Reload this Page >
~~Sig Kadet Brotherhood~~.
Old 01-03-2018, 07:49 PM
  #3501
Hydro Junkie
Hydro Junkie's Avatar
Originally Posted by skylark-flier
Geez guys, that's TOO cool!! I must be getting old or something - never even thought to check that out. Gotta tell ya, I like the idea of a stick-built Mk-II too. Very interesting idea.
I just look at the cost of a kit and how much it costs to modify it into what you want as compared to what it would cost to build what you want to begin with. I'm also looking at the weight you can save by "stick building" the tail feathers against what it weighs to use solid slab parts. If I built a vertical stab out of 3/16 stick frames with 1/32 ply over the top, I figure I can save almost half the weight. That means I don't have to cram everything up against the firewall and/or add dead weight in the nose to get the plane to balance
Old 01-03-2018, 07:55 PM
  #3502
skylark-flier
skylark-flier's Avatar
Absolutely, I see your point. I'm thinking of your probable weight saving in building a Mk-II stick-style vs slab AND what a Kadet Senior built as a slab-style might weigh. The weight savings HAS to be considerable - probably to the point that the same .45 that powers my Mk-II now would probably allow something approaching 3D capability if it were stick. VERY interesting proposition.
Old 01-04-2018, 10:41 AM
  #3503
Hydro Junkie
Been doing a bit more thinking and figure I might be better served if I build the fuse with 1/8" lite ply sides with lightening holes aft of the wing rather than the solid sheet balsa. A benefit of doing so would be not having to splice the last few inches of side to the rest of the structure, a minor weakness in the MKII design, especially if built as a tail dragger. The second benefit would be less tail weight, just like stick building the tail feathers. I'm thinking that, if I build it lite enough, I could get away with using an OS .35AX rather than the bigger .46AX that most would turn to. Only problem I see in using the smaller engine is it's $20 higher in price. Another possible solution to the engine would be using a Rimfire .32 Brushless. It's supposed to handle a 6lb plane and a stock built MKII supposedly weighs in at 5lbs. Just a matter now of getting the wife to sign off on this little project
Old 01-04-2018, 11:46 AM
  #3504
skylark-flier
I don't know about everybody else but I build my planes to pretty much survive combat conditions - in other words, HEAVY!! Ex: my CG Sr Falcon was designed to come to 6.25 lbs - it was originally 7.25 and presently weighs 7.5 lbs. My Stratus was supposed to be 6.5-7.5 lbs, she's 8.5 lbs. All my planes are this way, except the Kadet Mk-II. She's supposed to be 5 lbs, mine came out at 4.875 lbs - - FIRST EVER PLANE TO BE LESS THAN DESIGNED, and I've been building since 1955. If I can make them this light, everybody else is probably making them at 4 lbs. You'll be fine.
Old 01-04-2018, 11:48 AM
  #3505
FlyerInOKC
FlyerInOKC's Avatar
Hey Hydro if you are going to entertain electric check one of these. You will get more bang for the buck and the company is real easy to work with. I haven't had any problems ith the motors or ESCs I have bought from them.
Leopard Power 3542/5T 1080KV Outrunner Brushless Motor
Leopard Power 4250/5.5T 800KV Outrunner Brushless Motor
Power Up 46 Sport 620kv 1000 Watt Brushless Outrunner
Power Up 32 Sport 800kv Outrunner Brushless Motor
Here are a few ESCs that would probably work too.
Sky Power 60A ESC with Switchmode BEC
Hifei 60A ESC with Switchmode BEC
Sky Power 80A ESC with Switchmode BEC
Old 01-04-2018, 12:29 PM
  #3506
Hydro Junkie
I tend to build my "toys" as lite as I can. As I've told several in the boating world, "If you're going to build something, make it as lite as you can. It's a lot easier to add weight to a finished boat than it is to remove it". I tend to do that with my planes as well. If I can reduce the weight without compromising strength, why not do so? I've butted heads over it on more than one occasion as well, some would rather build a heavy boat so that it won't blow over rather than build a boat that will be competitive
Old 01-04-2018, 06:22 PM
  #3507
acdii
A challenge then, build a Rascal 168 light!
Old 01-04-2018, 07:19 PM
  #3508
Hydro Junkie
Not happening. That thing is just too expensive, for now anyway, and I don't have any way, other than putting it in my camp trailer, to get it to a flying field
Old 01-04-2018, 09:13 PM
  #3509
Pork Chop
Pork Chop's Avatar
Where I like in Northern California we get the wind blowing straight up through the San Francisco bay like a wind tunnel which is why they built Travis AFB here. A little weight does survive combat conditions and is better in gusty conditions. Dave, you've been building since 1955? That means you're more.... experienced than me! Just kidding!
