~~SIG Brotherhood ~~
#2326
Or a set of eflites. Have a set on my Top Flite P51 and they work great. No air to worry about, no lines, no fittings, just lug in and they work. Put is a larger RX battery and you are good to go.
#2328
well, damn, wish I had one. Hopefully I will have a couple planes ready soon. Only have the Something Extra ready to fly, all the others need work. T-Clips is still waiting on an engine, LT-40 needs the ailerons rehinged, and need a new cowl for the Cub. My other Cub needs a once over and it can be ready for flight. P-51 needs the engine retuned, if I can get it started, and the 4*120 needs the engine re-adjusted. I might yank the DLE-20 off and replace it with the XYZ which uses a different carb and was pre-tuned by the seller The P-47 needs a replacement cowl. I have to do some more sanding, put the panel lines on, then I can paint it and prep it to make a mold.
All this and building the B-25 at the same time. I need more time.
#2331
Thanks. I have an FG-11 I was flying it with, and picked up a Saito 56 for it instead. Problem is, the muffler that came with the 56 is wrong. Too small, so have to order a Turboheader for it. I needed tail weight for the FG, so hoping to reduce weight so it flies better. It flew OK but lacked the power to recover from a stall. The FG-11 uses a different mount than the 56.
#2335
Do you overnight there? I have a 28' Trailer that I would be taking if I can get a spot. Need to be sure I can get a spot, or will get a motel room in the next town over. That also determines if I spend the money to make an extended run fuel system for my genny.
#2336
Don't forget there is a nice campground at Diamond Lake county park just a mile north of town that has facilities. We used to camp there for many years because it was shaded and had some level campsites and the fishing was pretty good.
#2339
And Bob is right Diamond lake campground is beautiful. Thought about taking are camper there for the fun of it.
#2340
I take it your talking about the fly-in at Sig. I'm hoping to go this year, this will be my first trip there. I was thinking of going Thursday to get a spot and then I want to go check out the plant on monday.
Hi Bob, I talked to you in the past about my Komander that I want to bring with me. I am looking forward to meeting you and getting some flying in. This might be a dumb question, but I take it you can only fly with with 2.4 gig radios at this fly-in?
Okey , hope to see you all there.
#2348
Hope to see you there.
#2350
Capt crunch
Thanks for the info. I can't believe you got the 168, way out of my budget or room for in my shop. What kind of servos are you using in something that big? Enjoy your build and if I get to Sig this year I hope to meet you.
