Reload this Page >
~~SIG Brotherhood ~~
Old 01-20-2019, 07:14 PM
  #3526
do335a
Default Astro Hog
My clipped wing Astro Hog.
O.S. FP60 with 90 size muffler.
Old 01-21-2019, 10:14 AM
  #3527
skylark-flier
skylark-flier's Avatar
VERY nice!!!!! That's absolutely SURE to get some attention at the flying field.
Old 01-22-2019, 05:53 PM
  #3528
Captcrunch44
Well third and final hog done.
Old 01-26-2019, 01:03 AM
  #3529
GUS THE I.A.
Default In regard to the King Kobra...
Thanks for your interest! The scarfed tips on the airplane are sort of an homage to one of my favorite planes - the Curare - an R/C Pattern plane from 1976, by Hanno Prettner. Mr. Prettner changed the way pattern was flown, forever , and the design of all the airplanes that followed.
Old 01-26-2019, 01:14 AM
  #3530
GUS THE I.A.
Default More info...
Originally Posted by H5606
Really like your uniformity of colors across the board for all the subjects of your air force; thinking about doing the same for a few models. Really cool checkerboard undersides and switching to a conventional-gear like jet on the King Kobra too.
Wondering about the unique, scarfed wing and stab tips on the KK; is this a mod used to avoid high speed flutter on aileron/elevator? Did you have to lower the tank to accommodate the inverted engine? Also wondering if the Sig Primary Force is a one-off kit - I know it was once offered as an ARF but was wondering if you could elaborate on the Mike Pratt short kit...
Yep, lowered the tank in the KK, The Primary Force was from Mikey Pratt's run of "short kits" that he offered on Stunthangar.com
Old 01-29-2019, 09:50 AM
  #3531
tmaxx1701
tmaxx1701's Avatar
I am in the process of building a 4*20 and plan on using a Satio .30 4 stroke in it. I am trying to place the fuel tank and wondered if anyone here has build a glow powered 4*20. I have a 4 oz tank but having some challenges figuring out the support for it and general placement. In this view it is inserted thru the opening in the F2 because I think if it goes forward more I will have problems getting the fuel lines thru the firewall hole.
I know 4 strokes drink less fuel than a typical 2 stoke. Is it practical to use a 2 oz tank instead?
Just looking for some ideas and suggestions.
Dave
Old 01-29-2019, 10:20 AM
  #3532
TomCrump
TomCrump's Avatar
If it were me, I'd ignore the hole, and move your tank forward. New holes can be drilled for the fuel lines.
Old 01-29-2019, 10:42 AM
  #3533
FlyerInOKC
FlyerInOKC's Avatar
I agree with Tom. As for tank size mount the engine on a tes stand and see how long 2 oz lasts when running at your desired throttle setting.
Old 01-29-2019, 11:43 AM
  #3534
tmaxx1701
tmaxx1701's Avatar
Thanks for the comments guys. It will probably be better with the lines coming out higher as the carb is above the current hole in the firewall. I will have to mount the engine up and see what my options are. We are in the deep freeze here in Michigan for a while so I won't be able to test run the engine for a while. Might have to put this on the back burner for a while.
Old 01-29-2019, 11:56 AM
  #3535
Captcrunch44
You will most likely need to lower the engine to get the carburetor low enough to match the center line of the tank.
And mount the tank as high as you can. I have done this with mine. Also 4oz tank is plenty of fuel
but i like to fly longer periods then most so 2oz isn’t enough.
Oh and I believe a 2 oz weight in the tail.
Old 01-29-2019, 01:44 PM
  #3536
Flight Risk
Flight Risk's Avatar
Just wondering is a small header tank and a larger main tank would be worth the effort, or even be workable. Or design your own tank from a long skinny bottle.
Old 01-29-2019, 04:43 PM
  #3537
Captcrunch44
a 4oz tank is plenty. Just have the tank as high as you can get. But you will have to lower the engine so the center line of the carb is in line with the center lime of the tank.
Old 01-30-2019, 07:29 AM
  #3538
aspeed
aspeed's Avatar
You can mount the motor sideways instead of lowering it too. On another subject, would an AX .55 be enough power on an Astro Hog with or without floats? Mine came with an AX .46 and floats, but I put a .55 on just in case, as it pretty much fit anyway.
Old 01-30-2019, 10:23 AM
  #3539
Captcrunch44
yes that will work. I fly Astro hogs with .72 -1.25 four stroke’s.