Old 01-05-2018, 06:44 AM
  #3510
FlyerInOKC
FlyerInOKC's Avatar
Around here a 20 Mph wind is the norm so a little weight helps here too. I watched a friend once flying a little ARF Funtana into the wind and he wasn't making any forward movement! The plane was so light and the wind so strong it just hovered.
Old 01-05-2018, 11:48 AM
  #3511
skylark-flier
Yup! First build was a Guillows DR-1, covered in tissue, painted with Aerogloss red (of course). Got it for Christmas 1954, had it in the air by May 1955. My father came up with the idea of reinforcing the landing gear with wire - ended up pretty strong, survived a fair number of FF flights/landings. Powered with a Cox .020
My first C/L plane was a Cox PT19, which still flies occasionally. Also a Christmas 1954 acquisition. First CL build was a L'il Satan, which lasted a couple years. THAT was a fun little airplane - taught me aerobatics rather well.
Oh, yeah - Christmas 1954, I was 6.
Old 02-14-2018, 07:23 PM
  #3512
76htodchris
my first plane, circa 1979. flew it alot - let my friend fly it - real pilot in training, and got it in a spin - I took over, and almost saved it. wings flew off, and I ended up mating those wings with a goldberg falcon. called it a fa- ket. 3 channel, no ailerons. but, what a great way to learn to fly. taught me to build, cover, and work with weight. I even had foam wings - forget how I got those - I think they were optional through tower hobbies or something.
sig made/makes great stuff.
Old 02-17-2018, 01:29 PM
  #3513
Pork Chop
Pork Chop's Avatar
My first build(s) were the rubber band models from Wonder World as a 6 year old (1973) and that same summer I bought a Cox PT-19 at a garage sale for a buck! My brothers friend started the engine for me and off she flew!
Old 02-17-2018, 06:16 PM
  #3514
Big Stikflyer
Big Stikflyer's Avatar
My first build was a rubber band powered Comet kit, covered in tissue and painted with low cost spray can paint. My oldest sister boyfriend got it for me. Gary showed me how to put the covering on with a flour and water paste. I was in junior high school by then. I didn't get into RC until I went into the Navy and watched some guys fly their planes on base and I just knew I had to get one. My first RC was a Sig Klipper with a OS Max 15 and Monokote covering. That was in 1977 and I was just 20.
Old 02-20-2018, 03:52 AM
  #3515
N1EDM
Big Stikflyer,
That base where you saw those RC Airplane fly... that wouldn't have been at NCTC Correy Field in Pensacola, FL would it???
Bob USNR Ret
Old 02-20-2018, 06:14 AM
  #3516
Hydro Junkie
Back then, Corey Field was a "spook" training base(sorry, the courses were and probably still are classified and having a high clearance was required just to be in some of the buildings) so I doubt that was the one. In the area around Corey, there was NAS Pensacola(home of the Blue Angels), NTTC Meridian MS, NATTC Millington TN(now decommissioned) that all had runways. I know there was a guy that flew a scratch built FG ducted fan F-16 at Millington, watched him fly it on several occasions. Also watched it go nose first into a taxiway due to a radio failure(that's best guess as he had no control of the plane after he started a loop)
Old 02-20-2018, 10:55 AM
  #3517
Big Stikflyer
Originally Posted by N1EDM
Big Stikflyer,
Bob USNR Ret
Not NCTC Correy Field, I was at NAS Whiting Field, Milton Florida. We could only fly when the airfield was closed. When I transfered to NAS Lemoore, California we actually had a flying field right on base. That base was so big we could fly rc anytime we wanted.
Old 03-03-2018, 07:49 AM
  #3518
skylark-flier
SIG has completely rebuilt their website - much modernized. Only drawback (so far) is that all the archived instruction manuals are gone. Also, right now nearly 2/3 of the links, as they show when you put your cursor over them, are incorrect. Clicking the links send them to the right place, they just don't indicate that they're GOING TO GO to the right place. Apparently, they're still building so it's likely to be corrected in the near future. Several planes are now missing, others have been re-instated. Sure made updating the website interesting today.
(cross-posted from SIG B'hood)
Old 03-05-2018, 07:30 AM
  #3519
FlyerInOKC
FlyerInOKC's Avatar
Nice look too! Next they need to update their recommendations on some of there electrics to make them more newbie friendly.
