]
[TD]metaldriver_2[/TD]
[TD]98[/TD]
[TD]-[/TD]
[TD]Major Tomski[/TD]
[TD]163[/TD]
[TD]-[/TD]
[TD]TheComputerGeek[/TD]
[/TR]
[TR]
[TD]34[/TD]
[TD]-[/TD]
[TD]Bladejunkie[/TD]
[TD]99[/TD]
[TD]-[/TD]
[TD]Jim Branaum[/TD]
[TD]164[/TD]
[TD]-[/TD]
[TD]FloridaBeachFlyr[/TD]
[/TR]
[TR]
[TD]35[/TD]
[TD]-[/TD]
[TD]New222[/TD]
[TD]100[/TD]
[TD]-[/TD]
[TD]WLM189[/TD]
[TD]165[/TD]
[TD]-[/TD]
[TD]aggieman[/TD]
[/TR]
[TR]
[TD]36[/TD]
[TD]-[/TD]
[TD]cubflyman[/TD]
[TD]101[/TD]
[TD]-[/TD]
[TD]skyraider71[/TD]
[TD]166[/TD]
[TD]-[/TD]
[TD]Renegade[/TD]
[/TR]
[TR]
[TD]37[/TD]
[TD]-[/TD]
[TD]dasquirrelisme[/TD]
[TD]102[/TD]
[TD]-[/TD]
[TD]rc lifer[/TD]
[TD]167[/TD]
[TD]-[/TD]
[TD]T-47[/TD]
[/TR]
[TR]
[TD]38[/TD]
[TD]-[/TD]
[TD]Planejaw[/TD]
[TD]103[/TD]
[TD]-[/TD]
[TD]NM2K[/TD]
[TD]168[/TD]
[TD]-[/TD]
[TD]SigSenior[/TD]
[/TR]
[TR]
[TD]39[/TD]
[TD]-[/TD]
[TD]usc1990[/TD]
[TD]104[/TD]
[TD]-[/TD]
[TD]terrysigcolt[/TD]
[TD]169[/TD]
[TD]-[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]40[/TD]
[TD]-[/TD]
[TD]cjet[/TD]
[TD]105[/TD]
[TD]-[/TD]
[TD]plane-o-joe[/TD]
[TD]170[/TD]
[TD]-[/TD]
[TD]WMB[/TD]
[/TR]
[TR]
[TD]41[/TD]
[TD]-[/TD]
[TD]Murphey[/TD]
[TD]106[/TD]
[TD]-[/TD]
[TD]BobFE[/TD]
[TD]171[/TD]
[TD]-[/TD]
[TD]ckimmey[/TD]
[/TR]
[TR]
[TD]42[/TD]
[TD]-[/TD]
[TD]Sandyt[/TD]
[TD]107[/TD]
[TD]-[/TD]
[TD]FLAPSDOWN[/TD]
[TD]172[/TD]
[TD]-[/TD]
[TD]paul7194[/TD]
[/TR]
[TR]
[TD]43[/TD]
[TD]-[/TD]
[TD]planedriver_2[/TD]
[TD]108[/TD]
[TD]-[/TD]
[TD]scttsprg[/TD]
[TD]173[/TD]
[TD]-[/TD]
[TD]bebopgolf[/TD]
[/TR]
[TR]
[TD]44[/TD]
[TD]-[/TD]
[TD]PT19[/TD]
[TD]109[/TD]
[TD]-[/TD]
[TD]sbrillha[/TD]
[TD]174[/TD]
[TD]-[/TD]
[TD]Big Stikflyer[/TD]
[/TR]
[TR]
[TD]45[/TD]
[TD]-[/TD]
[TD]TimHendrix[/TD]
[TD]110[/TD]
[TD]-[/TD]
[TD]Mike Gretz[/TD]
[TD]175[/TD]
[TD]-[/TD]
[TD]nealmontgomery[/TD]
[/TR]
[TR]
[TD]46[/TD]
[TD]-[/TD]
[TD]jessiej[/TD]
[TD]111[/TD]
[TD]-[/TD]
[TD]skyrat71[/TD]
[TD]176[/TD]
[TD]-[/TD]
[TD]Battle Short[/TD]
[/TR]
[TR]
[TD]47[/TD]
[TD]-[/TD]
[TD]Mr-Punk[/TD]
[TD]112[/TD]
[TD]-[/TD]
[TD]lumppi[/TD]
[TD]177[/TD]
[TD]-[/TD]
[TD]canadian8apilot[/TD]
[/TR]
[TR]
[TD]48[/TD]
[TD]-[/TD]
[TD]rccrasher65[/TD]
[TD]113[/TD]
[TD]-[/TD]
[TD]bchapman[/TD]
[TD]178[/TD]
[TD]-[/TD]
[TD]Mud Duck[/TD]
[/TR]
[TR]
[TD]49[/TD]
[TD]-[/TD]
[TD]FMAY[/TD]
[TD]114[/TD]
[TD]-[/TD]
[TD]scoooper[/TD]
[TD]179[/TD]
[TD]-[/TD]
[TD]EDDIEMAC[/TD]
[/TR]
[TR]
[TD]50[/TD]
[TD]-[/TD]
[TD]Hrannar[/TD]
[TD]115[/TD]
[TD]-[/TD]
[TD]Jolly Popper[/TD]
[TD]180[/TD]
[TD]-[/TD]
[TD]merto31[/TD]
[/TR]
[TR]
[TD]51[/TD]
[TD]-[/TD]
[TD]Razor44[/TD]
[TD]116[/TD]
[TD]-[/TD]
[TD]CNY_Dave[/TD]