So you are in the neighborhood. But my favorite engine has be the Saito 91.
Old 01-31-2019, 05:18 AM
  #3540
PlaneJames
My Feedback: (14)
Default Sig Klipper
Was thinking of scanning the printed fuselage sides and other parts to make a set of plans. Has anyone already attempted this?
thanks
james
Old 02-01-2019, 08:54 PM
  #3541
skylark-flier
Nobody that I've ever head of has tried this, James. However, if you're successful and can make a pdf, and can get a copy of the wing planform in addition, I'd be all to happy to include them in the SIG History site. Klipper shows on page https://wanderings-ds.jimdo.com/sig-rc-kits-21-40/ , RC37.
I'm absolutely positive the guys would love some kind of plans for the Klipper.
Old 02-02-2019, 06:11 AM
  #3542
aspeed
aspeed's Avatar
That Klipper looks almost the same as the Skamp, OK, Scamp. I got one of those. Nice flyer, but you would need the foam wing which is not around any more Glancing over the list I saw a nice project there. The Relic. Also turns out that I have a swap meet deal downstairs on the list. Mustang 450. Wow, 1971. Now at least I know what it is. I saw the printing inside, and it looked like Sig printing.
Old 02-02-2019, 12:55 PM
  #3543
skylark-flier
Y'er right - a total recreation would need the foam wing, which may be procurable from a couple sources. However, a standard rib & spar wing COULD be recreated just having the outline of the wing itself.
Yeah, there are several rather good planes in this class, the Relic being one of the better ones, IMHO.
Old 02-02-2019, 02:40 PM
  #3544
aspeed
aspeed's Avatar
A stick, some .015" wire and a battery will get a hot wire, and you could cut one up too. Just needs joining as the original had the dihedral molded in. It was pretty thick, likely for strength.
Old 02-02-2019, 03:56 PM
  #3545
ETpilot
ETpilot's Avatar
I’ve gone over that list again. I, too, find the Relic interesting. Shouldn’t be to difficult a build. I’ve also studied the Komander indepth. I got all the info I need for it and almost started a scratch build. Maybe later. My problem is my grass runway. Not sure how a tri-gear would do on it. I’ve been building only taildraggers.
Old 02-02-2019, 04:36 PM
  #3546
aspeed
aspeed's Avatar
I always change my planes to tail draggers before building. I don't even like the wheels in the wing, better on the fuselage where things are stronger. I didn't notice the Relic was that foam wing. That would be a good victim for one of my AP .09s or .15s. I think I have one or two wings somewhere with a corner knocked off. Those wings were nice, kind of like the Ace 1/2A foam wings.
Old 02-04-2019, 08:57 AM
  #3547
FlyerInOKC
FlyerInOKC's Avatar
I have a project designed for Ace R/C foam wings. I found a laser cutter who was willing to make the pre-notched ribs and now the airplane will have a built up wing which I like better any way.
Old 02-04-2019, 10:09 AM
  #3548
aspeed
aspeed's Avatar
Balsworkbench already carries a short kit for $10. Probably no spars as it is a short kit. http://www.balsaworkbench.com/?page_id=2601 See who is cheaper I guess? Sounds fairly reasonable to me, although here there is a dollar exchange and a border gestapo. Apparently Lazer Works can make up a Scamp short kit, or wing kit for a bit more than the Ace one. Well a fair bit more. $28. http://lazer-works.com/misc.html it is under Scamp about 3/4 of the way down the page.
Old 02-04-2019, 12:03 PM
  #3549
FlyerInOKC
FlyerInOKC's Avatar
Balsworkbench already carries a short kit for $10. Probably no spars as it is a short kit. Ace mini foam wing | The Balsa Workbench See who is cheaper I guess? Sounds fairly reasonable to me, although here there is a dollar exchange and a border gestapo. Apparently Lazer Works can make up a Scamp short kit, or wing kit for a bit more than the Ace one. Well a fair bit more. $28. | Lazer Works - Engraving & Design | Radio Control Airplanes, Specialty, and More it is under Scamp about 3/4 of the way down the page.
I bought my ribs from Balsaworkbench. He makes ribs to replace the regular and mini size foam wings.
Old 02-06-2019, 01:26 PM
  #3550
trainermaster80
trainermaster80's Avatar
Just wrap your 4 oz tank in foam rubber and stuff it in
smaller pieces of foam can adjust the position & lock the tank in.
If you invert the 4 stroke make sure not to flood the engine on first start up
frankie the 90 year old modeler