Old 06-17-2018, 08:34 AM
  #3520
funfly8
My Feedback: (20)
Gary, Can you add me to the list.
#1Kadet MK II built in '86 for my first one powered with an O.S. 40 FSR. First plane, long gone.
Currently:
#1 a Kadet Senior with Ailerons, flaps, 86" wing powered by a Saito 80, built around 2000(Time fly's when you are having fun). White with Pearl Blue wing and stab leading edge, rudder Florescent Pink with a strip of Blue & Pink down each side. Struts on the wing, removable tail. Due to be recovered and some minor repairs to the strut mount on the fuse.
#2 Kadet Senior given to me a few yeas ago. Just recovered it Cub Yellow With Transparent Blue on top of wing, Transparent Red on Bottom, Powered by a O.S. .46 FP with a Magnum cylinder and piston, 1 tank of fuel through it so far. Gear retracts into the fuse. Maiden soon.
#3 LT-40 still on the board, Wing and tail from a crashed plane. Stick built like a Senior. Will be electric powered
Future: Probably start soon, my Dream Senior
#4 To be a Senior, Low wing, twin, tail dragger, air retracts, powered by Saito 45's or 50's Plans built , will be cutting out ribs and other parts. Will expand the wing to 80". I will use other plans to get things right for the retracts. It will be called Dream Senior.
#5 Down the road. Perhaps a V-tail
Thanks, Steve
Old 06-18-2018, 04:17 PM
  #3521
cmy6
More Sig porn. The Astrohog has 12 flights on it and it’s well proven. What a great airplane and kit produced by Sig. I’m surprised at the lack of popularity of this airplane. You could probably teach someone to learn to fly with this rig.
Old 06-18-2018, 06:01 PM
  #3522
neons
neons's Avatar
35 years old Monokote just crumbled. Had at least 25 patches in it
The black and windshield were left alone
Flew as good as it looked. And I flew just about all types of planes.
That Astro Hog is a real gem, I love it. Sadly in other news I lost my Sig Kadet Senior when the wing elastics popped in a loop. . My friend that passed 9 years ago had it. I just covered it all new last winter to exact specs he had it as the original Monokote just popped if you tapped it. Of course it went back a lot of years when it was built.. I am going to rebuild the fuselage all back again and continue to fly her. It has been a dream flier over the years. I just found some pictures of the fuselage plan and will start it in the fall as the weather cools down
It has been a great ride.
**Neons** Bob
Old 06-18-2018, 09:31 PM
  #3523
skylark-flier
#1Kadet MK II ...
#1 a Kadet Senior ... #2 Kadet Senior ... #3 LT-40 ... #4 To be a Senior ... #5 Down the road. Perhaps a V-tail
Thanks, Steve
Ambitious!! Great planes and ideas though. Absolutely, y'er in Steve. Gotcha listed with #219. Welcome to the SIG Kadet Brotherhood!!
Been awhile. Here's the brotherhood, as I've got it today (3 columns):
    1 - GaryHarris
    2 - soarrich
    3 - N1EDM
    4 - Live Wire
    5 - 5skyhawk172
    6 - zippome
    7 - shepard62
    8 - DeferredDefect
    9 - archie05
    10 - tomgreen
    11 - n2ryd
    12 - race61
    13 - Slavko
    14 - lkruse
    15 - flyingagin
    16 - JPNYGAARD
    17 - foodstick
    18 - ovationdave
    19 - joebahl
    20 - WI53072
    21 - huck1199
    22 - Top_Gunn
    23 - Nergall
    24 - acdii
    25 - hutchis
    26 - ddewey
    27 - dhal22
    28 - Thomas Pham
    29 - cubkadet
    30 - Greg Davis
    31 - CanDo
    32 - gva1956
    33 - metaldriver
    34 - Bladejunkie
    35 - New222
    36 - cubflyman
    37 - dasquirrelisme
    38 - Planejaw
    39 - usc1990
    40 - cjet
    41 - Murphey
    42 - Sandyt
    43 - planedriver_2
    44 - PT19
    45 - TimHendrix
    46 - jessiej
    47 - Mr-Punk
    48 - rccrasher65
    49 - FMAY
    50 - Hrannar