[TD]181[/TD]
[TD]-[/TD]
[TD]bisszerk[/TD]
[/TR]
[TR]
[TD]52[/TD]
[TD]-[/TD]
[TD]Ken Kehlet[/TD]
[TD]117[/TD]
[TD]-[/TD]
[TD]rtn9105[/TD]
[TD]182[/TD]
[TD]-[/TD]
[TD]Pork Chop[/TD]
[/TR]
[TR]
[TD]53[/TD]
[TD]-[/TD]
[TD]oldfartpilot[/TD]
[TD]118[/TD]
[TD]-[/TD]
[TD]mbnt
[/TD]
[TD]183[/TD]
[TD]-[/TD]
[TD]bushman8377[/TD]
[/TR]
[TR]
[TD]54[/TD]
[TD]-[/TD]
[TD]Soaring Steve[/TD]
[TD]119[/TD]
[TD]-[/TD]
[TD]crawler tech[/TD]
[TD]184[/TD]
[TD]-[/TD]
[TD]cmy6[/TD]
[/TR]
[TR]
[TD]55[/TD]
[TD]-[/TD]
[TD]freefall2907[/TD]
[TD]120[/TD]
[TD]-[/TD]
[TD]308jockey[/TD]
[TD]185[/TD]
[TD]-[/TD]
[TD]ETpilot
[/TD]
[/TR]
[TR]
[TD]56[/TD]
[TD]-[/TD]
[TD]fix-n-fly[/TD]
[TD]121[/TD]
[TD]-[/TD]
[TD]bparker3[/TD]
[TD]186[/TD]
[TD]-[/TD]
[TD]michaelnel[/TD]
[/TR]
[TR]
[TD]57[/TD]
[TD]-[/TD]
[TD]SigMan[/TD]
[TD]122[/TD]
[TD]-[/TD]
[TD]DBD1[/TD]
[TD]187[/TD]
[TD]-[/TD]
[TD]mortyspals[/TD]
[/TR]
[TR]
[TD]58[/TD]
[TD]-[/TD]
[TD]eroc144[/TD]
[TD]123[/TD]
[TD]-[/TD]
[TD]Chappy110[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]59[/TD]
[TD]-[/TD]
[TD]nextofkin[/TD]
[TD]124[/TD]
[TD]-[/TD]
[TD]ercobud[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]60[/TD]
[TD]-[/TD]
[TD]ALT[/TD]
[TD]125[/TD]
[TD]-[/TD]
[TD]rickpell[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]61[/TD]
[TD]-[/TD]
[TD]jstyle13[/TD]
[TD]126[/TD]
[TD]-[/TD]
[TD]ThunderBoat[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]62[/TD]
[TD]-[/TD]
[TD]WYDAH[/TD]
[TD]127[/TD]
[TD]-[/TD]
[TD]tazzzz[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]63[/TD]
[TD]-[/TD]
[TD]stupidscreenname[/TD]
[TD]128[/TD]
[TD]-[/TD]
[TD]ThunderChicken[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]64[/TD]
[TD]-[/TD]
[TD]coxco[/TD]
[TD]129[/TD]
[TD]-[/TD]
[TD]deanz406[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]65[/TD]
[TD]-[/TD]
[TD]TunnelBill[/TD]
[TD]130[/TD]
[TD]-[/TD]
[TD]biam[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[/TABLE]
Old 07-06-2015, 10:37 AM
  #2749
richard dee
richard dee's Avatar
Hey I built a senior scaled up to 12 feet wing .Flown with ryobi 31 now going to an old byron engine from their Mustang .The huge one ,this engine is a gasser 70 75 should be able to pull it around great. I also built a prop cutter so I can build large props cutting my cost
I am the skater of many cheaps.Also make my own fuel ,More cheaps.I wish I could build batteries.LOL LOL
Old 07-06-2015, 11:26 AM
  #2750
soarrich
My Feedback: (98)
soarrich's Avatar
I think a lemon and a galvanized nail works. :^)
12 foot, That's BIG. I wonder if anyone ever built an Ultralight Kadet?