    51 - Razor44
    52 - Ken Kehlet
    53 - oldfartpilot
    54 - Soaring Steve
    55 - freefall2907
    56 - fix-n-fly
    57 - SigMan
    58 - eroc144
    59 - nextofkin
    60 - ALT
    61 - jstyle13
    62 - WYDAH
    63 - stupidscreenname
    64 - coxco
    65 - TunnelBill
    66 - mike109
    67 - beevo
    68 - Lowvoltage
    69 - skylark-flier
    70 - hugh durden
    71 - Cloud Cruiser
    72 - SIGPlanes
    73 - rexperk
    74 - M. Boesen
    75 - whatwheel
    76 - Wagon1
    77 - paulhold
    78 - groundstrike
    79 - adreliable661
    80 - earlwb
    81 - Unclebuck21228
    82 - malitape
    83 - Dave Holmes
    84 - Carlos G
    85 - kingranch
    86 - Red Kadet
    87 - dirtrod
    88 - t4
    89 - FlyerInOKC
    90 - DELTAFLY
    91 - sharpe917
    92 - jollyroger
    93 - Cliffc
    94 - 1320fastback
    95 - captinjohn
    96 - spaceworm
    97 - EvanB
    98 - Major Tomski
    99 - Jim Branaum
    100 - WLM189
    101 - skyraider71
    102 - rc lifer
    103 - NM2K
    104 - terrysigcolt
    105 - plane-o-joe
    106 - BobFE
    107 - FLAPSDOWN
    108 - scttsprg
    109 - sbrillha
    110 - Mike Gretz
    111 - skyrat71
    112 - lumppi
    113 - bchapman
    114 - scoooper
    115 - JollyPopper
    116 - CNY_Dave
    117 - rtn9105
    118 - mbnt
    119 - crawler tech
    120 - 308jockey
    121 - bparker3
    122 - DBD1
    123 - Chappy110
    124 - ercobud
    125 - rickpell
    126 - ThunderBoat42
    127 - tazzzz
    128 - ThunderChicken72
    129 - deanz406
    130 - biam
    131 - UPF-7
    132 - neons
    133 - Flyboy14901
    134 - proszak59
    135 - wildbills21
    136 - hairy46
    137 - p-Yock
    138 - rrengineer
    139 - hogflyer
    140 - Firewalkerd1
    141 - Flight Risk
    142 - ratshooter
    143 - Steve Westphal
    144 - cforcht
    145 - kb8ife
    146 - rburke39
    147 - rc56
    148 - redjack
    149 - rdgettler
    150 - daddyvinny
    151 - MartyPetriSr
    152 - tomclark
    153 - c-crunch
    154 - BigTeeEldorado
    155 - TomCrump
    156 - hiflyer15
    157 - Fly North
    158 - dwaynenancy
    159 - oinoyou
    160 - Jersy Hank
    161 - flashpilot
    162 - Old_RC_Guy
    163 - TheComputerGeek
    164 - FloridaBeachFlyr
    165 - aggieman
    166 - Renegade
    167 - T-47
    168 - SigSenior
    170 - WMB
    171 - ckimmey
    172 - paul7194
    173 - bebopgolf
    174 - Big Stikflyer
    175 - nealmontgomery
    176 - Battle Short
    177 - canadian8apilot
    178 - Mud Duck
    179 - EDDIEMAC
    180 - merto31
    181 - bisszerk
    182 - Pork Chop
    183 - bushman8377
    184 - cmy6
    185 - ETpilot
    186 - michaelnel
    187 - mortyspals
    188 - PiperRon
    189 - BrightGarden
    190 - schwalbe
    191 - Brayden
    191 - GIVdriver
    192 - wood489
    193 - KenChoo
    194 - aliraminghe
    195 - shadowridertcw
    196 - Hydro Junkie
    197 - SPACE COWBOY
    198 - Bumpie
    199 - jsparky
    200 - br549-2
    201 - PatrickCurry
    202 - Dwayne
    203 - Leroy Gardner
    204 - FazFly
    205 - Shere-Khan
    206 - Jeff Spicoli
    207 - bodybuildr
    208 - Sport_Pilot
    209 - arnieby
    210 - richard dee
    211 - pens100
    212 - Dave Swanson
    213 - robflyer82
    214 - leitefrog
    215 - fennel
    216 - eeyess
    217 - jayyak
    218 - Mwt5086
    219 - funfly8
Old 06-18-2018, 09:36 PM
  #3524
skylark-flier
Bob & Jay - great pics guys. That pink really comes through Bob.
I think the Astrohog is a whole lot more popular than you give it credit for. In the SIG Brotherhood I've got 25 known Astrohog owners.
Old 06-19-2018, 04:34 AM
  #3525
FlyerInOKC
FlyerInOKC's Avatar
Hot Pink no that's an airplane you can see no matter what the sky is like that day!
